Help with migration
  • hpjrvs
    • Aug 2013
    Help with migration
    I want to change my zabbix server version to 2.0.7.
    Today I have 2.0.4 server.
    I need to run any script to upgrade?
    Or just compile the binaries.
  • tchjts1
    • May 2008
    • 1605
    There are no DB changes within minor releases. Just recompile the source and as due dilligence, I always put the new frontend files into place as well.
    if you do replace your frontend files, you will want to save your existing zabbix.php.conf file and then put it back into place after you put the new frontend into place. It goes into the destination/conf where your frotnend files go. For me it is: /var/www/html/zabbix/conf
    That will save you from being prompted to go through the GUI configuration again.
    • hpjrvs
      • Aug 2013
      Thank you
      Thank you tchjts1,
      I already did the migration and works fine.
      But I just want to be sure if there is no database changes.
      Thank you for your answer.
