Getting custom script(ping) working from zabbix server
  • zabbixfk
    • Jun 2013
    • 256
    Hello All,
    Problem statement: Get the packet loss/delay miliseconds using Ping.
    Tried Solution:
    I am trying to trigger custom script written, which just takes ip address as first argument, and returns number of delay in mili seconds. Below is my script.
    #!/bin/bash
    echo -e "\n\n" >>/tmp/o.txt
    echo "received $1">>/tmp/o.txt
    if [ "$#" != 1 ];
    then
    	echo -e "YOU HAVE TO PASS THE IP ADDRESS OF THE MACHINE TO PING AS FIRST ARGUMENT...!!!\n";
    	exit -1
    fi
    	ip=$1
        stat=1
        if [[ $ip =~ ^[0-9]{1,3}\.[0-9]{1,3}\.[0-9]{1,3}\.[0-9]{1,3}$ ]]; then
            OIFS=$IFS
            IFS='.'
            ip=($ip)
            IFS=$OIFS
            [[ ${ip[0]} -le 255 && ${ip[1]} -le 255 && ${ip[2]} -le 255 && ${ip[3]} -le 255 ]]
            stat=$?
        fi
    	echo "returing $stat">>/tmp/o.txt
    	if [[ $stat == 0 ]];
    	then
    		echo "inside okay">>/tmp/o.txt
    		result=$(/bin/ping -c 5 $1 | grep -E "time=" | awk '{print $7}' | sed s/time=//g | xargs echo | sed -e 's/\s/ + /g' | sed -e 's/^/( /' | sed -e 's/$/ ) \/ 5/' | bc)
    		sleep 2
    		echo "$time|$result">>/tmp/o.txt
    		echo $result
    	else
    		echo "inside no">>/tmp/o.txt
    		echo -e "OOPS, I CAN't VALIDATE YOUR IP ADDRESS... SORRY...!!!";
    		exit -2;
    	fi
    Now it is located under
    /usr/local/etc/scripts/checkPing
    I have also created a symbolic link in
    /etc/zabbix/externalscripts/
    to above.
    Also added this line under zabbix_agentd.conf on zabbix server
    UserParameter=checkPing[*],  /usr/local/etc/scripts/checkPing $1
    And then in my template, added new item called
    item name : checkPing
    type as externalcheck
    Key as checkPing[{HOST.CONN}] ( tried {HOST.HOST} but it didn't work so used this key)
    Since this template is mixture of snmp and general ( snmp because i am trying to monitory a firewall with discovery rull, and item prototypes), Is there any other config involved?
    1). Do i need to make any changes to run this from zabbix server to firewall ping test (as above solution isn't working).
    2). If i want to run this on a client machine behind firewall and ping some other server to check the latency or connectivity what other changes to be done on this?
    zabbix server: Oracle Linux server 6.4 with kernel 2.6.39-400, zabbix server/ agent version: 2.0.6
    Any pointers are greatly helpful.
  • Heilig
    • Mar 2013
    • 366
    If you run the script from the command line with IP, what it returns?
    Please try Zabbix Agent or Zabbix Agent (active) (details here https://www.zabbix.com/documentation...userparameters and here https://www.zabbix.com/documentation...xtending_agent)
    • zabbixfk
      • Jun 2013
      • 256
      [SOLVED] Getting custom script(ping) working from zabbix server
      Thanks for the reply. Now i am able to get this thing working. I had to remove the userparameter line from zabbix_agentd.conf on zabbix server, but created a symbolic link to existing script on
      , then i stated getting values.
