ZABBIX 1.1: Known issues & patches
  • dantheman
    • May 2006
    • 209
    #16
    Originally posted by dantheman
    I'm having the same issue as Phileppe, the host availability status does not update, for me I only monitor windows servers, so that's where I'm having problems. I don't know about linux agents. For me it seems to usually only update if there is a change to the availability, but not always.. i deleted the item and recreated it to see if that would get it going again, but it didn't... right now the only host that shows correct is the one for a server that was rebooted last night...
    There is one server that the latest data shows a status of 2, but the server is up and running and so is the agent.. I'm collecting other data from it.. but it just shows a status of 2........ not sure why that is..?
    If I stop the agent for 5-10 minutes and then turn it back on then the status updates once... but not every 60 seconds like I have configured in the item update interval setting.
    Alexei.. can you let me know if this a bug with the agent, a configuration problem, or by design?
    Thanks for all your hard work!
    Dan
    • Alexei
      Founder, CEO
      • Sep 2004
      • 5654
      #17
      It is by design. The update interval is ignored for the status item.
      Alexei Vladishev
      New York | Tokyo | Riga
      My Twitter
      • sphaero
        • Nov 2005
        • 11
        #18
        Refresh unsupported active agents
        I'm having the following issue with zabbix 1.1:
        Monitoring network interfaces (ppp) which temporary shutdown are put to "UNSUPPORTED" when using active agents and don't come back up in zabbix and so are not monitored anymore. Even the "refresh unsupported items" option doesn't help. The only workaround is to manually activate the items again.
        Arnaud.
        • thebrowser
          • Jul 2006
          • 9
          #19
          Hi there,
          I think there is a bug in zabbix agent for Windows.
          It's about the vfs.fs.size key which returns a value in Byte instead of a value in KByte.
          thebrowser
          • thebrowser
            • Jul 2006
            • 9
            #20
            another bug in windows agent
            I found another bug in the windows agent:
            Under windows, net.tcp.port returns 1 when it can't etablish the connection, and 0 when it can etablish it.
            the following line of network.cpp of the windows agent show the bug:
            *value=1; // Port unreacheable
            *value=0; // Connection successful
            in the official documentation, is is written that:
            net.tcp.port[<ip>, port]
            Check, if it is possible to make TCP connection to port number port.
            0 - cannot connect
            1 - can connect
            thebrowser
            • thebrowser
              • Jul 2006
              • 9
              #21
              I found another bug.
              In the SNMP_t template, there are triggers which use "item_key.delta(0)".
              The triggers statut stay as UNKNOWN.
              I found that if i change "item_key.delta(0)" to "item_key.delta(60)", it works.
              So the bug comes from the 0.
              In the documentation, it's written that
              "delta Same as max()-min() "
              However, shouldn't it be last() - prev() ??
              Alexei, can you answer to my 3 last post in this topic, and confirm they are bugs ?
              thebrowser
              • thebrowser
                • Jul 2006
                • 9
                #22
                i found a new bug:
                when a host is added using his dns instead of his ip, the icmppingsec ( and icmpping i guess ) key are not working.
                I prefer to use the domain name of my servers instead of their ip adresses.
                can you check that ?
                • Alexei
                  Founder, CEO
                  • Sep 2004
                  • 5654
                  #23
                  thebrowser
                  The SNMP_t template is wrong. Why should Delta be defined as last()-prev() if there is already change()?! The documentation is absolutely correct.
                  Alexei Vladishev
                  My Twitter
                  • Alexei
                    Founder, CEO
                    • Sep 2004
                    • 5654
                    #24
                    i found a new bug:
                    It is not documented "feature" that has been discussed many times. Please do not post your bug reports in this thread! It is very hard to keep track of them. One post per bug report please!
                    Alexei Vladishev
                    My Twitter
                    • vrtareg
                      • May 2006
                      • 293
                      #25
                      Hi
                      Please look topic: http://www.zabbix.com/forum/showthread.php?t=3413
                      Areg
