Unable to use any IPMI item
  • welkin
    • Mar 2007
    • 132
    Hi there,
    i'm trying to connect to a Server via IPMI and it fails with:
    "cannot connect to IPMI host: [33554449] Unknown error 33554449"
    Using the ipmitool on the commandline with the same settings as in zabbix, it works fine.
    Zabbix is: 2.0.8
    libopenipmi is: 2.0.18 (i tried .19 too)
    Using "debug=4" doesn't give me any further information...
    I'm trying to connect to a Sun x4100
    Any help is appreciated
    Regards,
    welkin
  • Heilig
    • Mar 2013
    • 366
    Please, read https://support.zabbix.com/browse/ZBX-6077 and try to test throw ipmi_ui tool.
    • welkin
      • Mar 2007
      • 132
      I'm afraid it's not that bug.
      I've tried the ipmi_ui tool and it gives me:
      IPMI connection to con.port 0.0 is down due to error 0x2000011
      No matter what user level i try.
      Regards,
      welkin
      Just tried lib version .19 ... and it gives me the same error.
      • Heilig
        • Mar 2013
        • 366
        What version of OpenIPMI you are using (https://www.zabbix.com/forum/archive...t-10797.html)?
        • welkin
          • Mar 2007
          • 132
          Zabbix is: 2.0.8
          If more information is needed, i'd be happy to provide it.
          Regards,
          welkin
          • welkin
            • Mar 2007
            • 132
            I also tried libOpenIPMI 2.0.20-rc3. still the same error.
            Maybe someone could post the exact parameters of an working IPMI setup.
            Thanks in advance,
            welkin
