Graph Scale Problem
  • xarous
    • Oct 2009
    • 15
    Graph Scale Problem
    Since upgrading from 1.8.4 to 2.0.6 we've had an intermittent problem with the graph scale on some graphs.
    It looks like the bottom scale number is repeated twice, then the top two numbers on the scale overwrite each other. The issue is also intermittent - changing the date range on the graph can clear the issue, and the same template defined graph can work fine on one host, but not another.
    I've attached an example which makes it a bit clearer.
    Any ideas how to fix this?
    Cheers,
    Jeff
