How to display the groups in the drop down box according to the screen?
  • sriram ganesh
    • Aug 2013
    We are using zabbix 2.0. Our problem is to display the groups according the screen. Because there will be confusion to select the groups and host for the screen. Say for example we create a screen called System performance, for a host to monitor its system performance and it contains the graphs in the Template OS Linux. This host is under group called Basic monitoring. Now in the Monitoring -> Screens if we select screen name as System performance from the drop down list, we need only the Basic monitoring group in the groups drop down list. Other than this group should not be there in the groups drop down. Help us for how to do this.
    Thanks,
    -Sriram G.
