system.run ... need to run a longer command
  • KarmaPolice
    • Oct 2005
    • 95
    I need to run a relatively long command... specifically:
    /usr/sbin/ioscan -kC processor|grep -n processor|wc -l|awk '{print $ 1}'
    using the system.run[] parameter... i changed the database field so it would accept an item of this length, however i still am getting "Not Supported" when it tries to run...
    is there another length setting set somewhere?
  • SLMitch
    • May 2006
    • 39
    I have the same problem.
    The faulty one is MAX_ITEM_KEY_LEN configured to 64. I fixed it to 128, i dont know if there will have colateral damage.
    if you use mode DEBUG for the agentd, you can see command is trunked.
    diff -ruwB zabbix-1.1-orig/include/db.h zabbix-1.1/include/db.h
    --- zabbix-1.1-orig/include/db.h        2006-06-23 10:51:07.000000000 +0200
    +++ zabbix-1.1/include/db.h     2006-06-23 10:54:09.000000000 +0200
    @@ -80,7 +80,7 @@
     #define        MAX_HOST_HOST_LEN       64
    -#define        MAX_ITEM_KEY_LEN        64
    +#define        MAX_ITEM_KEY_LEN        128
     #define        MAX_ITEM_IP_LEN         15
     #define        MAX_ITEM_SNMP_COMMUNITY_LEN     64
     #define        MAX_ITEM_SNMP_OID_LEN   255
    @@ -107,7 +107,7 @@
     #define HOST_ERROR_LEN                 128
     #define HOST_ERROR_LEN_MAX             HOST_ERROR_LEN+1
    -#define ITEM_KEY_LEN                   64
    +#define ITEM_KEY_LEN                   128
     #define ITEM_KEY_LEN_MAX               ITEM_KEY_LEN+1
     #define GRAPH_NAME_LEN                 128
    • KarmaPolice
      • Oct 2005
      • 95
      i assume i need to re-compile then?
      and do i just need to re-compile the server? or the agent? or both?
      • KarmaPolice
        • Oct 2005
        • 95
        and one more question... is there a similar field controlling the length of a return value (in this case a textual one)...
        I changed the DB field to LONGTEXT but it still seems to be chopping off before the end of the output... i'm guessing there is a similar variable hidden somewhere though that i could change...
        Thanks!!!!
        • KarmaPolice
          • Oct 2005
          • 95
          @@ -80,7 +80,7 @@
          @@ -107,7 +107,7 @@
          did that actually fix it for you? it doesn't seem to have fixed it on my end
          • KarmaPolice
            • Oct 2005
            • 95
            bump for some help?
            • SLMitch
              • May 2006
              • 39
              With my patch, i have not problem. You have to recompil agent
