zabbix 2.0.6 problem failed: first network error, wait for 15 seconds
  • officielmc
    • Apr 2011
    • 32
    Hi everybody
    I have very wired problem. I'm using zabbix 2.0.6 under centos 6.4 with postgresql.
    I using SNMPv3 to monitor Juniper router. From zabbix server if I'm doing (snmpget -v 3.........) with the OID for the VPN status for example I get answer. In GUI when i checked latest data for this host for example (BJSOPS-router) I have the right value. But on the server side the log file I have lot of error like this "[VPN_Status] on host [BJSOPS-router] failed: first network error, wait for 15 seconds".
    I understood nothing and for other router same model, same template, same ios I cannot get the value, and still get lot of error on the log file I don't know why.
    Today I updated the zabbix version to 2.0.8 but still same problem. Nobody can help me please??
    Thanks for your help
  • officielmc
    • Apr 2011
    • 32
    Nobody can help me? I also changed the UnavailableDelay / UnreachableDelay / and Unreachable period. But still same, I really don't know how to solve this issue
    • tchjts1
      • May 2008
      • 1605
      On your Zabbix server, in zabbix_server.conf, what value do you have for Timeout= ? If you have the default of 3, try increasing that to 10 and restarting your Zabbix server process.
      (Edit) I also seem to recall a somewhat similar issue where the user reported that he changed SNMPV3 to using SNMPV2 on his items and it solved the problems he was seeing. Maybe worth a try?
      • officielmc
        • Apr 2011
        • 32
        Thanks tchjts1 I though nobody gonna help me .
        I went to zabbix_server.conf , my value for the timeout was the default value so I increase to 10.
        But still same, about SNMPv2 for security reason i cannot use it in my company. SO have to find solution with SNMPv3. If someone have any idea feel free to let me know.
        • tchjts1
          • May 2008
          • 1605
          Take a look at this post... The last paragraph and the graphs. If you have these graphs, can you post screenshots of them showing a 1 or 2 day period?
          • officielmc
            • Apr 2011
            • 32
            Thank you again for your support,
            Attached you can find the different graph about Zabbix server. I will continu to check and if you have any idea let me know.
            • officielmc
              • Apr 2011
              • 32
              I solved this issue. In fact all my devices had the same Local-engine-id that's why I got this error.
