Error: zabbix-2.1.5 / CentOS/ Monitoring VMware
  • andredeo
    • May 2008
    • 19
    I installed the last beta version, and created hosts for my VMware Esxi 5.1 and VMware Vcenter and put the templates.
    When I active the host, i recieve this errors in zabbix_server.log:
    noname.xml:14: parser error : Opening and ending tag mismatch: meta line 13 and head
    </head>
    noname.xml:85: parser error : Entity 'nbsp' not defined
    &nbsp;
    noname.xml:87: parser error : Opening and ending tag mismatch: meta line 5 and html
    </html>
    noname.xml:88: parser error : Premature end of data in tag head line 4
    noname.xml:88: parser error : Premature end of data in tag html line 3
    Any ideas?
    Regards,
    Déo
  • richlv
    • Oct 2005
    • 3112
    is zabbix pointed directly at the vmware, or is there any kind of a proxy or such ?
    • andredeo
      • May 2008
      • 19
      Is pointed directly to vmware.... But my problem was the variable $URL, I forgot to back here and say it...
      Tks,
      Déo
