Database monitoring with unixODBC (mysql)
  • Timoteo
    • Oct 2013
    I'm trying to monitor a MySQL DB running on a linux client. I've followed these instructions exactly:
    I'm running Zabbix server 2.0.8 on CentOS 6.4.
    I can access the remote DB via isql with no issues.
    I set up a 'database monitoring' item for the host in Zabbix and a trigger to no avail.
    The item doesn't go to 'unsupported', it stays 'enabled' and the trigger never fires off an action, even if I change the trigger to obviously fail.
    With verbose logging on the server, I get this:
    In substitute_key_macros() data:'db.odbc.select[mysql]'
    End of substitute_key_macros():SUCCEED data:'db.odbc.select[mysql]'
    In get_value() key:'db.odbc.select[mysql]'
    In get_value_db() key_orig:'db.odbc.select[mysql]'
    In odbc_DBconnect() db_dsn:'MySQL' user:''
    End of odbc_DBconnect():SUCCEED
    In odbc_DBselect() query:'select count(*) from mysql;'
    It never returns a query SUCCEED, like I'm expecting.
    Any ideas on why my item and query are hanging, even though isql goes right through?
    Thanks!
  • ghoulich
    • Aug 2014
    I've got the same problem as you described, and google doesn't give any help ...
