Items sorting on different pages
  • vrtareg
    • May 2006
    • 293
    Hi
    Is it possible to add sort in sql scripts?
    There are many pages which will be looks better if they will be sorted.
    You can see 2 attached images with overview page which not like good for me.
    Every time when i open this page i see different order of the servers list.
    It is difficult to examine this list.
    Regards
    Areg
  • vrtareg
    • May 2006
    • 293
    I patched triggers.inc.php to sort overview by the hostname too
    --- triggers.inc.php.old 2006-06-28 10:11:47.000000000 +0500
    +++ triggers.inc.php 2006-07-03 12:52:33.000000000 +0500
    @@ -1047,7 +1047,7 @@
    ' from hosts h,items i,triggers t, functions f '.$group_where.
    ' h.status='.HOST_STATUS_MONITORED.' and h.hostid=i.hostid and i.itemid=f.itemid and f.triggerid=t.triggerid'.
    ' and t.status='.TRIGGER_STATUS_ENABLED.
    - ' order by t.description');
    + ' order by h.host,t.description');
    unset($triggers);
    unset($hosts);
    while($row = DBfetch($result))
    Regards
    Areg
    • andreas
      • Apr 2006
      works fine, but now the triggers on the left side are not sorted anymore.
      can you help please..
