Zabbix Proxy Installation and Configuration
  • ramesh.vishwa
    • Oct 2013
    I am new to zabbix please help me to install and configure zabbix proxy for centerlized monitoring.
    Thanks in advance
  • nick0909
    • Apr 2013
    • 73
    Do you have a primary zabbix server up and running? You need one of those before you can use a proxy. After that, setting up the proxy is just like setting up another zabbix agent device really (just point it at the main server). There are a lot of "how to" guides out there on google to get you started, if you run in to a specific problem the forums can help you out further.
    • ramesh.vishwa
      • Oct 2013
      Hi Nick Thanks for reply
      I have installed primary zabbix server and running i need help to setup zabbix proxy for centelized monitoring.
