Disable low-level discovery (LLD) update
  • nuno.pereira
    • Apr 2012
    According to the manual, when an item is not discovered anymore, "(...) the items will be deleted after the days defined in the Keep lost resources period field pass; triggers and graphs will be deleted immediately."
    We have some items that we need to have event history that sometimes aren't discovered, temporarily.
    Is there a possibility to not delete the triggers and/or graphs when items aren't discovered anymore?
    If not, is there a possibility to disable low-level discovery, either globally, by host or by LLD rule, without deleting items, triggers and graphs, freezing the discovered items?
    I've tried putting an update interval of 0, but that it's not possible (we have to put a flexible interval with update item > 0). Disabling the LLD rule was not tested now, but I think that it's like not having the item discovered.
    Thank you.
