https 6 ldap not supported
  • pingulino
    • Nov 2013
    I'm using simple check for a few servers, using templates for ssh and http works fine. (Template App SSH Service: SSH service is running - net.tcp.service[ssh] ).
    However, choosing service https or ldap gives "Not supported". If I change to "net.tcp.service[tcp,,389]" it works fine.
    I have read several threads about this issue, both here and in other forums, but haven't found a solution.
    I compiled zabbix from source with
    ./configure --enable-server --enable-agent --with-mysql --enable-ipv6 --with-net-snmp --with-libcurl --prefix=/od/apps/zabbix-2.2.0-ny --with-ldap
    It clearly said " LDAP support: yes" after ./configure
    I checked curl:
    ldd /od/apps/zabbix/sbin/zabbix_server |grep curl
    libcurl.so.4 => /usr/lib/x86_64-linux-gnu/libcurl.so.4 (0x00007f2143bbc000)
    Maybe this is not a real problem? That is, if using "tcp" for service is really reliable?
    Version: zabbix-2-2-0
    OS: Ubuntu 12.04.3 LTS
    Apache/2.4.6
    PHP Version => 5.5.5-1
