Excluding mount-points
  • uxbod
    • Nov 2013
    am testing Zabbix 2.2.0 and how it handles file system discovery. we are using ZFS and at first those mount-points were not being found until I changed the regular expression to include it. That works great but it is also identifying all the snap shots eg.
           "{#FSNAME}":"\/mnt\/storage-pools\/qs-8cea6be2-71ed-a436-f4aa-974abbcac083\/test-data_snaps\/@GMT-2013.11.05-16.00.41",
                            "{#FSTYPE}":"zfs"},
    Thanks.
  • uxbod
    • Nov 2013
    I did find this post where somebody wished to do something similar https://www.zabbix.com/forum/showthread.php?t=42625
    Could I change the filter on the LLD rule to say {#FSTYPE}|{#FSNAME} and then create a new regex that excludes say ^zfs|.*_snaps
    • uxbod
      • Nov 2013
      Struggling with this as cannot see how when can combine Macros and then execute a multi-step regex against it. Any help appreciated please.
      • steveboyson
        • Jul 2013
        • 582
        Just define a separate regexp rule with "result = FALSE" which finds the snapshots for the same macro.
        You might need to place it at the very beginning of your regexps - I don't know if the sequence matters at all.
        • uxbod
          • Nov 2013
          But the macro is different. The standard file system discovery looks at FSTYPE and to know whether its a snap one needs to look at FSNAME. So appears that its not possible to exclude as cannot regex across the two macros. Is that correct ?
          • steveboyson
            • Jul 2013
            • 582
            Yes, that is correct. You cannot bind more than one LLD regexp macros to one LLD.
            Then you have to create our own macro and filter out the values you need/bon't need (e.g. use #FSNAME in your regexp).
            • uxbod
              • Nov 2013
              Ah, so I could create a global macro called {$FSFULLNAME} with a value of {#FSTYPE}--{#FSNAME} and then use {$FSFULLNAME} within a new regex ?
              • steveboyson
                • Jul 2013
                • 582
                Ahm - no. I'm afraid that is not possible.
                I meant you should use macro {#FSNAME} rather than {#FSTYPE} and filter there.
                • uxbod
                  • Nov 2013
                  Darn, that is going to be a real pain then Okay, thanks and appreciate the help.
                  • johansen
                    • Oct 2009
                    • 38
                    has anybody found a solution?
                    very interested in this.
                    • coreychristian
                      • Jun 2012
                      • 159
                      Right now you have to do either or. I thought I read somewhere that they were going to give the option for multiple macro's on discovery in a future release, not sure if that will be 2.4 or not though.
                      The only other option really right now, that I am aware of, would be to write a custom disk discovery script and have the filters in the script.
