Complieing 1.1 on SLES9 x86_64
  • sbadger
    • Dec 2005
    • 81
    I have been trying to compile on a SLES 9 sp3 x86_64 for a new installation, but I continue to get the following error for the server configuration. Please let me know what I am missing.
    Here is the output from the make script:
    make[3]: Entering directory `/zabbix/sources/zabbix-1.1/src/zabbix_server'
    gcc -g -O2 -o zabbix_server -L/usr/lib/mysql -L/usr/lib evalfunc.o expression.o actions.o zlog.o functions.o server.o ../libs/zbxsysinfo/libzbxsysinfo.a ../libs/zbxsysinfo/linux/libzbxsysinfo2.a ../libs/zbxlog/libzbxlog.a ../libs/zbxpid/libzbxpid.a ../libs/zbxconf/libzbxconf.a ../libs/zbxcrypto/libzbxcrypto.a ../libs/zbxnet/libzbxnet.a pinger/libzbxpinger.a poller/libzbxpoller.a housekeeper/libzbxhousekeeper.a alerter/libzbxalerter.a timer/libzbxtimer.a trapper/libzbxtrapper.a ../libs/zbxemail/libzbxemail.a ../libs/zbxsms/libzbxsms.a ../libs/zbxdbhigh/libzbxdbhigh.a ../libs/zbxcommon/libzbxcommon.a -lmysqlclient -lm -lz -lnetsnmp -lresolv -lnsl
    /usr/lib64/gcc-lib/x86_64-suse-linux/3.3.3/../../../../x86_64-suse-linux/bin/ld: skipping incompatible /usr/lib/libm.so when searching for -lm
    /usr/lib64/gcc-lib/x86_64-suse-linux/3.3.3/../../../../x86_64-suse-linux/bin/ld: skipping incompatible /usr/lib/libm.a when searching for -lm
    /usr/lib64/gcc-lib/x86_64-suse-linux/3.3.3/../../../../x86_64-suse-linux/bin/ld: skipping incompatible /usr/lib/libz.so when searching for -lz
    /usr/lib64/gcc-lib/x86_64-suse-linux/3.3.3/../../../../x86_64-suse-linux/bin/ld: skipping incompatible /usr/lib/libz.a when searching for -lz
    /usr/lib64/gcc-lib/x86_64-suse-linux/3.3.3/../../../../x86_64-suse-linux/bin/ld: skipping incompatible /usr/lib/libresolv.so when searching for -lresolv
    /usr/lib64/gcc-lib/x86_64-suse-linux/3.3.3/../../../../x86_64-suse-linux/bin/ld: skipping incompatible /usr/lib/libresolv.a when searching for -lresolv
    /usr/lib64/gcc-lib/x86_64-suse-linux/3.3.3/../../../../x86_64-suse-linux/bin/ld: skipping incompatible /usr/lib/libnsl.so when searching for -lnsl
    /usr/lib64/gcc-lib/x86_64-suse-linux/3.3.3/../../../../x86_64-suse-linux/bin/ld: skipping incompatible /usr/lib/libnsl.a when searching for -lnsl
    /usr/lib64/gcc-lib/x86_64-suse-linux/3.3.3/../../../../x86_64-suse-linux/bin/ld: skipping incompatible /usr/lib/libc.so when searching for -lc
    /usr/lib64/gcc-lib/x86_64-suse-linux/3.3.3/../../../../x86_64-suse-linux/bin/ld: skipping incompatible /usr/lib/libc.a when searching for -lc
    /usr/lib64/gcc-lib/x86_64-suse-linux/3.3.3/../../../../lib64/libnetsnmp.so: undefined reference to `EVP_DigestInit'
    /usr/lib64/gcc-lib/x86_64-suse-linux/3.3.3/../../../../lib64/libnetsnmp.so: undefined reference to `EVP_DigestFinal'
    /usr/lib64/gcc-lib/x86_64-suse-linux/3.3.3/../../../../lib64/libnetsnmp.so: undefined reference to `EVP_DigestFinal_ex'/usr/lib64/gcc-lib/x86_64-suse-linux/3.3.3/../../../../lib64/libnetsnmp.so: undefined reference to `AES_set_encrypt_key'
    /usr/lib64/gcc-lib/x86_64-suse-linux/3.3.3/../../../../lib64/libnetsnmp.so: undefined reference to `EVP_md5'
    /usr/lib64/gcc-lib/x86_64-suse-linux/3.3.3/../../../../lib64/libnetsnmp.so: undefined reference to `HMAC'
    /usr/lib64/gcc-lib/x86_64-suse-linux/3.3.3/../../../../lib64/libnetsnmp.so: undefined reference to `EVP_MD_CTX_cleanup'/usr/lib64/gcc-lib/x86_64-suse-linux/3.3.3/../../../../lib64/libnetsnmp.so: undefined reference to `SSLeay'
    /usr/lib64/gcc-lib/x86_64-suse-linux/3.3.3/../../../../lib64/libnetsnmp.so: undefined reference to `EVP_sha1'
    /usr/lib64/gcc-lib/x86_64-suse-linux/3.3.3/../../../../lib64/libnetsnmp.so: undefined reference to `EVP_MD_CTX_init'
    /usr/lib64/gcc-lib/x86_64-suse-linux/3.3.3/../../../../lib64/libnetsnmp.so: undefined reference to `EVP_DigestUpdate'
    /usr/lib64/gcc-lib/x86_64-suse-linux/3.3.3/../../../../lib64/libnetsnmp.so: undefined reference to `RAND_bytes'
    /usr/lib64/gcc-lib/x86_64-suse-linux/3.3.3/../../../../lib64/libnetsnmp.so: undefined reference to `DES_cbc_encrypt'
    /usr/lib64/gcc-lib/x86_64-suse-linux/3.3.3/../../../../lib64/libnetsnmp.so: undefined reference to `DES_ncbc_encrypt'
    /usr/lib64/gcc-lib/x86_64-suse-linux/3.3.3/../../../../lib64/libnetsnmp.so: undefined reference to `DES_key_sched'
    /usr/lib64/gcc-lib/x86_64-suse-linux/3.3.3/../../../../lib64/libnetsnmp.so: undefined reference to `AES_cfb128_encrypt'collect2: ld returned 1 exit status
    make[3]: *** [zabbix_server] Error 1
    make[3]: Leaving directory `/zabbix/sources/zabbix-1.1/src/zabbix_server'
    make[2]: *** [all-recursive] Error 1
    make[2]: Leaving directory `/zabbix/sources/zabbix-1.1/src/zabbix_server'
    make[1]: *** [all-recursive] Error 1
    make[1]: Leaving directory `/zabbix/sources/zabbix-1.1/src'
    make: *** [all-recursive] Error 1
  • sbadger
    • Dec 2005
    • 81
    Solved
    I found the solution with the help of this tread:
    I also needed to install the openssl dev packages as well.
