Hi everyone,
i have installed the newest zabbix-server 2.2.0 and tryed out the "new" feature database monitoring. But everytime i enable a database monitoring item type the zabbix-server "crash". He don't stop running but he didn't gather any values anymore.
I installed unixodbc driver manager 2.3.2 and connector-odbc 5.1.12.
The test with isql worked fine for the localhost.
Then i compiled the new zabbix.
The output told me he accepted odbc and
returned no error.
I added a host and two items. One for database monitoring and one simple agent ping with a normal zabbix agent.
Collecting data from the agent.ping is no problem, but everytime i enable the database monitoring item i get following crash report:
So it seems like the call of the odbc connector or whatever throws a segmetion fault for any reason.
Has somebody an idea?
Trickels
Edit:
On Ubuntu 12.04 LTS server 64bit
./configure --enable-server --enable-agent --with-mysql --with-net-snmp --with-libcurl --with-jabber –with-libxml2 –with-unixodbc make install
ldd /usr/local/sbin/zabbix_server
16307:20131126:154621.172 In substitute_key_macros() data:'db.odbc.select[itemcount2,mysql-test]' 16307:20131126:154621.172 End of substitute_key_macros():SUCCEED data:'db.odbc.select[itemcount2,mysql-test]' 16307:20131126:154621.172 In substitute_simple_macros() data:'select hostid from items where itemdid=10009;' 16307:20131126:154621.172 In substitute_simple_macros() data:EMPTY 16307:20131126:154621.172 In substitute_simple_macros() data:EMPTY 16307:20131126:154621.172 In get_value() key:'db.odbc.select[itemcount2,mysql-test]' 16307:20131126:154621.172 In get_value_db() key_orig:'db.odbc.select[itemcount2,mysql-test]' 16307:20131126:154621.172 In odbc_DBconnect() db_dsn:'mysql-test' user:'' 16307:20131126:154621.195 Got signal [signal:11(SIGSEGV),reason:1,refaddr:0x7fff8508e853]. Crashing ... 16307:20131126:154621.195 ====== Fatal information: ====== 16307:20131126:154621.195 Program counter: 0x7f248602f4d7 16307:20131126:154621.195 === Registers: === 16307:20131126:154621.195 r8 = a = 10 = 10 16307:20131126:154621.195 r9 = 7f24864b5080 = 139794848632960 = 139794848632960 16307:20131126:154621.195 r10 = 130a = 4874 = 4874 16307:20131126:154621.195 r11 = 7fff83de6f24 = 140735405780772 = 140735405780772 16307:20131126:154621.195 r12 = fffffffd = 4294967293 = 4294967293 16307:20131126:154621.195 r13 = a = 10 = 10 16307:20131126:154621.195 r14 = 7f24864c4380 = 139794848695168 = 139794848695168 16307:20131126:154621.195 r15 = 7f24864c5c60 = 139794848701536 = 139794848701536 16307:20131126:154621.195 rdi = 7f24864c5c60 = 139794848701536 = 139794848701536 16307:20131126:154621.195 rsi = 7fff83de5cc4 = 140735405776068 = 140735405776068 16307:20131126:154621.195 rbp = 12a959b = 19568027 = 19568027 16307:20131126:154621.195 rbx = 7fff83de5cc4 = 140735405776068 = 140735405776068 16307:20131126:154621.195 rdx = 7fff8508e854 = 140735425341524 = 140735425341524 16307:20131126:154621.196 rax = 7f248602f4b0 = 139794843890864 = 139794843890864 16307:20131126:154621.196 rcx = 12a959b = 19568027 = 19568027 16307:20131126:154621.196 rsp = 7fff83de5b90 = 140735405775760 = 140735405775760 16307:20131126:154621.196 rip = 7f248602f4d7 = 139794843890903 = 139794843890903 16307:20131126:154621.196 efl = 10283 = 66179 = 66179 16307:20131126:154621.196 csgsfs = 33 = 51 = 51 16307:20131126:154621.196 err = 4 = 4 = 4 16307:20131126:154621.196 trapno = e = 14 = 14 16307:20131126:154621.196 oldmask = 0 = 0 = 0 16307:20131126:154621.196 cr2 = 7fff8508e853 = 140735425341523 = 140735425341523 16307:20131126:154621.196 === Backtrace: === 16307:20131126:154621.197 15: /usr/local/sbin/zabbix_server: poller #1 [got 0 values in 0.000219 sec, getting values](print_fatal_info+0xae) [0x45bd8e] 16307:20131126:154621.197 14: /usr/local/sbin/zabbix_server: poller #1 [got 0 values in 0.000219 sec, getting values]() [0x45c1b1] 16307:20131126:154621.197 13: /lib/x86_64-linux-gnu/libc.so.6(+0x364a0) [0x7f24846424a0] 16307:20131126:154621.197 12: /usr/lib/x86_64-linux-gnu/libmysqlclient.so.18(+0x3f4d7) [0x7f248602f4d7] 16307:20131126:154621.197 11: /usr/lib/odbc/libmyodbc5.so(copy_and_convert+0x108) [0x7f2477ae4992] 16307:20131126:154621.197 10: /usr/lib/odbc/libmyodbc5.so(sqlchar_as_sqlwchar+0x1ee) [0x7f2477ae4106] 16307:20131126:154621.197 9: /usr/lib/odbc/libmyodbc5.so(SQLConnect+0x63) [0x7f2477a2669f] 16307:20131126:154621.197 8: /usr/lib/libodbc.so.2(SQLConnect+0x20a) [0x7f24855cb04a] 16307:20131126:154621.197 7: /usr/local/sbin/zabbix_server: poller #1 [got 0 values in 0.000219 sec, getting values](odbc_DBconnect+0x120) [0x48bd70] 16307:20131126:154621.197 6: /usr/local/sbin/zabbix_server: poller #1 [got 0 values in 0.000219 sec, getting values](get_value_db+0x94) [0x423a24] 16307:20131126:154621.197 5: /usr/local/sbin/zabbix_server: poller #1 [got 0 values in 0.000219 sec, getting values]() [0x41e8db] 16307:20131126:154621.197 4: /usr/local/sbin/zabbix_server: poller #1 [got 0 values in 0.000219 sec, getting values](main_poller_loop+0x83) [0x41ea93] 16307:20131126:154621.197 3: /usr/local/sbin/zabbix_server: poller #1 [got 0 values in 0.000219 sec, getting values](MAIN_ZABBIX_ENTRY+0x682) [0x416af2] 16307:20131126:154621.197 2: /usr/local/sbin/zabbix_server: poller #1 [got 0 values in 0.000219 sec, getting values](daemon_start+0x1b2) [0x45b642] 16307:20131126:154621.197 1: /lib/x86_64-linux-gnu/libc.so.6(__libc_start_main+0xed) [0x7f248462d76d] 16307:20131126:154621.197 0: /usr/local/sbin/zabbix_server: poller #1 [got 0 values in 0.000219 sec, getting values]() [0x411dfd] 16307:20131126:154621.197 === Memory map: === 16307:20131126:154621.197 00400000-00543000 r-xp 00000000 fc:00 159488 /usr/local/sbin/zabbix_server 16307:20131126:154621.197 00742000-00743000 r--p 00142000 fc:00 159488 /usr/local/sbin/zabbix_server 16307:20131126:154621.197 00743000-00747000 rw-p 00143000 fc:00 159488 /usr/local/sbin/zabbix_server 16307:20131126:154621.197 00747000-0074d000 rw-p 00000000 00:00 0 16307:20131126:154621.197 01263000-01284000 rw-p 00000000 00:00 0 [heap] 16307:20131126:154621.197 01284000-012c7000 rw-p 00000000 00:00 0 [heap] 16307:20131126:154621.197 7f2477259000-7f247733b000 r-xp 00000000 fc:00 136606 /usr/lib/x86_64-linux-gnu/libstdc++.so.6.0.16 16307:20131126:154621.197 7f247733b000-7f247753a000 ---p 000e2000 fc:00 136606 /usr/lib/x86_64-linux-gnu/libstdc++.so.6.0.16 16307:20131126:154621.197 7f247753a000-7f2477542000 r--p 000e1000 fc:00 136606 /usr/lib/x86_64-linux-gnu/libstdc++.so.6.0.16 16307:20131126:154621.197 7f2477542000-7f2477544000 rw-p 000e9000 fc:00 136606 /usr/lib/x86_64-linux-gnu/libstdc++.so.6.0.16 16307:20131126:154621.197 7f2477544000-7f2477559000 rw-p 00000000 00:00 0 16307:20131126:154621.198 7f2477559000-7f247756f000 r-xp 00000000 fc:00 283114 /lib64/libodbcinst.so.1.0.0 16307:20131126:154621.198 7f247756f000-7f247776f000 ---p 00016000 fc:00 283114 /lib64/libodbcinst.so.1.0.0 16307:20131126:154621.198 7f247776f000-7f2477770000 r--p 00016000 fc:00 283114 /lib64/libodbcinst.so.1.0.0 16307:20131126:154621.198 7f2477770000-7f2477771000 rw-p 00017000 fc:00 283114 /lib64/libodbcinst.so.1.0.0 16307:20131126:154621.198 7f2477771000-7f24777d8000 r-xp 00000000 fc:00 283116 /lib64/libodbc.so.1.0.0 16307:20131126:154621.198 7f24777d8000-7f24779d7000 ---p 00067000 fc:00 283116 /lib64/libodbc.so.1.0.0 16307:20131126:154621.198 7f24779d7000-7f24779d8000 r--p 00066000 fc:00 283116 /lib64/libodbc.so.1.0.0 16307:20131126:154621.198 7f24779d8000-7f24779df000 rw-p 00067000 fc:00 283116 /lib64/libodbc.so.1.0.0 16307:20131126:154621.198 7f24779df000-7f24779e0000 rw-p 00000000 00:00 0 16307:20131126:154621.198 7f24779e0000-7f2477d1b000 r-xp 00000000 fc:00 153558 /usr/lib/odbc/libmyodbc5.so 16307:20131126:154621.198 7f2477d1b000-7f2477f1a000 ---p 0033b000 fc:00 153558 /usr/lib/odbc/libmyodbc5.so 16307:20131126:154621.198 7f2477f1a000-7f2477ffb000 rw-p 0033a000 fc:00 153558 /usr/lib/odbc/libmyodbc5.so 16307:20131126:154621.198 7f2477ffb000-7f2478000000 rw-p 00000000 00:00 0 16307:20131126:154621.198 7f2478000000-7f2478021000 rw-p 00000000 00:00 0 16307:20131126:154621.198 7f2478021000-7f247c000000 ---p 00000000 00:00 0 16307:20131126:154621.198 7f247c203000-7f247c218000 r-xp 00000000 fc:00 261722 /lib/x86_64-linux-gnu/libgcc_s.so.1 16307:20131126:154621.198 7f247c218000-7f247c417000 ---p 00015000 fc:00 261722 /lib/x86_64-linux-gnu/libgcc_s.so.1 16307:20131126:154621.198 7f247c417000-7f247c418000 r--p 00014000 fc:00 261722 /lib/x86_64-linux-gnu/libgcc_s.so.1 16307:20131126:154621.198 7f247c418000-7f247c419000 rw-p 00015000 fc:00 261722 /lib/x86_64-linux-gnu/libgcc_s.so.1 16307:20131126:154621.198 7f247c419000-7f247c41a000 ---p 00000000 00:00 0 16307:20131126:154621.198 7f247c41a000-7f247cc1a000 rw-p 00000000 00:00 0 16307:20131126:154621.198 7f247cc1a000-7f247d41a000 rw-s 00000000 00:04 40534023 /SYSV76007292 (deleted) 16307:20131126:154621.198 7f247d41a000-7f247dae7000 rw-s 00000000 00:04 40435716 /SYSV67007292 (deleted) 16307:20131126:154621.198 7f247dae7000-7f247dee7000 rw-s 00000000 00:04 40402947 /SYSV74007292 (deleted) 16307:20131126:154621.198 7f247dee7000-7f247eee7000 rw-s 00000000 00:04 40370178 /SYSV78007292 (deleted) 16307:20131126:154621.198 7f247eee7000-7f247f6e7000 rw-s 00000000 00:04 40337409 /SYSV68007292 (deleted) 16307:20131126:154621.198 7f247f6e7000-7f247f6f3000 r-xp 00000000 fc:00 261708 /lib/x86_64-linux-gnu/libnss_files-2.15.so 16307:20131126:154621.198 7f247f6f3000-7f247f8f2000 ---p 0000c000 fc:00 261708 /lib/x86_64-linux-gnu/libnss_files-2.15.so 16307:20131126:154621.198 7f247f8f2000-7f247f8f3000 r--p 0000b000 fc:00 261708 /lib/x86_64-linux-gnu/libnss_files-2.15.so 16307:20131126:154621.198 7f247f8f3000-7f247f8f4000 rw-p 0000c000 fc:00 261708 /lib/x86_64-linux-gnu/libnss_files-2.15.so 16307:20131126:154621.198 7f247f8f4000-7f247f8fe000 r-xp 00000000 fc:00 261704 /lib/x86_64-linux-gnu/libnss_nis-2.15.so 16307:20131126:154621.199 7f247f8fe000-7f247fafe000 ---p 0000a000 fc:00 261704 /lib/x86_64-linux-gnu/libnss_nis-2.15.so 16307:20131126:154621.199 7f247fafe000-7f247faff000 r--p 0000a000 fc:00 261704 /lib/x86_64-linux-gnu/libnss_nis-2.15.so 16307:20131126:154621.199 7f247faff000-7f247fb00000 rw-p 0000b000 fc:00 261704 /lib/x86_64-linux-gnu/libnss_nis-2.15.so 16307:20131126:154621.199 7f247fb00000-7f247fb17000 r-xp 00000000 fc:00 261717 /lib/x86_64-linux-gnu/libnsl-2.15.so 16307:20131126:154621.199 7f247fb17000-7f247fd16000 ---p 00017000 fc:00 261717 /lib/x86_64-linux-gnu/libnsl-2.15.so 16307:20131126:154621.199 7f247fd16000-7f247fd17000 r--p 00016000 fc:00 261717 /lib/x86_64-linux-gnu/libnsl-2.15.so 16307:20131126:154621.199 7f247fd17000-7f247fd18000 rw-p 00017000 fc:00 261717 /lib/x86_64-linux-gnu/libnsl-2.15.so 16307:20131126:154621.199 7f247fd18000-7f247fd1a000 rw-p 00000000 00:00 0 16307:20131126:154621.199 7f247fd1a000-7f247fd22000 r-xp 00000000 fc:00 261709 /lib/x86_64-linux-gnu/libnss_compat-2.15.so 16307:20131126:154621.199 7f247fd22000-7f247ff21000 ---p 00008000 fc:00 261709 /lib/x86_64-linux-gnu/libnss_compat-2.15.so 16307:20131126:154621.199 7f247ff21000-7f247ff22000 r--p 00007000 fc:00 261709 /lib/x86_64-linux-gnu/libnss_compat-2.15.so 16307:20131126:154621.199 7f247ff22000-7f247ff23000 rw-p 00008000 fc:00 261709 /lib/x86_64-linux-gnu/libnss_compat-2.15.so 16307:20131126:154621.199 7f247ff23000-7f247ff2c000 r-xp 00000000 fc:00 261707 /lib/x86_64-linux-gnu/libcrypt-2.15.so 16307:20131126:154621.199 7f247ff2c000-7f248012c000 ---p 00009000 fc:00 261707 /lib/x86_64-linux-gnu/libcrypt-2.15.so 16307:20131126:154621.199 7f248012c000-7f248012d000 r--p 00009000 fc:00 261707 /lib/x86_64-linux-gnu/libcrypt-2.15.so 16307:20131126:154621.199 7f248012d000-7f248012e000 rw-p 0000a000 fc:00 261707 /lib/x86_64-linux-gnu/libcrypt-2.15.so 16307:20131126:154621.199 7f248012e000-7f248015c000 rw-p 00000000 00:00 0 16307:20131126:154621.199 7f248015c000-7f24801fa000 r-xp 00000000 fc:00 136760 /usr/lib/x86_64-linux-gnu/libsqlite3.so.0.8.6 16307:20131126:154621.199 7f24801fa000-7f24803fa000 ---p 0009e000 fc:00 136760 /usr/lib/x86_64-linux-gnu/libsqlite3.so.0.8.6 16307:20131126:154621.199 7f24803fa000-7f24803fc000 r--p 0009e000 fc:00 136760 /usr/lib/x86_64-linux-gnu/libsqlite3.so.0.8.6 16307:20131126:154621.199 7f24803fc000-7f24803fe000 rw-p 000a0000 fc:00 136760 /usr/lib/x86_64-linux-gnu/libsqlite3.so.0.8.6 16307:20131126:154621.199 7f24803fe000-7f24803ff000 rw-p 00000000 00:00 0 16307:20131126:154621.199 7f24803ff000-7f2480444000 r-xp 00000000 fc:00 149608 /usr/lib/x86_64-linux-gnu/libhx509.so.5.0.0 16307:20131126:154621.199 7f2480444000-7f2480644000 ---p 00045000 fc:00 149608 /usr/lib/x86_64-linux-gnu/libhx509.so.5.0.0 16307:20131126:154621.199 7f2480644000-7f2480646000 r--p 00045000 fc:00 149608 /usr/lib/x86_64-linux-gnu/libhx509.so.5.0.0 16307:20131126:154621.199 7f2480646000-7f2480648000 rw-p 00047000 fc:00 149608 /usr/lib/x86_64-linux-gnu/libhx509.so.5.0.0 16307:20131126:154621.199 7f2480648000-7f2480649000 rw-p 00000000 00:00 0 16307:20131126:154621.199 7f2480649000-7f2480657000 r-xp 00000000 fc:00 149602 /usr/lib/x86_64-linux-gnu/libheimbase.so.1.0.0 16307:20131126:154621.199 7f2480657000-7f2480856000 ---p 0000e000 fc:00 149602 /usr/lib/x86_64-linux-gnu/libheimbase.so.1.0.0 16307:20131126:154621.199 7f2480856000-7f2480857000 r--p 0000d000 fc:00 149602 /usr/lib/x86_64-linux-gnu/libheimbase.so.1.0.0 16307:20131126:154621.200 7f2480857000-7f2480858000 rw-p 0000e000 fc:00 149602 /usr/lib/x86_64-linux-gnu/libheimbase.so.1.0.0 16307:20131126:154621.200 7f2480858000-7f2480880000 r-xp 00000000 fc:00 149605 /usr/lib/x86_64-linux-gnu/libwind.so.0.0.0 16307:20131126:154621.200 7f2480880000-7f2480a7f000 ---p 00028000 fc:00 149605 /usr/lib/x86_64-linux-gnu/libwind.so.0.0.0 16307:20131126:154621.200 7f2480a7f000-7f2480a80000 r--p 00027000 fc:00 149605 /usr/lib/x86_64-linux-gnu/libwind.so.0.0.0 16307:20131126:154621.200 7f2480a80000-7f2480a81000 rw-p 00028000 fc:00 149605 /usr/lib/x86_64-linux-gnu/libwind.so.0.0.0 16307:20131126:154621.200 7f2480a81000-7f2480a84000 r-xp 00000000 fc:00 276126 /lib/x86_64-linux-gnu/libkeyutils.so.1.4 16307:20131126:154621.200 7f2480a84000-7f2480c83000 ---p 00003000 fc:00 276126 /lib/x86_64-linux-gnu/libkeyutils.so.1.4 16307:20131126:154621.200 7f2480c83000-7f2480c84000 r--p 00002000 fc:00 276126 /lib/x86_64-linux-gnu/libkeyutils.so.1.4 16307:20131126:154621.200 7f2480c84000-7f2480c85000 rw-p 00003000 fc:00 276126 /lib/x86_64-linux-gnu/libkeyutils.so.1.4 16307:20131126:154621.200 7f2480c85000-7f2480c99000 r-xp 00000000 fc:00 149571 /usr/lib/x86_64-linux-gnu/libroken.so.18.1.0 16307:20131126:154621.200 7f2480c99000-7f2480e98000 ---p 00014000 fc:00 149571 /usr/lib/x86_64-linux-gnu/libroken.so.18.1.0 16307:20131126:154621.200 7f2480e98000-7f2480e99000 r--p 00013000 fc:00 149571 /usr/lib/x86_64-linux-gnu/libroken.so.18.1.0 16307:20131126:154621.200 7f2480e99000-7f2480e9a000 rw-p 00014000 fc:00 149571 /usr/lib/x86_64-linux-gnu/libroken.so.18.1.0 16307:20131126:154621.200 7f2480e9a000-7f2480ecb000 r-xp 00000000 fc:00 149599 /usr/lib/x86_64-linux-gnu/libhcrypto.so.4.1.0 16307:20131126:154621.200 7f2480ecb000-7f24810cb000 ---p 00031000 fc:00 149599 /usr/lib/x86_64-linux-gnu/libhcrypto.so.4.1.0 16307:20131126:154621.200 7f24810cb000-7f24810cc000 r--p 00031000 fc:00 149599 /usr/lib/x86_64-linux-gnu/libhcrypto.so.4.1.0 16307:20131126:154621.200 7f24810cc000-7f24810cd000 rw-p 00032000 fc:00 149599 /usr/lib/x86_64-linux-gnu/libhcrypto.so.4.1.0 16307:20131126:154621.200 7f24810cd000-7f24810ce000 rw-p 00000000 00:00 0 16307:20131126:154621.200 7f24810ce000-7f2481169000 r-xp 00000000 fc:00 149574 /usr/lib/x86_64-linux-gnu/libasn1.so.8.0.0 16307:20131126:154621.200 7f2481169000-7f2481368000 ---p 0009b000 fc:00 149574 /usr/lib/x86_64-linux-gnu/libasn1.so.8.0.0 16307:20131126:154621.200 7f2481368000-7f248136a000 r--p 0009a000 fc:00 149574 /usr/lib/x86_64-linux-gnu/libasn1.so.8.0.0 16307:20131126:154621.200 7f248136a000-7f248136e000 rw-p 0009c000 fc:00 149574 /usr/lib/x86_64-linux-gnu/libasn1.so.8.0.0 16307:20131126:154621.200 7f248136e000-7f24813ee000 r-xp 00000000 fc:00 149611 /usr/lib/x86_64-linux-gnu/libkrb5.so.26.0.0 16307:20131126:154621.200 7f24813ee000-7f24815ee000 ---p 00080000 fc:00 149611 /usr/lib/x86_64-linux-gnu/libkrb5.so.26.0.0 16307:20131126:154621.200 7f24815ee000-7f24815f0000 r--p 00080000 fc:00 149611 /usr/lib/x86_64-linux-gnu/libkrb5.so.26.0.0 16307:20131126:154621.200 7f24815f0000-7f24815f4000 rw-p 00082000 fc:00 149611 /usr/lib/x86_64-linux-gnu/libkrb5.so.26.0.0 16307:20131126:154621.200 7f24815f4000-7f24815fa000 r-xp 00000000 fc:00 149614 /usr/lib/x86_64-linux-gnu/libheimntlm.so.0.1.0 16307:20131126:154621.200 7f24815fa000-7f24817f9000 ---p 00006000 fc:00 149614 /usr/lib/x86_64-linux-gnu/libheimntlm.so.0.1.0 16307:20131126:154621.200 7f24817f9000-7f24817fa000 r--p 00005000 fc:00 149614 /usr/lib/x86_64-linux-gnu/libheimntlm.so.0.1.0 16307:20131126:154621.200 7f24817fa000-7f24817fb000 rw-p 00006000 fc:00 149614 /usr/lib/x86_64-linux-gnu/libheimntlm.so.0.1.0 16307:20131126:154621.200 7f24817fb000-7f24817fe000 r-xp 00000000 fc:00 276122 /lib/x86_64-linux-gnu/libgpg-error.so.0.8.0 16307:20131126:154621.200 7f24817fe000-7f24819fd000 ---p 00003000 fc:00 276122 /lib/x86_64-linux-gnu/libgpg-error.so.0.8.0 16307:20131126:154621.200 7f24819fd000-7f24819fe000 r--p 00002000 fc:00 276122 /lib/x86_64-linux-gnu/libgpg-error.so.0.8.0 16307:20131126:154621.200 7f24819fe000-7f24819ff000 rw-p 00003000 fc:00 276122 /lib/x86_64-linux-gnu/libgpg-error.so.0.8.0 16307:20131126:154621.201 7f24819ff000-7f2481a06000 r-xp 00000000 fc:00 149585 /usr/lib/x86_64-linux-gnu/libkrb5support.so.0.1 16307:20131126:154621.201 7f2481a06000-7f2481c05000 ---p 00007000 fc:00 149585 /usr/lib/x86_64-linux-gnu/libkrb5support.so.0.1 16307:20131126:154621.201 7f2481c05000-7f2481c06000 r--p 00006000 fc:00 149585 /usr/lib/x86_64-linux-gnu/libkrb5support.so.0.1 16307:20131126:154621.201 7f2481c06000-7f2481c07000 rw-p 00007000 fc:00 149585 /usr/lib/x86_64-linux-gnu/libkrb5support.so.0.1 16307:20131126:154621.201 7f2481c07000-7f2481c0a000 r-xp 00000000 fc:00 261684 /lib/x86_64-linux-gnu/libcom_err.so.2.1 16307:20131126:154621.201 7f2481c0a000-7f2481e09000 ---p 00003000 fc:00 261684 /lib/x86_64-linux-gnu/libcom_err.so.2.1 16307:20131126:154621.201 7f2481e09000-7f2481e0a000 r--p 00002000 fc:00 261684 /lib/x86_64-linux-gnu/libcom_err.so.2.1 16307:20131126:154621.201 7f2481e0a000-7f2481e0b000 rw-p 00003000 fc:00 261684 /lib/x86_64-linux-gnu/libcom_err.so.2.1 16307:20131126:154621.201 7f2481e0b000-7f2481e30000 r-xp 00000000 fc:00 149587 /usr/lib/x86_64-linux-gnu/libk5crypto.so.3.1 16307:20131126:154621.201 7f2481e30000-7f2482030000 ---p 00025000 fc:00 149587 /usr/lib/x86_64-linux-gnu/libk5crypto.so.3.1 16307:20131126:154621.201 7f2482030000-7f2482031000 r--p 00025000 fc:00 149587 /usr/lib/x86_64-linux-gnu/libk5crypto.so.3.1 16307:20131126:154621.201 7f2482031000-7f2482032000 rw-p 00026000 fc:00 149587 /usr/lib/x86_64-linux-gnu/libk5crypto.so.3.1 16307:20131126:154621.201 7f2482032000-7f2482033000 rw-p 00000000 00:00 0 16307:20131126:154621.201 7f2482033000-7f24820f7000 r-xp 00000000 fc:00 149593 /usr/lib/x86_64-linux-gnu/libkrb5.so.3.3 16307:20131126:154621.201 7f24820f7000-7f24822f6000 ---p 000c4000 fc:00 149593 /usr/lib/x86_64-linux-gnu/libkrb5.so.3.3 16307:20131126:154621.201 7f24822f6000-7f2482300000 r--p 000c3000 fc:00 149593 /usr/lib/x86_64-linux-gnu/libkrb5.so.3.3 16307:20131126:154621.201 7f2482300000-7f2482301000 rw-p 000cd000 fc:00 149593 /usr/lib/x86_64-linux-gnu/libkrb5.so.3.3 16307:20131126:154621.201 7f2482301000-7f248233b000 r-xp 00000000 fc:00 149617 /usr/lib/x86_64-linux-gnu/libgssapi.so.3.0.0 16307:20131126:154621.201 7f248233b000-7f248253b000 ---p 0003a000 fc:00 149617 /usr/lib/x86_64-linux-gnu/libgssapi.so.3.0.0 16307:20131126:154621.201 7f248253b000-7f248253c000 r--p 0003a000 fc:00 149617 /usr/lib/x86_64-linux-gnu/libgssapi.so.3.0.0 16307:20131126:154621.201 7f248253c000-7f248253f000 rw-p 0003b000 fc:00 149617 /usr/lib/x86_64-linux-gnu/libgssapi.so.3.0.0 16307:20131126:154621.201 7f248253f000-7f2482559000 r-xp 00000000 fc:00 149622 /usr/lib/x86_64-linux-gnu/libsasl2.so.2.0.25 16307:20131126:154621.201 7f2482559000-7f2482758000 ---p 0001a000 fc:00 149622 /usr/lib/x86_64-linux-gnu/libsasl2.so.2.0.25 16307:20131126:154621.201 7f2482758000-7f2482759000 r--p 00019000 fc:00 149622 /usr/lib/x86_64-linux-gnu/libsasl2.so.2.0.25 16307:20131126:154621.201 7f2482759000-7f248275a000 rw-p 0001a000 fc:00 149622 /usr/lib/x86_64-linux-gnu/libsasl2.so.2.0.25 16307:20131126:154621.201 7f248275a000-7f248276b000 r-xp 00000000 fc:00 149577 /usr/lib/x86_64-linux-gnu/libp11-kit.so.0.0.0 16307:20131126:154621.201 7f248276b000-7f248296a000 ---p 00011000 fc:00 149577 /usr/lib/x86_64-linux-gnu/libp11-kit.so.0.0.0 16307:20131126:154621.201 7f248296a000-7f248296b000 r--p 00010000 fc:00 149577 /usr/lib/x86_64-linux-gnu/libp11-kit.so.0.0.0 16307:20131126:154621.201 7f248296b000-7f248296c000 rw-p 00011000 fc:00 149577 /usr/lib/x86_64-linux-gnu/libp11-kit.so.0.0.0 16307:20131126:154621.201 7f248296c000-7f24829e6000 r-xp 00000000 fc:00 276124 /lib/x86_64-linux-gnu/libgcrypt.so.11.7.0 16307:20131126:154621.202 7f24829e6000-7f2482be6000 ---p 0007a000 fc:00 276124 /lib/x86_64-linux-gnu/libgcrypt.so.11.7.0 16307:20131126:154621.202 7f2482be6000-7f2482be7000 r--p 0007a000 fc:00 276124 /lib/x86_64-linux-gnu/libgcrypt.so.11.7.0 16307:20131126:154621.202 7f2482be7000-7f2482bea000 rw-p 0007b000 fc:00 276124 /lib/x86_64-linux-gnu/libgcrypt.so.11.7.0 16307:20131126:154621.202 7f2482bea000-7f2482bfa000 r-xp 00000000 fc:00 149579 /usr/lib/x86_64-linux-gnu/libtasn1.so.3.1.12 16307:20131126:154621.202 7f2482bfa000-7f2482df9000 ---p 00010000 fc:00 149579 /usr/lib/x86_64-linux-gnu/libtasn1.so.3.1.12 16307:20131126:154621.202 7f2482df9000-7f2482dfa000 r--p 0000f000 fc:00 149579 /usr/lib/x86_64-linux-gnu/libtasn1.so.3.1.12 16307:20131126:154621.202 7f2482dfa000-7f2482dfb000 rw-p 00010000 fc:00 149579 /usr/lib/x86_64-linux-gnu/libtasn1.so.3.1.12 16307:20131126:154621.202 7f2482dfb000-7f2482e13000 r-xp 00000000 fc:00 149633 /usr/lib/x86_64-linux-gnu/librtmp.so.0 16307:20131126:154621.202 7f2482e13000-7f2483013000 ---p 00018000 fc:00 149633 /usr/lib/x86_64-linux-gnu/librtmp.so.0 16307:20131126:154621.202 7f2483013000-7f2483014000 r--p 00018000 fc:00 149633 /usr/lib/x86_64-linux-gnu/librtmp.so.0 16307:20131126:154621.202 7f2483014000-7f2483015000 rw-p 00019000 fc:00 149633 /usr/lib/x86_64-linux-gnu/librtmp.so.0 16307:20131126:154621.202 7f2483015000-7f24831c6000 r-xp 00000000 fc:00 261799 /lib/x86_64-linux-gnu/libcrypto.so.1.0.0 16307:20131126:154621.202 7f24831c6000-7f24833c6000 ---p 001b1000 fc:00 261799 /lib/x86_64-linux-gnu/libcrypto.so.1.0.0 16307:20131126:154621.202 7f24833c6000-7f24833e1000 r--p 001b1000 fc:00 261799 /lib/x86_64-linux-gnu/libcrypto.so.1.0.0 16307:20131126:154621.202 7f24833e1000-7f24833ec000 rw-p 001cc000 fc:00 261799 /lib/x86_64-linux-gnu/libcrypto.so.1.0.0 16307:20131126:154621.202 7f24833ec000-7f24833f0000 rw-p 00000000 00:00 0 16307:20131126:154621.202 7f24833f0000-7f2483444000 r-xp 00000000 fc:00 261800 /lib/x86_64-linux-gnu/libssl.so.1.0.0 16307:20131126:154621.202 7f2483444000-7f2483644000 ---p 00054000 fc:00 261800 /lib/x86_64-linux-gnu/libssl.so.1.0.0 16307:20131126:154621.202 7f2483644000-7f2483647000 r--p 00054000 fc:00 261800 /lib/x86_64-linux-gnu/libssl.so.1.0.0 16307:20131126:154621.202 7f2483647000-7f248364d000 rw-p 00057000 fc:00 261800 /lib/x86_64-linux-gnu/libssl.so.1.0.0 16307:20131126:154621.202 7f248364d000-7f248364e000 rw-p 00000000 00:00 0 16307:20131126:154621.202 7f248364e000-7f2483689000 r-xp 00000000 fc:00 149595 /usr/lib/x86_64-linux-gnu/libgssapi_krb5.so.2.2 16307:20131126:154621.202 7f2483689000-7f2483889000 ---p 0003b000 fc:00 149595 /usr/lib/x86_64-linux-gnu/libgssapi_krb5.so.2.2 16307:20131126:154621.202 7f2483889000-7f248388a000 r--p 0003b000 fc:00 149595 /usr/lib/x86_64-linux-gnu/libgssapi_krb5.so.2.2 16307:20131126:154621.202 7f248388a000-7f248388c000 rw-p 0003c000 fc:00 149595 /usr/lib/x86_64-linux-gnu/libgssapi_krb5.so.2.2 16307:20131126:154621.202 7f248388c000-7f24838d7000 r-xp 00000000 fc:00 149626 /usr/lib/x86_64-linux-gnu/libldap_r-2.4.so.2.8.1 16307:20131126:154621.202 7f24838d7000-7f2483ad6000 ---p 0004b000 fc:00 149626 /usr/lib/x86_64-linux-gnu/libldap_r-2.4.so.2.8.1 16307:20131126:154621.202 7f2483ad6000-7f2483ad8000 r--p 0004a000 fc:00 149626 /usr/lib/x86_64-linux-gnu/libldap_r-2.4.so.2.8.1 16307:20131126:154621.202 7f2483ad8000-7f2483ad9000 rw-p 0004c000 fc:00 149626 /usr/lib/x86_64-linux-gnu/libldap_r-2.4.so.2.8.1 16307:20131126:154621.202 7f2483ad9000-7f2483adb000 rw-p 00000000 00:00 0 16307:20131126:154621.202 7f2483adb000-7f2483ae8000 r-xp 00000000 fc:00 149627 /usr/lib/x86_64-linux-gnu/liblber-2.4.so.2.8.1 16307:20131126:154621.203 7f2483ae8000-7f2483ce7000 ---p 0000d000 fc:00 149627 /usr/lib/x86_64-linux-gnu/liblber-2.4.so.2.8.1 16307:20131126:154621.203 7f2483ce7000-7f2483ce8000 r--p 0000c000 fc:00 149627 /usr/lib/x86_64-linux-gnu/liblber-2.4.so.2.8.1 16307:20131126:154621.203 7f2483ce8000-7f2483ce9000 rw-p 0000d000 fc:00 149627 /usr/lib/x86_64-linux-gnu/liblber-2.4.so.2.8.1 16307:20131126:154621.203 7f2483ce9000-7f2483d1b000 r-xp 00000000 fc:00 149597 /usr/lib/x86_64-linux-gnu/libidn.so.11.6.6 16307:20131126:154621.203 7f2483d1b000-7f2483f1a000 ---p 00032000 fc:00 149597 /usr/lib/x86_64-linux-gnu/libidn.so.11.6.6 16307:20131126:154621.203 7f2483f1a000-7f2483f1b000 r--p 00031000 fc:00 149597 /usr/lib/x86_64-linux-gnu/libidn.so.11.6.6 16307:20131126:154621.203 7f2483f1b000-7f2483f1c000 rw-p 00032000 fc:00 149597 /usr/lib/x86_64-linux-gnu/libidn.so.11.6.6 16307:20131126:154621.203 7f2483f1c000-7f2483fd0000 r-xp 00000000 fc:00 149582 /usr/lib/x86_64-linux-gnu/libgnutls.so.26.21.8 16307:20131126:154621.203 7f2483fd0000-7f24841d0000 ---p 000b4000 fc:00 149582 /usr/lib/x86_64-linux-gnu/libgnutls.so.26.21.8 16307:20131126:154621.203 7f24841d0000-7f24841d6000 r--p 000b4000 fc:00 149582 /usr/lib/x86_64-linux-gnu/libgnutls.so.26.21.8 16307:20131126:154621.203 7f24841d6000-7f24841d7000 rw-p 000ba000 fc:00 149582 /usr/lib/x86_64-linux-gnu/libgnutls.so.26.21.8 16307:20131126:154621.203 7f24841d7000-7f24841d8000 rw-p 00000000 00:00 0 16307:20131126:154621.203 7f24841d8000-7f24841f0000 r-xp 00000000 fc:00 261700 /lib/x86_64-linux-gnu/libpthread-2.15.so 16307:20131126:154621.203 7f24841f0000-7f24843ef000 ---p 00018000 fc:00 261700 /lib/x86_64-linux-gnu/libpthread-2.15.so 16307:20131126:154621.203 7f24843ef000-7f24843f0000 r--p 00017000 fc:00 261700 /lib/x86_64-linux-gnu/libpthread-2.15.so 16307:20131126:154621.203 7f24843f0000-7f24843f1000 rw-p 00018000 fc:00 261700 /lib/x86_64-linux-gnu/libpthread-2.15.so 16307:20131126:154621.203 7f24843f1000-7f24843f5000 rw-p 00000000 00:00 0 16307:20131126:154621.203 7f24843f5000-7f248440b000 r-xp 00000000 fc:00 262052 /lib/x86_64-linux-gnu/libz.so.1.2.3.4 16307:20131126:154621.203 7f248440b000-7f248460a000 ---p 00016000 fc:00 262052 /lib/x86_64-linux-gnu/libz.so.1.2.3.4 16307:20131126:154621.203 7f248460a000-7f248460b000 r--p 00015000 fc:00 262052 /lib/x86_64-linux-gnu/libz.so.1.2.3.4 16307:20131126:154621.203 7f248460b000-7f248460c000 rw-p 00016000 fc:00 262052 /lib/x86_64-linux-gnu/libz.so.1.2.3.4 16307:20131126:154621.203 7f248460c000-7f24847c1000 r-xp 00000000 fc:00 261697 /lib/x86_64-linux-gnu/libc-2.15.so 16307:20131126:154621.203 7f24847c1000-7f24849c0000 ---p 001b5000 fc:00 261697 /lib/x86_64-linux-gnu/libc-2.15.so 16307:20131126:154621.203 7f24849c0000-7f24849c4000 r--p 001b4000 fc:00 261697 /lib/x86_64-linux-gnu/libc-2.15.so 16307:20131126:154621.203 7f24849c4000-7f24849c6000 rw-p 001b8000 fc:00 261697 /lib/x86_64-linux-gnu/libc-2.15.so 16307:20131126:154621.203 7f24849c6000-7f24849cb000 rw-p 00000000 00:00 0 16307:20131126:154621.203 7f24849cb000-7f24849e3000 r-xp 00000000 fc:00 261703 /lib/x86_64-linux-gnu/libresolv-2.15.so 16307:20131126:154621.203 7f24849e3000-7f2484be3000 ---p 00018000 fc:00 261703 /lib/x86_64-linux-gnu/libresolv-2.15.so 16307:20131126:154621.204 7f2484be3000-7f2484be4000 r--p 00018000 fc:00 261703 /lib/x86_64-linux-gnu/libresolv-2.15.so 16307:20131126:154621.204 7f2484be4000-7f2484be5000 rw-p 00019000 fc:00 261703 /lib/x86_64-linux-gnu/libresolv-2.15.so 16307:20131126:154621.204 7f2484be5000-7f2484be7000 rw-p 00000000 00:00 0 16307:20131126:154621.204 7f2484be7000-7f2484bee000 r-xp 00000000 fc:00 261702 /lib/x86_64-linux-gnu/librt-2.15.so 16307:20131126:154621.204 7f2484bee000-7f2484ded000 ---p 00007000 fc:00 261702 /lib/x86_64-linux-gnu/librt-2.15.so 16307:20131126:154621.204 7f2484ded000-7f2484dee000 r--p 00006000 fc:00 261702 /lib/x86_64-linux-gnu/librt-2.15.so 16307:20131126:154621.204 7f2484dee000-7f2484def000 rw-p 00007000 fc:00 261702 /lib/x86_64-linux-gnu/librt-2.15.so 16307:20131126:154621.204 7f2484def000-7f2484df1000 r-xp 00000000 fc:00 261694 /lib/x86_64-linux-gnu/libdl-2.15.so 16307:20131126:154621.204 7f2484df1000-7f2484ff1000 ---p 00002000 fc:00 261694 /lib/x86_64-linux-gnu/libdl-2.15.so 16307:20131126:154621.204 7f2484ff1000-7f2484ff2000 r--p 00002000 fc:00 261694 /lib/x86_64-linux-gnu/libdl-2.15.so 16307:20131126:154621.204 7f2484ff2000-7f2484ff3000 rw-p 00003000 fc:00 261694 /lib/x86_64-linux-gnu/libdl-2.15.so 16307:20131126:154621.204 7f2484ff3000-7f24850ee000 r-xp 00000000 fc:00 261706 /lib/x86_64-linux-gnu/libm-2.15.so 16307:20131126:154621.204 7f24850ee000-7f24852ed000 ---p 000fb000 fc:00 261706 /lib/x86_64-linux-gnu/libm-2.15.so 16307:20131126:154621.204 7f24852ed000-7f24852ee000 r--p 000fa000 fc:00 261706 /lib/x86_64-linux-gnu/libm-2.15.so 16307:20131126:154621.204 7f24852ee000-7f24852ef000 rw-p 000fb000 fc:00 261706 /lib/x86_64-linux-gnu/libm-2.15.so 16307:20131126:154621.204 7f24852ef000-7f2485384000 r-xp 00000000 fc:00 155709 /usr/lib/libnetsnmp.so.15.1.2 16307:20131126:154621.204 7f2485384000-7f2485583000 ---p 00095000 fc:00 155709 /usr/lib/libnetsnmp.so.15.1.2 16307:20131126:154621.204 7f2485583000-7f2485584000 r--p 00094000 fc:00 155709 /usr/lib/libnetsnmp.so.15.1.2 16307:20131126:154621.204 7f2485584000-7f2485586000 rw-p 00095000 fc:00 155709 /usr/lib/libnetsnmp.so.15.1.2 16307:20131126:154621.204 7f2485586000-7f24855bb000 rw-p 00000000 00:00 0 16307:20131126:154621.204 7f24855bb000-7f2485621000 r-xp 00000000 fc:00 158990 /usr/lib/libodbc.so.2.0.0 16307:20131126:154621.204 7f2485621000-7f2485821000 ---p 00066000 fc:00 158990 /usr/lib/libodbc.so.2.0.0 16307:20131126:154621.204 7f2485821000-7f2485822000 r--p 00066000 fc:00 158990 /usr/lib/libodbc.so.2.0.0 16307:20131126:154621.204 7f2485822000-7f2485829000 rw-p 00067000 fc:00 158990 /usr/lib/libodbc.so.2.0.0 16307:20131126:154621.204 7f2485829000-7f248582a000 rw-p 00000000 00:00 0 16307:20131126:154621.204 7f248582a000-7f2485884000 r-xp 00000000 fc:00 153465 /usr/lib/x86_64-linux-gnu/libcurl.so.4.2.0 16307:20131126:154621.205 7f2485884000-7f2485a84000 ---p 0005a000 fc:00 153465 /usr/lib/x86_64-linux-gnu/libcurl.so.4.2.0 16307:20131126:154621.205 7f2485a84000-7f2485a86000 r--p 0005a000 fc:00 153465 /usr/lib/x86_64-linux-gnu/libcurl.so.4.2.0 16307:20131126:154621.205 7f2485a86000-7f2485a87000 rw-p 0005c000 fc:00 153465 /usr/lib/x86_64-linux-gnu/libcurl.so.4.2.0 16307:20131126:154621.205 7f2485a87000-7f2485bd8000 r-xp 00000000 fc:00 149720 /usr/lib/x86_64-linux-gnu/libxml2.so.2.7.8 16307:20131126:154621.205 7f2485bd8000-7f2485dd8000 ---p 00151000 fc:00 149720 /usr/lib/x86_64-linux-gnu/libxml2.so.2.7.8 16307:20131126:154621.206 7f2485dd8000-7f2485de0000 r--p 00151000 fc:00 149720 /usr/lib/x86_64-linux-gnu/libxml2.so.2.7.8 16307:20131126:154621.206 7f2485de0000-7f2485de2000 rw-p 00159000 fc:00 149720 /usr/lib/x86_64-linux-gnu/libxml2.so.2.7.8 16307:20131126:154621.206 7f2485de2000-7f2485de3000 rw-p 00000000 00:00 0 16307:20131126:154621.206 7f2485de3000-7f2485def000 r-xp 00000000 fc:00 155529 /usr/lib/libiksemel.so.3.0.0 16307:20131126:154621.206 7f2485def000-7f2485fee000 ---p 0000c000 fc:00 155529 /usr/lib/libiksemel.so.3.0.0 16307:20131126:154621.206 7f2485fee000-7f2485fef000 r--p 0000b000 fc:00 155529 /usr/lib/libiksemel.so.3.0.0 16307:20131126:154621.206 7f2485fef000-7f2485ff0000 rw-p 0000c000 fc:00 155529 /usr/lib/libiksemel.so.3.0.0 16307:20131126:154621.206 7f2485ff0000-7f24862ae000 r-xp 00000000 fc:00 152961 /usr/lib/x86_64-linux-gnu/libmysqlclient.so.18.0.0 16307:20131126:154621.206 7f24862ae000-7f24864ad000 ---p 002be000 fc:00 152961 /usr/lib/x86_64-linux-gnu/libmysqlclient.so.18.0.0 16307:20131126:154621.206 7f24864ad000-7f24864b3000 r--p 002bd000 fc:00 152961 /usr/lib/x86_64-linux-gnu/libmysqlclient.so.18.0.0 16307:20131126:154621.206 7f24864b3000-7f2486531000 rw-p 002c3000 fc:00 152961 /usr/lib/x86_64-linux-gnu/libmysqlclient.so.18.0.0 16307:20131126:154621.206 7f2486531000-7f2486536000 rw-p 00000000 00:00 0 16307:20131126:154621.206 7f2486536000-7f2486558000 r-xp 00000000 fc:00 261712 /lib/x86_64-linux-gnu/ld-2.15.so 16307:20131126:154621.206 7f2486601000-7f2486608000 r--s 00000000 fc:00 133834 /usr/lib/x86_64-linux-gnu/gconv/gconv-modules.cache 16307:20131126:154621.206 7f2486608000-7f248673c000 rw-s 00000000 00:04 40468485 /SYSV73007292 (deleted) 16307:20131126:154621.206 7f248673c000-7f2486750000 rw-p 00000000 00:00 0 16307:20131126:154621.206 7f2486752000-7f2486753000 rw-p 00000000 00:00 0 16307:20131126:154621.206 7f2486753000-7f2486755000 rw-s 00000000 00:04 40501254 /SYSV53007292 (deleted) 16307:20131126:154621.206 7f2486755000-7f2486756000 rw-p 00000000 00:00 0 16307:20131126:154621.206 7f2486756000-7f2486758000 rw-p 00000000 00:00 0 16307:20131126:154621.206 7f2486758000-7f2486759000 r--p 00022000 fc:00 261712 /lib/x86_64-linux-gnu/ld-2.15.so 16307:20131126:154621.206 7f2486759000-7f248675b000 rw-p 00023000 fc:00 261712 /lib/x86_64-linux-gnu/ld-2.15.so 16307:20131126:154621.206 7fff83dd3000-7fff83e05000 rw-p 00000000 00:00 0 [stack] 16307:20131126:154621.206 7fff83fd4000-7fff83fd6000 r-xp 00000000 00:00 0 [vdso] 16307:20131126:154621.206 ffffffffff600000-ffffffffff601000 r-xp 00000000 00:00 0 [vsyscall] 16307:20131126:154621.206 ================================ 16307:20131126:154621.206 Please consider attaching a disassembly listing to your bug report. 16307:20131126:154621.206 This listing can be produced with, e.g., objdump -DSswx zabbix_server. 16307:20131126:154621.206 ================================ 16303:20131126:154621.208 One child process died (PID:16307,exitcode/signal:255). Exiting ... 16303:20131126:154621.208 zbx_on_exit() called 16305:20131126:154621.209 Got signal [signal:15(SIGTERM),sender_pid:16303,sender_uid:1000,reason:0]. Exiting ... 16306:20131126:154621.210 Got signal [signal:15(SIGTERM),sender_pid:16303,sender_uid:1000,reason:0]. Exiting ... 16308:20131126:154621.212 Got signal [signal:15(SIGTERM),sender_pid:16303,sender_uid:1000,reason:0]. Exiting ... 16309:20131126:154621.213 Got signal [signal:15(SIGTERM),sender_pid:16303,sender_uid:1000,reason:0]. Exiting ... 16310:20131126:154621.214 Got signal [signal:15(SIGTERM),sender_pid:16303,sender_uid:1000,reason:0]. Exiting ... 16311:20131126:154621.217 Got signal [signal:15(SIGTERM),sender_pid:16303,sender_uid:1000,reason:0]. Exiting ... 16312:20131126:154621.219 Got signal [signal:15(SIGTERM),sender_pid:16303,sender_uid:1000,reason:0]. Exiting ... 16313:20131126:154621.220 Got signal [signal:15(SIGTERM),sender_pid:16303,sender_uid:1000,reason:0]. Exiting ... 16314:20131126:154621.222 Got signal [signal:15(SIGTERM),sender_pid:16303,sender_uid:1000,reason:0]. Exiting ... 16315:20131126:154621.223 Got signal [signal:15(SIGTERM),sender_pid:16303,sender_uid:1000,reason:0]. Exiting ... 16316:20131126:154621.225 Got signal [signal:15(SIGTERM),sender_pid:16303,sender_uid:1000,reason:0]. Exiting ... 16317:20131126:154621.228 Got signal [signal:15(SIGTERM),sender_pid:16303,sender_uid:1000,reason:0]. Exiting ... 16321:20131126:154621.228 Got signal [signal:15(SIGTERM),sender_pid:16303,sender_uid:1000,reason:0]. Exiting ... 16322:20131126:154621.230 Got signal [signal:15(SIGTERM),sender_pid:16303,sender_uid:1000,reason:0]. Exiting ... 16324:20131126:154621.231 Got signal [signal:15(SIGTERM),sender_pid:16303,sender_uid:1000,reason:0]. Exiting ... 16326:20131126:154621.235 Got signal [signal:15(SIGTERM),sender_pid:16303,sender_uid:1000,reason:0]. Exiting ... 16327:20131126:154621.239 Got signal [signal:15(SIGTERM),sender_pid:16303,sender_uid:1000,reason:0]. Exiting ... 16328:20131126:154621.253 Got signal [signal:15(SIGTERM),sender_pid:16303,sender_uid:1000,reason:0]. Exiting ... 16329:20131126:154621.255 Got signal [signal:15(SIGTERM),sender_pid:16303,sender_uid:1000,reason:0]. Exiting ... 16334:20131126:154621.256 Got signal [signal:15(SIGTERM),sender_pid:16303,sender_uid:1000,reason:0]. Exiting ... 16335:20131126:154621.258 Got signal [signal:15(SIGTERM),sender_pid:16303,sender_uid:1000,reason:0]. Exiting ... 16336:20131126:154621.259 Got signal [signal:15(SIGTERM),sender_pid:16303,sender_uid:1000,reason:0]. Exiting ... 16337:20131126:154621.260 Got signal [signal:15(SIGTERM),sender_pid:16303,sender_uid:1000,reason:0]. Exiting ... 16340:20131126:154621.262 Got signal [signal:15(SIGTERM),sender_pid:16303,sender_uid:1000,reason:0]. Exiting ... 16343:20131126:154621.264 Got signal [signal:15(SIGTERM),sender_pid:16303,sender_uid:1000,reason:0]. Exiting ...
Trickels
Edit:
