Since correcting a major issue with the zabbix installation that I have been stuck with. Some new problems have arisen.
I am pasting a trigger that is supposed to trigger in the event that connectivity fails from the front end to the 4 mongodb servers.
<triggers>
{front-end-severname:net.tcp.port[mongo1dbhostname.com,27017].last(3)}=0 | {front-end-severname:net.tcp.port[mongo2dbhostname.com,27017].last(3)}=0 | {front-end-severname:net.tcp.port[mongo3dbhostname.com,27017].last(3)}=0 | {front-end-severname:net.tcp.port[mongo4dbhostname.com,27017].last(3)}=0
</triggers>
If I understand this correctly. I use IF very prominently.
The above says "If connectivity to from front-end-servername to mongodbhostname.com on port 27017 fails for more than 3 seconds. Then trigger.. Am I understanding that correctly?
The problem is that we keep getting alerts that this connectivity has beeb interrupted but then immediately after we get a recovery email.
Any help is appreciated.
Thanks,
J
<triggers>
</triggers>
Thanks,
J
