VMware monitoring on 2.2
  • DIoX|DaZ
    • Apr 2011
    • 31
    i've have problem starting monitoring vmware hosts with default templates, first of all what i can see in discovery when i've add template Template Virt VMware is "Cannot create group: invalid group name ""."
    So i'm guessing that template wants to create some kind of group?
    If i've have Guest vmware monitoring template, it adds all discovered hosts to groups (vm) and hypervisor name: Discovered hosts, is the a way to change location where to add discovered hosts? maybe i could change smth in template?
  • xxiii
    • Jun 2013
    • 28
    VMware Hypervisor: can't create group ""
    I'm having this problem as well. It appears the hypervisor discovery host template rule tries to create a group for the VMware cluster. Except my VMware server isn't part of a cluster, So I'm assuming its getting an empty string back for the cluster name, and then tries to use this as a group name to create.
    As a result, the entire discovery fails and no hypervisor host gets created (but I do get hosts created for the individual VMs).
    • DIoX|DaZ
      • Apr 2011
      • 31
      So, i'm guessing no news here
      • johansen
        • Oct 2009
        • 38
        you can remove the macros in the host discovery and hardcode the group to add the hypervisor to.
        this is what we did to work around the "issue" that multiple host groups (based on the amount of hypervisor servers) are added automatically.
        • Daniel Checa
          • Jul 2024
          Hola, he resuelto el problema.
          Les dejo un pequeño documento creado para la resolución del problema.
          Si tienen duda, háganmelo saber por favor.
          !Saludos!
          • metalrise
            • Aug 2024
            Daniel approach is a little bit hardcore, using his pdf I've made some configuration directly in the web interface for Zabbix 7
            Note: on the vmware server I have only 2 templates assigned
            VMware FQDN
            VMware Hypervisor
            now the config:
            Templates
            For VMware FQDN click on Discovery 4
            disable VMware FQDN Discover VMware clusters
            go back to Hosts
            click on the vmware host
            for VMware FQDN click on Unlink and clear
            Update
            Click on the vmware host
            add back the VMware FQDN template​
            Go to Templates
            filter VMware FQDN
            Click on Discovery 4
            For VMware FQDN Discover VMware hypervisors click on Host prototypes 1
            click on {#HV.NAME}
            remove {#CLUSTER.NAME} line
            Update
            Go to Hosts
            click on the vmware server
            click on Discovery 7
            Select all the lines and click on Execute now​
