https frontend for zabbix
  • mystycs
    • Aug 2013
    • 56
    How do i configure/setup https for the frontend of zabbix? At the moment i tried https:// but its not working.
    Has anyone done this successfully or can push me in the right direction?
    Thanks!
  • pxsh
    • Oct 2013
    • 14
    Are you using Linux (apache, httpd) or Windows (IIS) ?
    Is port 443 allowed thru your server firewall ?
    Do you get any errors in logs ?
    Its possible that SSL is either not enabled in your setup or its enabled but with faulty configuration.
    If you´re using Linux / CentOS like me then feel free to check this guide, first hit on google: http://wiki.centos.org/HowTos/Https
    • mystycs
      • Aug 2013
      • 56
      I allowed port ssl, still nothing. I am using ubuntu. And i tried using that guide but im not sure what http conf i setup for this. Is it ports.conf or the zabbix apache conf?
      I am running ubuntus zabbix installation. i think its apache2
      • mystycs
        • Aug 2013
        • 56
        I figured it out using this guide!
        • esawyja
          • Dec 2011
          • 54
          This is the way I've set it up with SLES (OpenSuSe)
          Your Gateway to Linux, Hadoop, Hive, H-Base, Postgres, Zabbix, Centos7, 389-DS, Arduino
