ZBX_NotSupported in 2.2 but working in 2.0.8
  • Vapochilled
    • Nov 2013
    • 17
    Hello everyone,
    I'm having a very weird issue.
    Im using Zabbix 2.0.8 ofr the production lab
    In parallel I have installed a 2.2 to monitor a test lab and check the new features, performance, etc.
    Here is my problem:
    - I have one Discovery rule that will run a script I have (agent_active) and find some specific services in that host.
    - When I run the 1st time the zabbix_get from zabbix_server
    [root@PTPET ~]# zabbix_get -s 10.91.76.10 -k "OSSServices"
    {"data":[
    {"{#OSSSERVICE}":"netfs-sprintlab357vm4"},
    {"{#OSSSERVICE}":"cpfnx2s-sprintlab357vm4"},
    {"{#OSSSERVICE}":"OMAgentAF-sprintlab357vm4"},
    {"{#OSSSERVICE}":"db"}]}
    It works!!
    Few seconds after...
    ZBX_NOTSUPPORTED
    If I connect this host to my production system...
    The script and the rule works.
    Also.. as you can see the JSON seems to be ok.
    Is this a bug from 2.2?
  • Vapochilled
    • Nov 2013
    • 17
    Hi guys,
    I've discovered my problem and this might be usefull to other guys.
    The problem here was the timeout flag.
    By default 2.2 is bringing a timeout = 3 secs
    This discovery that I run just once (because I don't need to discover all the services on that host more than once) takes around 3 or 4 secs.
    Because the Zabbix default in 2.2 is 3secs in the agents, I had ZBX not supported.
    I believe this should be changed to timeout message in the GUI.
    It was really difficult to see why it was failing..... in fact it is not ZBX_notsupported.. but should be timed-out.
