SNMP flip flap on new items
  • nickwe
    • Sep 2009
    • 13
    I've taken the default SNMP template to monitore one my device, and all the snmp item by default always respond while the one I create flip flap (bacame supported/not supported):
      2511:20180315:123446.026 item "DPW PROD:EthernetCountersStatusIn[eth21]" became supported
      2510:20180315:123546.357 item "DPW PROD:EthernetCountersStatusIn[eth21]" became not supported: No Such Instance currently exists at this OID
      2510:20180315:123746.891 item "DPW PROD:EthernetCountersStatusIn[eth21]" became supported
      2513:20180315:123847.161 item "DPW PROD:EthernetCountersStatusIn[eth21]" became not supported: No Such Instance currently exists at this OID
      2515:20180315:124346.541 item "DPW PROD:EthernetCountersStatusIn[eth21]" became supported
      2513:20180315:124445.809 item "DPW PROD:EthernetCountersStatusIn[eth21]" became not supported: No Such Instance currently exists at this OID
      2511:20180315:130247.098 item "DPW PROD:EthernetCountersStatusIn[eth21]" became supported
      2510:20180315:130346.533 item "DPW PROD:EthernetCountersStatusIn[eth21]" became not supported: No Such Instance currently exists at this OID
      2515:20180315:130646.637 item "DPW PROD:EthernetCountersStatusIn[eth21]" became supported
      2513:20180315:130746.550 item "DPW PROD:EthernetCountersStatusIn[eth21]" became not supported: No Such Instance currently exists at this OID
      2510:20180315:130946.229 item "DPW PROD:EthernetCountersStatusIn[eth21]" became supported
      2515:20180315:131046.652 item "DPW PROD:EthernetCountersStatusIn[eth21]" became not supported: No Such Instance currently exists at this OID
      2511:20180315:131146.123 item "DPW PROD:EthernetCountersStatusIn[eth21]" became supported
      2515:20180315:131246.486 item "DPW PROD:EthernetCountersStatusIn[eth21]" became not supported: No Such Instance currently exists at this OID
      2510:20180315:132247.407 item "DPW PROD:EthernetCountersStatusIn[eth21]" became supported
      2511:20180315:132346.680 item "DPW PROD:EthernetCountersStatusIn[eth21]" became not supported: No Such Instance currently exists at this OID
      2511:20180315:133446.968 item "DPW PROD:EthernetCountersStatusIn[eth21]" became supported
      2513:20180315:133546.255 item "DPW PROD:EthernetCountersStatusIn[eth21]" became not supported: No Such Instance currently exists at this OID
      2510:20180315:133847.078 item "DPW PROD:EthernetCountersStatusIn[eth21]" became supported
      2511:20180315:133947.345 item "DPW PROD:EthernetCountersStatusIn[eth21]" became not supported: No Such Instance currently exists at this OID
      2515:20180315:140346.467 item "DPW PROD:EthernetCountersStatusIn[eth21]" became supported
      2515:20180315:140446.624 item "DPW PROD:EthernetCountersStatusIn[eth21]" became not supported: No Such Instance currently exists at this OID
      2510:20180315:141246.873 item "DPW PROD:EthernetCountersStatusIn[eth21]" became supported
      2511:20180315:141346.175 item "DPW PROD:EthernetCountersStatusIn[eth21]" became not supported: No Such Instance currently exists at this OID
      2510:20180315:141847.550 item "DPW PROD:EthernetCountersStatusIn[eth21]" became supported
      2510:20180315:141946.815 item "DPW PROD:EthernetCountersStatusIn[eth21]" became not supported: No Such Instance currently exists at this OID
      2510:20180315:143246.430 item "DPW PROD:EthernetCountersStatusIn[eth21]" became supported
      2510:20180315:143346.751 item "DPW PROD:EthernetCountersStatusIn[eth21]" became not supported: No Such Instance currently exists at this OID
      2515:20180315:143646.583 item "DPW PROD:EthernetCountersStatusIn[eth21]" became supported
      2511:20180315:143746.855 item "DPW PROD:EthernetCountersStatusIn[eth21]" became not supported: No Such Instance currently exists at this OID
      2513:20180315:144346.459 item "DPW PROD:EthernetCountersStatusIn[eth21]" became supported
      2513:20180315:144446.767 item "DPW PROD:EthernetCountersStatusIn[eth21]" became not supported: No Such Instance currently exists at this OID
      2513:20180315:145846.578 item "DPW PROD:EthernetCountersStatusIn[eth21]" became supported
      2515:20180315:145946.843 item "DPW PROD:EthernetCountersStatusIn[eth21]" became not supported: No Such Instance currently exists at this OID
      2513:20180315:150946.948 item "DPW PROD:EthernetCountersStatusIn[eth21]" became supported
      2510:20180315:151046.700 item "DPW PROD:EthernetCountersStatusIn[eth21]" became not supported: No Such Instance currently exists at this OID
      2510:20180315:161145.900 item "DPW PROD:EthernetCountersStatusIn[eth21]" became supported
      2515:20180315:161246.193 item "DPW PROD:EthernetCountersStatusIn[eth21]" became not supported: No Such Instance currently exists at this OID
      2510:20180315:161445.868 item "DPW PROD:EthernetCountersStatusIn[eth21]" became supported
      2513:20180315:161546.161 item "DPW PROD:EthernetCountersStatusIn[eth21]" became not supported: No Such Instance currently exists at this OID
      2513:20180315:162347.356 item "DPW PROD:EthernetCountersStatusIn[eth21]" became supported
      2511:20180315:162446.617 item "DPW PROD:EthernetCountersStatusIn[eth21]" became not supported: No Such Instance currently exists at this OID
      2510:20180315:162545.887 item "DPW PROD:EthernetCountersStatusIn[eth21]" became supported
      2513:20180315:162646.159 item "DPW PROD:EthernetCountersStatusIn[eth21]" became not supported: No Such Instance currently exists at this OID
      2510:20180315:164547.337 item "DPW PROD:EthernetCountersStatusIn[eth21]" became supported
    When I do a snmpwalk from the zabbix server, I always get an answer:
    [root ~]# snmpwalk -v2c -c public 192.168.30.47 .1.3.6.1.4.1.14685.3.1.132.1.10.6
    SNMPv2-SMI::enterprises.14685.3.1.132.1.10.6 = Counter64: 489706383560
    Don't know why some items are supported on one check, then get unsupported for the next 5 checks ?
    What could I do to debug and see exactly what zabbix is trying to do because with snmpwalk, it's always good.
Name:	2018-03-15 17_03_14-Latest data [refreshed every 900 sec.].png
  • DmitryL
    • May 2016
    • 278
    Try to disable bulk requests
    • nickwe
      • Sep 2009
      • 13
      Thanks DmitryL , you're my hero, I've lost so much time on this and disabling the bulk request solve my issue :-)
      Thanks a lot!
      • DmitryL
        • May 2016
        • 278
        Just don't think that bulk requests is a bad thing Simply some devices don't support it
