Hi Guys,
I have VM using Oracle Linux 7 which is based RHEL 7, and i use Zabbix Agent 3.0, and also same version with my existing Zabbix Server. And i guess there is problem with communication between agent and server.
This below is the log of zabbix agent of OEL7 VM
[root@yoga-em ~]# tail /var/log/zabbix/zabbix_agentd.log
9626:20180316:093441.631 **** Enabled features ****
9626:20180316:093441.631 IPv6 support: YES
9626:20180316:093441.631 TLS support: YES
9626:20180316:093441.631 **************************
9626:20180316:093441.631 using configuration file: /etc/zabbix/zabbix_agentd.conf
9626:20180316:093441.632 agent #0 started [main process]
9627:20180316:093441.632 agent #1 started [collector]
9628:20180316:093441.633 agent #2 started[listener #1]
9629:20180316:093441.633 agent #3 started[listener #2]
9630:20180316:093441.634 agent #4 started[listener #3]
And i have uploaded the capture of Zabbix Server which is show us the grey light in communication part. i've changed the configuration file, only Server parameter to my Zabbix Server's IP Address, ServerActive using #, and Hostname with my VM hostname.
So please kindly to help me solve this issue.
Thanks,
Yoga
Thanks,
Yoga
