Default Encryption settings for newly added host
  • alledm
    • May 2012
    • 84
    I am used TLS certificate based encryption on all my agents.
    my agent configuration is:
    TLSConnect=cert
    TLSAccept=cert
    TLSCAFile=/etc/certs/zabbix/ca.crt
    TLSCertFile=/etc/certs/zabbix/zabbix.crt
    TLSKeyFile=/etc/certs/zabbix/zabbix.key
    Unfortunately new hosts are automatically added with the following settings:
    So the agent won't work, requiring me to change these settings manually.
    Can you tell me where I can set the default TLS settings for a newly added host?
    Regards
    Alessandro
  • dimir
    Zabbix developer
    • Apr 2011
    • 1080
    If you are using agent auto-registration, there is a feature request https://support.zabbix.com/browse/ZBXNEXT-3497 .
    Until then you would have to write a script that will be triggered on host discovery, similarly as explained here: http://www.zabbixbook.com/2017/08/01...sk-encryption/
