Zabbix 3.4 Agent grabbing data from a text file
  • jbgoheels
    • May 2017
    • 9
    I have Zabbix Agent version 3.4 running on a Server 2012R2 machine. The machine runs a DFS backlog report every day at 9am. The report is a simple text file that contains the date and the backlog count. I would like for Zabbix to pull the count from the text file and alert me if the count goes above 100.
    The text file is located at C:\DFSLog.txt
    This file contains the following:
    3/14/2018 9:00:10 AM servername 0
    So I need to get this 0 value on my zabbix server.
    So I created an item in Zabbix under the host where the report is located Named "DFS", type "Zabbix Agent", key vfs.file.regexp["C:\DFSLog.txt",], text.
    Is this possible with regexp?
    Thanks!
  • jbgoheels
    • May 2017
    • 9
    I am able to grab the first character of the txt file, but cannot grab the whole string.
    Here is what I am using to grab the info from the txt file.
    vfs.file.regexp[C:\DFSLog.txt,"([0-9]+)$",,1,1,\1]
    Any particular reason why it will only grab the first character of the txt file?
    • sancho
      • Mar 2015
      • 301
      Hello jbgoheels,
      Try downloading the unixtools on the server windows http://unxutils.sourceforge.net/ and add the folder where you have unzipped to windows environment variables or copying gawk.exe to your windows folder.
      Then create an item zabbix agent
      Key: system.run [type C: \ DFSLog.txt | gawk "{print $ 5}"]
      Type of information: Numeric (float)
      I hope it helps you.
      A greeting.
      • jbgoheels
        • May 2017
        • 9
        Thanks for the reply sancho. Here's what I'm getting when trying to add the item into Zabbix.
        • Invalid key "system.run [type C:\DFSLog.txt | gawk "{print $ 5}"]" for item "DFS Log" on "Server": incorrect syntax near " [type C:\DFSLog.txt | gawk "{print $ 5}"]".
        • sancho
          • Mar 2015
          • 301
          jbgoheels copy the file gawk.exe that you should have downloaded with the unixutils in C:\Windows\System32
          The error seems to be because the system can not find the program gawk.exe
          • jbgoheels
            • May 2017
            • 9
            Got it working! Thanks for your help sancho!
            The key that I used was:
            system.run[type C:\DFSLog.txt | gawk "{print $ 5}",wait]
            Type of information: Text
            • sancho
              • Mar 2015
              • 301
              I'm glad you it worked
              • jbgoheels
                • May 2017
                • 9
                I need Zabbix to read another text file. This file has 3 lines.
                4/19/2018 11:09:43 AM
                server
                500
                Is there a way to get the key to use gawk to read from the 3rd line only?
                • jbgoheels
                  • May 2017
                  • 9
                  Got it.
                  Use this Key:
                  system.run[type C:\DFSR-BACKLOG\REPORTS\server-TOTAL-Backlog-Report.txt | gawk "FNR == 3 {print $ 1}",wait]
                  • jbgoheels
                    • May 2017
                    • 9
                    If anyone wants to monitor DFSR Backlogs on Server 2012 R2 using Zabbix 3.4 this is one method that works.
                    Use the Powershell script located at: https://gallery.technet.microsoft.co...e18d5b#content
                    Add these lines (change path accordingly) to the script near the beginning:
                    ### ENSURE REPORTS FILE EMPTY ###
                    Clear-Content C:\DFSR-BACKLOG\REPORTS\server1-TOTAL-Backlog-Report.txt
                    Clear-Content C:\DFSR-BACKLOG\REPORTS\server2-TOTAL-Backlog-Report.txt
                    This will clear out the report each time it is run.
                    Automate the script to run on a schedule.
                    This will output a txt file with the following contents:
                    server
                    0
                    The 3rd line is the backlog count.
                    On the server running the powershell script, follow sancho's advice from above and download UnxUtils.
                    In Zabbix, create an item for the server running the powershell script.
                    Use this key: (change path accordingly)
                    • sancho
                      • Mar 2015
                      • 301
                      Thanks jbgoheels
