Zabbix queued Delayed
  • linor
    • Apr 2017
    I have many items delayed on the zabbix queue. And I'm not able to find where is the problem. Can anyone help me?
    Informations:
    Zabbix 3.4.7
    I use zabbix proxy for monitoring
    I'm able to query the metrics from zabbix proxy using zabbix proxy quickly
  • LenR
    • Sep 2009
    • 1011
    Have you looked at this section of the web interface? https://www.zabbix.com/documentation...stration/queue
    If a host is unreachable, it's items will count as delayed, disabling a unreachable host should clear it's delayed items (may not be instant). Typically a few problem hosts cut down a lot of items.
    • linor
      • Apr 2017
      Hi LenR,
      Thanks for anwser me.
      Yes I have looked the queue section on zabbix documentation.
      Hosts that has items delayed are not unreachable. Actually I'm able to use zabbix_get from the zabbix_proxy and get metrics quicly.
      I'm suspecting of the database, but I don't have evidences on that.
      Do you have some tips that what else I can check?
      Thank you.
      • LenR
        • Sep 2009
        • 1011
        Yes, if you can't get the data written to the database in a timely manner, it can appear as a large queue. What is your NVPS rate? What is the iowait% on the zabbix db server? Do you have the zabbix server template applied to your server? It has good metrics and alerts for server performance. Are there network problems between the proxy and server? We have found it best to run a zabbix "node" with the server and mysql db on the same host, but offload most of the monitoring to proxies. Run some of the mysqltuner tools to validate your db environment.
        • kloczek
          • Jun 2006
          • 1771
          Add monitoring of the database. This is for what zabbix is.
          • linor
            • Apr 2017
            This problem was solved. In fact was a database problem.
