Problème with frontend simple quote added
  • jcduss59
    • Jun 2011
    • 33
    Since I've upgraded the frontend of zabbix from version 1.8.10 to 1.8.18, i've got troubles with quote....
    I use apache 2.2.16 and php5.3.3 on debian squeeze
    First :
    If I logout/ login to the frontend, My url is extended with comma like this :
    https://myzabbixdashboard/'dashboard.php'
    (note the quote around dashboard.php)
    If I was previously on screen page, then the logout/logout will try to connect me to :
    https://myzabbixdashboard/'screen.php'
    The url is off course not reachable. I need to remove the quote.
    Secondly :
    If I use filters on items for an host, I search for all unsupported items, I remove the host name, then click again on filter, I've got the unsupported items for all hosts.
    If on the host list, I click on an host, my filters become like this :
    host = ''
    applications = ''
    description = ''
    And the result is empty.
    Where are added those quotes ???
    Thank you!
  • jcduss59
    • Jun 2011
    • 33
    It seems this is a reported and solved bug!
    Let's upgrade then!
