Remote command repeated
  • Samuel
    • Apr 2008
    • 26
    I configured an action to send SMS by AWS.
    It worked perfect some days, but today, when a problem happen, the same remote command is executed many times, like attached.
    is it a bug?
  • sancho
    • Mar 2015
    • 301
    Hi samuel,
    Check the configuration of the action, in "Operation details", in steps set it 1-1.
    I hope this helps.
    A greeting.
    • Samuel
      • Apr 2008
      • 26
      Hi Sancho.
      It is setted like you can see in this new attached image.
      • sancho
        • Mar 2015
        • 301
        Hi samuel,
        In "Default operation step duration" how long have you set ???
        I see that you assigned that action to a group of hosts?
        Could it be that each "Remote command" that is seen corresponds to each host of that group ???
        • Samuel
          • Apr 2008
          • 26
          Sancho,
          ever "default operation step duration" was setted 0.
          Yes, In this action I assigned that action for a group of hosts because it is required, as you can see in this message "You did not specify targets for action operation command "aws sns publish......"
          Good question. In target list, now I setted "current host", and I´ll test.
          The result I´ll post here.
          thanks for you insides sancho.
          • Samuel
            • Apr 2008
            • 26
            Sancho, Worked perfectly.
            thanks for your help.
            • sancho
              • Mar 2015
              • 301
              I'm glad I helped.
              A greeting.
