Hello everyone.
I have some trouble with my zabbix-agentd on a host.
When I changed local date and time on my host (current date and time plus one day), everything has been ok.
But, after that I changed date and time (changed local date and time to current date and time). When I has been done it, zabbix-agentd quit its job.
All keys what was send from zabbix server after this manipulation don't execute on a host. And zabbix agetnd log haven't any exception about that.
On a host installed openSUSE OS.
On a zabbix server installed Zabbix 2.2.
Service zabbix agentd don't stop its work on a client (I checked using linux command: service zabbix-agentd status).
Example:
zabbix-agentd.service - Zabbix Monitor Agent
Loaded: loaded (/usr/lib/systemd/system/zabbix-agentd.service; disabled)
Active: active (exited) since Thu, 2018-03-29 15:12:48 EEST; 1h 25min ago
Process: 31706 ExecStart=/usr/sbin/zabbix_agentd (code=exited, status=0/SUCCESS)
CGroup: name=systemd:/system/zabbix-agentd.service
├ 31708 /usr/sbin/zabbix_agentd
├ 31709 /usr/sbin/zabbix_agentd: collector [idle 1 sec]
├ 31710 /usr/sbin/zabbix_agentd: listener #1 [waiting for connection]
├ 31711 /usr/sbin/zabbix_agentd: listener #2 [waiting for connection]
├ 31712 /usr/sbin/zabbix_agentd: listener #3 [waiting for connection]
└ 31713 /usr/sbin/zabbix_agentd: active checks #1 [idle 1 sec]
My zabbix-agentd.conf:
LogFile=/var/log/zabbix/zabbix_agentd.log
Timeout=30
EnableRemoteCommands=1
UnsafeUserParameters=1
Hostname=kassa-2012-1.sh.atbmarket.com
DebugLevel=4
Server=172.18.68.17
ServerActive=172.18.68.17
UserParameter=i_hw_hddtemp,sudo /usr/sbin/smartctl -a /dev/sda |grep Temperature_Celsius | grep Old_age | awk {' print $10 '}
UserParameter=i_hw_hddser,sudo /usr/sbin/smartctl -a /dev/sda | grep "Serial Number" | awk {' print $3 '}
UserParameter=i_hw_mbser,sh /opt/sh/get_data_monitoring.sh|grep "Serial Number:" | awk {' print $3 '}
UserParameter=i_hw_mbname,sh /opt/sh/get_data_monitoring.sh| grep "Product Name:" | awk {' print $3 '}
UserParameter=i_hw_cputemp,sh /opt/sh/cpu_temp.sh
UserParameter=i_psp_rpm_pspupdatever,rpm -qv psp-update
UserParameter=i_psp_rpm_pspver,rpm -qv psp
UserParameter=i_psp_pspver,echo -n `cat /home/user/bin/psp/psp.ver | awk {' print $1'}`
UserParameter=i_psp_pspconfver,echo -n `cat /home/user/bin/psp/psp_config.ver | awk {' print $1 '}`
UserParameter=i_psp_replver,echo -n `cat /home/user/bin/replicator/replicator.ver | awk {' print $1 '}`
UserParameter=i_psp_replconfver,echo -n `cat /home/user/bin/replicator/replicator_config.ver | awk {' print $1 '}`
UserParameter=i_os_cpuinfo,cat /proc/cpuinfo | grep -m1 "model name" | cut -d: -f2
UserParameter=i_psp_nrro,isql-fb -u sysdba -p posmaster localhost:/home/user/bin/db/client.fdb -ch utf8 -i /opt/sh/i_psp_nrro.sql |tail -n2 | head -n1 | awk '{ print $1 }'
UserParameter=i_psp_dbclientver,cat /home/user/bin/db/dbclient.ver | awk {' print $1 '}
UserParameter=i_os_ip[*],/sbin/ifconfig $1 | grep "inet addr" | awk '{ print $$2 }' | cut -d: -f2
UserParameter=i_os_mac[*],/sbin/ifconfig $1 | grep HWaddr | awk '{ print $$5 }'
# UserParameter=i_hash_db,echo 'select * from PS_HashAllStructur_SELECT;' > /tmp/123.sql | isql-fb -u sysdba -p posmaster localhost:/home/user/bin/db/client.fdb -ch utf8 -i /tmp/123.sql |awk {'print $1'}|tail -n2|head -n1
UserParameter=i_hash_db_client,echo 'select * from PS_HashAllStructur_SELECT;' > /tmp/123.sql | isql-fb -u sysdba -p posmaster localhost:/home/user/bin/db/client.fdb -ch utf8 -i /tmp/123.sql |awk {'print $1'}|tail -n2|head -n1
UserParameter=i_md5_psp,/usr/bin/md5sum /home/user/bin/psp/PosServicePro.exe | awk {' print $1 '}
UserParameter=i_md5_replic,/usr/bin/md5sum /home/user/bin/replicator/Replic.exe | awk {' print $1 '}
UserParameter=i_rpm_status,tail -n1 /opt/STATUS_INSTALL_RPM | grep FINISH | wc -l
UserParameter=i_diff_db_size,[[ -e /home/user/bin/db/diff/client.diff ]] && du -s /home/user/bin/db/diff/client.diff | awk {' print $1 '} || echo -n "0"
UserParameter=i_fbqry[*],sh /home/user/bin/queryfirebird.sh $1 "$2"
Maybe somebody knows about problem like that. How did you resolve it?
Please, help me.
Best regards BK.
Example:
Timeout=30
DebugLevel=4
Server=172.18.68.17
Please, help me.
Best regards BK.
