Problematic Query in Zabbix
  • tammyt
    • Mar 2017
    • 11
    Hello there
    For a few weeks now I have been have problems with this query
    "SELECT h.* FROM history_uint h WHERE (h.itemid BETWEEN '651600' AND '651651' OR h.itemid BETWEEN '651660' AND '651671' OR h.itemid BETWEEN '651673' AND '651677' OR h.itemid BETWEEN '651681' AND '651750' OR h.itemid BETWEEN '651844' AND '651868' OR h.itemid BETWEEN '651874' AND '651881' OR h.itemid BETWEEN '651883' AND '651889' OR h.itemid BETWEEN '651891' AND '651923' OR h.itemid BETWEEN '651925' AND '651936' OR h.itemid BETWEEN '875746' AND '875750' OR h.itemid BETWEEN '1374509' AND '1374514' OR h.itemid IN ('651653','651654','651655','651657','651658','651 679','651870','651871','736559','741031','741032', '751589','789537','804598','811651','877500','8775 01','953831','957805','957806','961030','985045',' 1041493','1041494','1041495','1109733','1109734',' 1120543','1120544','1144970','1144971','1160945',' 1201127','1380676','1380677','1386334','1418475',' 1492880','1506486','1512747','1539725','1539726',' 1539727')) AND h.clock>='1522033200' AND h.clock<='1522072034' ORDER BY h.clock"
    Zabbix keeps sending lots of this same query (changing only the period in the h.clock), and the query keeps geting stuck, making the database CPU go 100%.
    I asked the help of a DBA, as I didnt change anything in the zabbix and this problem started out of nowhere, and he tried lots of things, including indexing this select, and the problem continues.
    Someone knows what this query does and why zabbix started sending so many of those? I am lost
    Thank you
  • LenR
    • Sep 2009
    • 1011
    Is this during a time when housekeeper is running? If not, it's either server or frontend action causing the trigger. I use myphpadmin to find decode the itemid back to a host item but there are many ways. Then check that you don't have "expensive" triggers on that item or users flogging the GUI.
    • tammyt
      • Mar 2017
      • 11
      No
      The DB server is all closed in amazon, and only accessible via zbx server(console only)
      I am sorry, but i have really little knowledge in db, so i dont even know how to check what is those itemids (a simple select would work?)
      About the users, only 3 admin users access the GUI of Zabbix, but we gave a Grafana connecting to the zabbix API. If thats the cause, how could I check which dashboard is the villain?
      Thank you very much for the help
      • dimir
        Zabbix developer
        • Apr 2011
        • 1080
        This SQL comes from frontend because all server SQL statements are lower-cased. Check which frontend pages you have opened, looks like "Monitoring -> Latest data".
