Text item requires numeric float in trigger? BUG
  • siegmarb
    • Nov 2014
    • 25
    Item Type: Text
    Trigger:
    ({postfix_Mailserver_Queue:system.run["postqueue -p | grep '\d{2}:\d{2}:\d{2}' || echo 0"].last()}<>0) and
    ({postfix_Mailserver_Queue:system.run["postqueue -p | grep '\d{2}:\d{2}:\d{2}' || echo 0"].change()}=0)
    Cannot evaluate expression: expected numeric token at "69F1B2772 3464 Tue Apr 3 11:10:22 [email protected])<>0) and
    (1=0)".
    This looks like a bug or am i missing something?
  • dimir
    Zabbix developer
    • Apr 2011
    • 1080
    Just tried in latest trunk it looks fine. Which version is that?
    • siegmarb
      • Nov 2014
      • 25
      It's 3.4.7. latest stable.
      • Atsushi
        • Aug 2013
        • 2028
        Please check the first part of the trigger expression.
        Since you are using last(), the left side of the trigger expression is text type.
        If you want compare 0 with trigger expressions, the value of the item you compare will need to be a number.
        Text and numbers can not be compared directly.
        If you want to compare with text, the function should use regexp() or str().
        • siegmarb
          • Nov 2014
          • 25
          DOH! Thank you - thats it!
