Anyone can success use remote command with customer script for terraform
  • williewoo
    • Apr 2018
    I am using zabbix on premise, I want to use remote command and execute a terraform on a specified host
    It works for some common Linux command, but cannot execute the terraform command
  • aigars.kadikis
    • Mar 2018
    • 208
    Hi, williewoo!
    Be aware that remote commands is executed by user zabbix.
    Please, take a look is there is any environment assigned to user zabbix:
    grep zabbix /etc/passwd
    Another shot is to test you command directly from zabbix users perspective using just exact environment 'bash'
    sudo -H -u zabbix bash -c 'your custom terraform command'
    Does the outcome is what you desired for?
    Regards,
    Aigars
