Trgiger status Problem - after restore database
  • vso
    Zabbix developer
    • Aug 2016
    • 190
    #31
    it should be safe to delete problems that cannot exist, as per foreign key constraint:
    delete from problem where eventid=9775;
    delete from problem where eventid=17661;
    Something gone wrong during backup. Did you stop zabbix server when performing backup ?
    • lukisec
      • Apr 2018
      • 22
      #32
      i think that yes. ok but can i delete all this problems where evenetid=xxx ? Because there is a lot of this numbers
      • vso
        Zabbix developer
        • Aug 2016
        • 190
        #33
        You need to ensure that this foreign key is respected:
        CONSTRAINT `c_problem_1` FOREIGN KEY (`eventid`) REFERENCES `events` (`eventid`) ON DELETE CASCADE,
        Did you disable foreign key checks when importing database ?
        • lukisec
          • Apr 2018
          • 22
          #34
          Thank you for your help,
          no i dont disable this.
          when i try:
          MariaDB [zabbix]> CONSTRAINT `c_problem_1` FOREIGN KEY (`eventid`) REFERENCES `events` (`eventid`) ON DELETE CASCADE;
          ERROR 1064 (42000): You have an error in your SQL syntax; check the manual that corresponds to your MariaDB server version for the right syntax to use near 'CONSTRAINT `c_problem_1` FOREIGN KEY (`eventid`) REFERENCES `events` (`eventid`)' at line 1
          • lukisec
            • Apr 2018
            • 22
            #35
            Could you tell me, it is possible to delete all ?
            • vso
              Zabbix developer
              • Aug 2016
              • 190
              #36
              Can you please show output of following query ?
              select eventid from problem p where not exists (select null from events e where e.eventid=p.eventid);
              • lukisec
                • Apr 2018
                • 22
                #37
                | eventid |
                |       1 |
                |       2 |
                |      17 |
                |      18 |
                |      20 |
                |      21 |
                |      22 |
                |      24 |
                |      25 |
                |      42 |
                |      45 |
                |      46 |
                |      47 |
                |      48 |
                |      49 |
                |      50 |
                |      51 |
                |      52 |
                |      53 |
                |      54 |
                |      55 |
                |      56 |
                |      57 |
                |      58 |
                |      59 |
                |      60 |
                |      61 |
                |      62 |
                |      63 |
                |      64 |
                |      65 |
                |      66 |
                |      67 |
                |      69 |
                |      71 |
                |      72 |
                |      73 |
                |      74 |
                |      76 |
                |      77 |
                |      78 |
                |      79 |
                |      80 |
                |      81 |
                |      83 |
                |      84 |
                |      85 |
                |      86 |
                |      87 |
                |      89 |
                |      90 |
                |      91 |
                |      92 |
                |      93 |
                |      94 |
                |      95 |
                |      96 |
                |      97 |
                |      98 |
                |      99 |
                |     100 |
                |     101 |
                |     102 |
                |     103 |
                |     104 |
                |     105 |
                |     108 |
                |     109 |
                |     110 |
                |     111 |
                |     112 |
                |     113 |
                |     116 |
                |     129 |
                |     130 |
                |     131 |
                |     132 |
                |     136 |
                |     137 |
                |     139 |
                |     140 |
                |     141 |
                |     142 |
                |     143 |
                |     144 |
                |     145 |
                |     146 |
                |     147 |
                |     148 |
                |     149 |
                |     150 |
                |     151 |
                |     152 |
                |     153 |
                |     155 |
                |     156 |
                |     157 |
                |     158 |
                |     159 |
                |     183 |
                |     209 |
                |     210 |
                |     221 |
                |     222 |
                |     233 |
                |     234 |
                |     235 |
                |     236 |
                |     237 |
                |     252 |
                |     253 |
                |     258 |
                |     259 |
                |     261 |
                |     262 |
                |     263 |
                |     267 |
                |     269 |
                |     270 |
                |     271 |
                |     272 |
                |     273 |
                |     274 |
                |     275 |
                |     277 |
                |     278 |
                |     279 |
                |     280 |
                |     282 |
                |     285 |
                |     286 |
                |     287 |
                |     292 |
                |     295 |
                |     302 |
                |     303 |
                |     305 |
                |     318 |
                |     321 |
                |     323 |
                |     324 |
                |     325 |
                |     360 |
                |     369 |
                |     370 |
                |     372 |
                |     378 |
                |     380 |
                |     382 |
                |     383 |
                |     386 |
                |     388 |
                |     393 |
                |     401 |
                |     406 |
                |     424 |
                |     439 |
                |     441 |
                |     527 |
                |     528 |
                |     529 |
                |     530 |
                |     531 |
                |     532 |
                |     533 |
                |     534 |
                |     535 |
                |     536 |
                |     537 |
                |     538 |
                |     539 |
                |     540 |
                |     541 |
                |     542 |
                |     543 |
                |     544 |
                |     546 |
                |     547 |
                |     548 |
                |     549 |
                |     550 |
                |     551 |
                |     577 |
                |     578 |
                |     629 |
                |     631 |
                |     649 |
                |     650 |
                |     655 |
                |     656 |
                |     657 |
                |     661 |
                |     662 |
                |     665 |
                |     687 |
                |     688 |
                |     722 |
                |     769 |
                |     771 |
                |     824 |
                |     826 |
                |     835 |
                |     839 |
                |    1071 |
                |    1072 |
                |    1133 |
                |    1135 |
                |    1137 |
                |    1190 |
                |    1214 |
                |    1306 |
                |    1326 |
                |    1329 |
                |    1386 |
                |    1387 |
                |    1398 |
                |    1418 |
                |    1447 |
                |    1454 |
                |    1456 |
                |    1463 |
                |    1474 |
                |    1496 |
                |    1506 |
                |    1508 |
                |    1509 |
                |    1512 |
                |    1513 |
                |    1514 |
                |    1516 |
                |    1517 |
                |    1610 |
                |    1611 |
                |    1632 |
                |    1633 |
                |    1639 |
                |    1640 |
                |    1657 |
                |    1658 |
                |    1659 |
                |    1660 |
                |    1666 |
                |    1745 |
                |    1758 |
                |    1760 |
                |    1767 |
                |    1778 |
                |    1816 |
                |    1840 |
                |    1841 |
                |    1842 |
                |    1857 |
                |    1903 |
                |    1904 |
                |    1970 |
                |    1996 |
                |    1997 |
                |    2020 |
                |    2065 |
                |    2080 |
                |    2081 |
                |    2091 |
                |    2136 |
                |    2137 |
                |    2194 |
                |    2228 |
                |    2334 |
                |    2385 |
                |    2386 |
                |    2387 |
                |    2388 |
                |    2389 |
                |    2390 |
                |    2415 |
                |    2470 |
                |    2475 |
                |    2476 |
                |    2477 |
                |    2478 |
                |    2479 |
                |    2480 |
                |    2481 |
                |    2482 |
                |    2483 |
                |    2488 |
                |    2492 |
                |    2520 |
                |    2596 |
                |    2638 |
                |    2685 |
                |    2767 |
                |    2768 |
                |    2769 |
                |    2770 |
                |    2771 |
                |    2772 |
                |    2796 |
                |    2909 |
                |    2960 |
                |    3020 |
                |    3056 |
                |    3087 |
                |    3098 |
                |    3099 |
                |    3106 |
                |    3107 |
                |    3136 |
                |    3160 |
                |    3161 |
                |    3163 |
                |    3207 |
                |    3208 |
                |    3218 |
                |    3263 |
                |    3314 |
                |    3378 |
                |    3428 |
                |    3433 |
                |    3434 |
                |    3435 |
                |    3436 |
                |    3437 |
                |    3438 |
                |    3481 |
                |    3583 |
                |    3622 |
                |    3653 |
                |    3745 |
                |    3778 |
                |    3779 |
                |    3796 |
                |    3800 |
                |    3815 |
                |    3816 |
                |    3820 |
                |    3852 |
                |    3853 |
                |    3904 |
                |    4143 |
                |    4237 |
                |    4342 |
                |    4389 |
                |    4404 |
                |    4412 |
                |    4442 |
                |    4652 |
                |    4806 |
                |    4952 |
                |    4953 |
                |    4971 |
                |    4975 |
                |    4976 |
                |    5002 |
                |    5151 |
                |    5304 |
                |    5388 |
                |    5434 |
                |    5539 |
                |    5542 |
                |    5544 |
                |    5570 |
                |    5571 |
                |    5619 |
                |    5766 |
                |    5872 |
                |    5873 |
                |    5876 |
                |    5898 |
                |    5905 |
                |    5943 |
                |    5944 |
                |    5951 |
                |    5972 |
                |    5974 |
                |    6047 |
                |    6066 |
                |    6095 |
                |    6113 |
                |    6118 |
                |    6122 |
                |    6146 |
                |    6147 |
                |    6321 |
                |    6390 |
                |    6434 |
                |    6438 |
                |    6462 |
                |    6467 |
                |    6504 |
                |    6556 |
                |    6641 |
                |    6643 |
                |    6658 |
                |    6663 |
                |    6690 |
                |    6691 |
                |    6692 |
                |    6699 |
                |    6744 |
                |    6783 |
                |    6788 |
                |    6818 |
                |    6828 |
                |    6831 |
                |    6867 |
                |    6942 |
                |    6943 |
                |    6965 |
                |    6967 |
                |    6969 |
                |    6977 |
                |    7000 |
                |    7037 |
                |    7079 |
                |    7116 |
                |    7117 |
                |    7118 |
                |    7164 |
                |    7202 |
                |    7239 |
                |    7240 |
                |    7244 |
                |    7251 |
                |    7274 |
                |    7275 |
                |    7285 |
                |    7320 |
                |    7384 |
                |    7396 |
                |    7402 |
                |    7436 |
                |    7445 |
                |    7452 |
                |    7531 |
                |    7547 |
                |    7552 |
                |    7569 |
                |    7592 |
                |    7593 |
                |    7617 |
                |    7666 |
                |    7680 |
                |    7695 |
                |    7719 |
                |    7729 |
                |    7756 |
                |    7791 |
                |    7795 |
                |    7796 |
                |    7819 |
                |    7831 |
                |    7833 |
                |    7885 |
                |    7905 |
                |    8039 |
                |    8063 |
                |    8082 |
                |    8100 |
                |    8105 |
                |    8115 |
                |    8134 |
                |    8193 |
                |    8201 |
                |    8227 |
                |    8264 |
                |    8326 |
                |    8335 |
                |    8337 |
                |    8340 |
                |    8364 |
                |    8365 |
                |    8378 |
                |    8410 |
                |    8412 |
                |    8423 |
                |    8495 |
                |    8520 |
                |    8551 |
                |    8561 |
                |    8598 |
                |    8613 |
                |    8637 |
                |    8653 |
                |    8657 |
                |    8681 |
                |    8682 |
                |    8700 |
                |    8720 |
                |    8752 |
                |    8793 |
                |    8832 |
                |    8833 |
                |    8904 |
                |    8909 |
                |    8930 |
                |    8936 |
                |    8952 |
                |    8973 |
                |    8980 |
                |    9059 |
                |    9075 |
                |    9118 |
                |    9126 |
                |    9159 |
                |    9165 |
                |    9210 |
                |    9230 |
                |    9231 |
                |    9234 |
                |    9261 |
                |    9264 |
                |    9279 |
                |    9281 |
                |    9297 |
                |    9317 |
                |    9326 |
                |    9365 |
                |    9393 |
                |    9430 |
                |    9461 |
                |    9468 |
                |    9496 |
                |    9523 |
                |    9539 |
                |    9547 |
                |    9577 |
                |    9628 |
                |    9669 |
                |    9676 |
                |    9704 |
                |    9716 |
                |    9721 |
                |    9735 |
                |    9743 |
                |    9773 |
                |    9788 |
                |    9790 |
                |    9803 |
                |    9804 |
                |    9808 |
                |    9825 |
                |    9838 |
                |    9839 |
                |    9840 |
                |    9841 |
                |    9869 |
                |    9873 |
                |    9885 |
                |    9896 |
                |    9987 |
                |    9994 |
                |    9995 |
                |   10013 |
                |   10030 |
                |   10031 |
                |   10035 |
                |   10054 |
                |   10062 |
                |   10090 |
                |   10104 |
                |   10112 |
                |   10113 |
                |   10150 |
                |   10153 |
                |   10173 |
                |   10185 |
                |   10192 |
                |   10228 |
                |   10236 |
                |   10245 |
                |   10246 |
                |   10247 |
                |   10276 |
                |   10277 |
                |   10281 |
                |   10283 |
                |   10314 |
                |   10316 |
                |   10317 |
                |   10326 |
                |   10336 |
                |   10390 |
                |   10394 |
                |   10416 |
                |   10420 |
                |   10426 |
                |   10427 |
                |   10461 |
                |   10526 |
                |   10560 |
                |   10564 |
                |   10601 |
                |   10609 |
                |   10612 |
                |   10617 |
                |   10618 |
                |   10630 |
                |   10631 |
                |   10633 |
                |   10635 |
                |   10665 |
                |   10702 |
                |   10710 |
                |   10738 |
                |   10763 |
                |   10764 |
                |   10770 |
                |   10799 |
                |   10804 |
                |   10826 |
                |   10909 |
                |   10925 |
                |   10933 |
                |   10970 |
                |   10973 |
                |   10977 |
                |   11005 |
                |   11012 |
                |   11047 |
                |   11048 |
                |   11052 |
                |   11053 |
                |   11068 |
                |   11069 |
                |   11109 |
                |   11139 |
                |   11181 |
                |   11186 |
                |   11189 |
                |   11209 |
                |   11216 |
                |   11259 |
                |   11260 |
                |   11269 |
                |   11282 |
                |   11287 |
                |   11321 |
                |   11349 |
                |   11458 |
                |   11484 |
                |   11496 |
                |   11507 |
                |   11526 |
                |   11530 |
                |   11543 |
                |   11560 |
                |   11561 |
                |   11638 |
                |   11750 |
                |   11756 |
                |   11784 |
                |   11787 |
                |   11788 |
                |   11799 |
                |   11854 |
                |   11934 |
                |   11941 |
                |   11950 |
                |   11992 |
                |   12042 |
                |   12071 |
                |   12082 |
                |   12089 |
                |   12096 |
                |   12131 |
                |   12138 |
                |   12173 |
                |   12223 |
                |   12230 |
                |   12231 |
                |   12276 |
                |   12280 |
                |   12281 |
                |   12283 |
                |   12285 |
                |   12315 |
                |   12324 |
                |   12325 |
                |   12353 |
                |   12413 |
                |   12431 |
                |   12482 |
                |   12492 |
                |   12522 |
                |   12549 |
                |   12570 |
                |   12587 |
                |   12598 |
                |   12646 |
                |   12649 |
                |   12655 |
                |   12663 |
                |   12668 |
                |   12674 |
                |   12705 |
                |   12706 |
                |   12764 |
                |   12791 |
                |   12806 |
                |   12817 |
                |   12834 |
                |   12838 |
                |   12859 |
                |   12860 |
                |   12865 |
                |   12866 |
                |   12870 |
                |   12896 |
                |   12906 |
                |   12911 |
                |   12915 |
                |   12938 |
                |   12959 |
                |   12977 |
                |   13094 |
                |   13101 |
                |   13131 |
                |   13169 |
                |   13204 |
                |   13208 |
                |   13216 |
                |   13232 |
                |   13239 |
                |   13251 |
                |   13255 |
                |   13263 |
                |   13264 |
                |   13269 |
                |   13287 |
                |   13291 |
                |   13327 |
                |   13332 |
                |   13377 |
                |   13383 |
                |   13425 |
                |   13443 |
                |   13464 |
                |   13469 |
                |   13472 |
                |   13474 |
                |   13489 |
                |   13494 |
                |   13499 |
                |   13500 |
                |   13504 |
                |   13525 |
                |   13539 |
                |   13547 |
                |   13576 |
                |   13592 |
                |   13595 |
                |   13617 |
                |   13618 |
                |   13632 |
                |   13671 |
                |   13696 |
                |   13698 |
                |   13699 |
                |   13725 |
                |   13728 |
                |   13739 |
                |   13740 |
                |   13751 |
                |   13812 |
                |   13825 |
                |   13835 |
                |   13858 |
                |   13862 |
                |   13892 |
                |   13893 |
                |   13919 |
                |   13934 |
                |   14028 |
                |   14034 |
                |   14040 |
                |   14043 |
                |   14068 |
                |   14128 |
                |   14130 |
                |   14140 |
                |   14165 |
                |   14173 |
                |   14204 |
                |   14231 |
                |   14287 |
                |   14302 |
                |   14311 |
                |   14401 |
                |   14422 |
                |   14426 |
                |   14428 |
                |   14435 |
                |   14449 |
                |   14455 |
                |   14476 |
                |   14492 |
                |   14506 |
                |   14517 |
                |   14518 |
                |   14541 |
                |   14542 |
                |   14560 |
                |   14566 |
                |   14569 |
                |   14597 |
                |   14598 |
                |   14628 |
                |   14641 |
                |   14659 |
                |   14673 |
                |   14683 |
                |   14687 |
                |   14688 |
                |   14689 |
                |   14690 |
                |   14691 |
                |   14692 |
                |   14693 |
                |   14727 |
                |   14729 |
                |   14763 |
                |   14768 |
                |   14769 |
                |   14786 |
                |   14806 |
                |   14811 |
                |   14824 |
                |   14875 |
                |   14882 |
                |   14883 |
                |   14912 |
                |   14939 |
                |   14940 |
                |   14962 |
                |   14997 |
                |   15018 |
                |   15032 |
                |   15033 |
                |   15042 |
                |   15046 |
                |   15069 |
                |   15071 |
                |   15093 |
                |   15105 |
                |   15107 |
                |   15114 |
                |   15152 |
                |   15173 |
                |   15174 |
                |   15203 |
                |   15216 |
                |   15221 |
                |   15222 |
                |   15235 |
                |   15240 |
                |   15270 |
                |   15277 |
                |   15278 |
                |   15309 |
                |   15311 |
                |   15333 |
                |   15334 |
                |   15361 |
                |   15383 |
                |   15386 |
                |   15393 |
                |   15416 |
                |   15424 |
                |   15434 |
                |   15457 |
                |   15458 |
                |   15480 |
                |   15490 |
                |   15493 |
                |   15520 |
                |   15540 |
                |   15543 |
                |   15547 |
                |   15569 |
                |   15582 |
                |   15614 |
                |   15632 |
                |   15648 |
                |   15654 |
                |   15685 |
                |   15686 |
                |   15689 |
                |   15724 |
                |   15732 |
                |   15748 |
                |   15749 |
                |   15753 |
                |   15778 |
                |   15781 |
                |   15783 |
                |   15845 |
                |   15875 |
                |   15903 |
                |   16176 |
                |   16200 |
                |   16204 |
                |   16231 |
                |   16277 |
                |   16278 |
                |   16287 |
                |   16378 |
                |   16418 |
                |   16430 |
                |   16534 |
                |   16535 |
                |   16611 |
                |   16710 |
                |   16748 |
                |   16771 |
                |   16777 |
                |   16808 |
                |   16809 |
                |   16853 |
                |   16887 |
                |   16930 |
                |   16977 |
                |   17004 |
                |   17011 |
                |   17071 |
                |   17119 |
                |   17258 |
                |   17314 |
                |   17315 |
                |   17317 |
                |   17319 |
                |   17344 |
                |   17345 |
                |   17400 |
                |   17406 |
                |   17451 |
                |   17505 |
                |   17548 |
                |   17562 |
                |   17563 |
                |   17564 |
                |   17567 |
                |   17602 |
                |   17631 |
                |   17719 |
                |   17720 |
                |   17736 |
                |   17772 |
                |   17787 |
                |   17812 |
                |   17822 |
                |   17845 |
                |   17846 |
                |   17869 |
                |   17876 |
                |   17887 |
                |   17894 |
                |   17898 |
                |   17910 |
                |   17923 |
                |   17924 |
                |   17925 |
                |   17926 |
                |   17934 |
                |   17962 |
                |   17963 |
                |   17974 |
                |   17990 |
                |   18000 |
                |   18029 |
                |   18042 |
                |   18089 |
                |   18151 |
                |   18183 |
                |   18196 |
                |   18260 |
                |   18288 |
                |   18304 |
                |   18309 |
                |   18349 |
                |   18379 |
                |   18404 |
                |   18417 |
                |   18462 |
                |   18463 |
                |   18484 |
                |   18487 |
                |   18524 |
                |   18525 |
                |   18564 |
                |   18600 |
                |   18646 |
                |   18653 |
                |   18686 |
                |   18700 |
                |   18738 |
                |   18739 |
                |   18784 |
                |   18785 |
                |   18788 |
                |   18843 |
                |   18865 |
                |   18905 |
                |   18912 |
                |   18921 |
                |   18953 |
                |   19009 |
                |   19028 |
                |   19059 |
                |   19102 |
                |   19142 |
                |   19150 |
                |   19159 |
                |   19195 |
                |   19246 |
                |   19345 |
                |   19429 |
                |   19471 |
                |   19480 |
                |   19495 |
                |   19496 |
                |   19525 |
                |   19534 |
                |   19586 |
                |   19591 |
                |   19617 |
                |   19618 |
                |   19626 |
                |   19636 |
                |   19637 |
                |   19640 |
                |   19665 |
                |   19668 |
                |   19711 |
                |   19712 |
                |   19753 |
                |   19865 |
                |   19940 |
                |   20074 |
                |   20076 |
                |   20077 |
                |   20078 |
                |   20079 |
                |   20080 |
                |   20081 |
                |   20082 |
                |   20083 |
                |   20084 |
                |   20095 |
                |   20099 |
                |   20100 |
                |   20101 |
                |   20102 |
                |   20103 |
                |   20104 |
                |   20105 |
                |   20106 |
                |   20107 |
                |   20108 |
                |   20109 |
                |   20110 |
                |   20111 |
                |   20112 |
                |   20113 |
                |   20114 |
                |   20115 |
                |   20116 |
                |   20117 |
                |   20118 |
                |   20119 |
                |   20120 |
                |   20121 |
                |   20122 |
                |   20145 |
                |   20161 |
                |   20165 |
                |   20197 |
                |   20198 |
                |   20238 |
                |   20244 |
                |   20307 |
                |   20322 |
                |   20372 |
                |   20380 |
                |   20431 |
                |   20468 |
                |   20516 |
                |   20602 |
                |   20708 |
                |   23554 |
                |   24107 |
                |   24963 |
                |   24964 |
                |   25252 |
                |   25377 |
                |   25384 |
                |   25886 |
                |   26636 |
                |   26766 |
                |   27098 |
                |   27896 |
                |   27902 |
                |   28688 |
                |   28887 |
                |   29075 |
                |   30066 |
                |   30110 |
                |   30429 |
                |   30796 |
                |   30990 |
                |   31130 |
                |   31544 |
                |   31692 |
                |   31693 |
                |   31768 |
                |   31935 |
                |   31993 |
                |   32550 |
                |   32854 |
                |   33663 |
                |   35378 |
                |   36076 |
                |   36410 |
                |   37095 |
                |   39374 |
                |   39837 |
                |   40918 |
                |   41936 |
                |   42212 |
                |   42214 |
                |   42215 |
                |   43106 |
                |   43344 |
                |   44987 |
                |   45094 |
                |   45242 |
                |   45258 |
                |   45309 |
                |   45313 |
                |   46214 |
                |   46382 |
                |   46842 |
                |   46906 |
                |   46996 |
                |   47219 |
                |   47716 |
                |   48094 |
                |   48344 |
                |   49203 |
                |   49244 |
                |   49530 |
                |   49925 |
                |   50751 |
                |   51498 |
                |   53093 |
                |   53341 |
                |   53792 |
                |   54363 |
                |   54739 |
                |   55244 |
                |   56612 |
                |   59155 |
                |   59515 |
                |   59764 |
                |   60322 |
                |   60901 |
                |   61454 |
                |   61987 |
                |   62837 |
                |   63690 |
                |   64241 |
                |   64242 |
                |   64474 |
                |   64796 |
                |   64797 |
                |   66195 |
                |   67018 |
                |   67282 |
                |   67566 |
                |   67846 |
                |   68119 |
                |   68683 |
                |   69292 |
                |   69780 |
                |   69788 |
                |   70477 |
                |   70887 |
                |   72039 |
                |   72998 |
                |   74176 |
                |   74675 |
                |   74777 |
                |   76148 |
                |   76191 |
                |   76698 |
                |   77015 |
                |   77846 |
                |   79246 |
                |   79400 |
                |   79754 |
                |   80260 |
                |   80327 |
                |   80337 |
                |   80362 |
                |   80682 |
                |   81851 |
                |   82556 |
                |   83668 |
                |   84073 |
                |   87413 |
                |   88597 |
                |   88732 |
                |   89302 |
                |   89878 |
                |   90389 |
                |   91503 |
                |   92858 |
                |   92870 |
                |   93188 |
                |   93629 |
                |   93757 |
                |   93769 |
                |   94295 |
                |   94568 |
                |   94855 |
                |   96624 |
                |   96625 |
                |   97551 |
                |   98013 |
                |   98795 |
                |   98825 |
                |   98849 |
                |   98903 |
                |   98940 |
                |   99479 |
                |  100039 |
                |  100167 |
                |  100954 |
                |  102316 |
                |  103169 |
                |  103623 |
                |  103903 |
                |  104550 |
                |  104551 |
                |  105632 |
                |  106211 |
                |  107278 |
                |  107279 |
                |  107850 |
                |  108416 |
                |  108417 |
                |  108418 |
                |  108909 |
                |  109277 |
                |  109477 |
                |  109478 |
                |  109515 |
                |  109550 |
                |  109551 |
                |  110630 |
                |  110760 |
                |  111720 |
                |  111834 |
                |  112341 |
                |  112368 |
                |  112744 |
                |  112922 |
                |  112923 |
                |  112925 |
                |  112961 |
                |  114323 |
                |  114355 |
                |  114378 |
                |  114406 |
                |  114427 |
                |  114520 |
                |  114572 |
                |  114589 |
                |  114611 |
                |  114616 |
                |  114646 |
                |  114648 |
                |  114693 |
                |  114712 |
                |  114742 |
                |  114839 |
                |  114840 |
                |  114842 |
                |  114873 |
                |  114874 |
                |  114901 |
                |  114922 |
                |  114923 |
                |  114972 |
                |  114973 |
                |  115002 |
                |  115011 |
                |  115012 |
                |  115053 |
                |  115074 |
                |  115075 |
                |  115124 |
                |  115159 |
                |  115190 |
                |  115199 |
                |  115209 |
                |  115223 |
                |  115224 |
                |  115228 |
                |  115229 |
                |  115251 |
                |  115255 |
                |  115256 |
                |  115301 |
                |  115304 |
                |  115314 |
                |  115325 |
                |  115330 |
                |  115331 |
                |  115355 |
                |  115356 |
                |  115383 |
                |  115395 |
                |  115396 |
                |  115461 |
                |  115462 |
                |  115463 |
                |  115507 |
                |  115522 |
                |  115558 |
                |  115560 |
                |  115562 |
                |  115605 |
                |  115625 |
                |  115626 |
                |  115643 |
                |  115656 |
                |  115696 |
                |  115770 |
                |  115771 |
                |  115795 |
                |  115819 |
                |  115822 |
                |  115824 |
                |  115859 |
                |  115860 |
                |  115874 |
                |  115875 |
                |  115911 |
                |  115932 |
                |  115959 |
                |  116042 |
                |  116059 |
                |  116153 |
                |  116169 |
                |  116175 |
                |  116203 |
                |  116219 |
                |  116221 |
                |  116238 |
                |  116245 |
                |  116246 |
                |  116278 |
                |  116298 |
                |  116299 |
                |  116339 |
                |  116340 |
                |  116389 |
                |  116406 |
                |  116407 |
                |  116410 |
                |  116441 |
                |  116442 |
                |  116459 |
                |  116460 |
                |  116504 |
                |  116514 |
                |  116515 |
                |  116547 |
                |  116590 |
                |  116643 |
                |  116683 |
                |  116686 |
                |  116687 |
                |  116718 |
                |  116798 |
                |  116799 |
                |  116817 |
                |  116850 |
                |  116851 |
                |  116887 |
                |  116891 |
                |  116899 |
                |  116927 |
                |  116935 |
                |  116989 |
                |  117000 |
                |  117001 |
                |  117005 |
                |  117013 |
                |  117014 |
                |  117033 |
                |  117036 |
                |  117063 |
                |  117066 |
                |  117124 |
                |  117136 |
                |  117145 |
                |  117177 |
                |  117178 |
                |  117204 |
                |  117277 |
                |  117286 |
                |  117318 |
                |  117319 |
                |  117376 |
                |  117377 |
                |  117406 |
                |  117493 |
                |  117558 |
                |  117559 |
                |  117560 |
                |  117564 |
                |  117592 |
                |  117594 |
                |  117597 |
                |  117622 |
                |  117640 |
                |  117673 |
                |  117702 |
                |  117810 |
                |  117811 |
                |  117852 |
                |  117853 |
                |  117884 |
                |  117920 |
                |  117921 |
                |  117922 |
                |  117950 |
                |  117952 |
                |  118048 |
                |  118112 |
                |  118127 |
                |  118132 |
                |  118160 |
                |  118161 |
                |  118200 |
                |  118216 |
                |  118337 |
                |  118382 |
                |  118522 |
                |  118572 |
                |  118666 |
                |  118682 |
                |  118683 |
                |  118688 |
                |  118711 |
                |  118760 |
                |  118797 |
                |  118841 |
                |  118883 |
                |  118885 |
                |  118990 |
                |  119027 |
                |  119068 |
                |  119155 |
                |  119226 |
                |  119229 |
                |  119230 |
                |  119260 |
                |  119272 |
                |  119273 |
                |  119316 |
                |  119363 |
                |  119457 |
                |  119549 |
                |  119588 |
                |  119670 |
                |  119773 |
                |  119794 |
                |  119798 |
                |  119802 |
                |  119828 |
                |  119829 |
                |  119864 |
                |  119880 |
                |  119904 |
                |  120021 |
                |  120073 |
                |  120085 |
                |  120183 |
                |  120263 |
                |  120270 |
                |  120319 |
                |  120329 |
                |  120341 |
                |  120342 |
                |  120346 |
                |  120379 |
                |  120380 |
                |  120426 |
                |  120460 |
                |  120602 |
                |  120614 |
                |  120652 |
                |  120692 |
                |  120793 |
                |  120808 |
                |  120842 |
                |  120859 |
                |  120863 |
                |  120872 |
                |  120904 |
                |  120958 |
                |  121093 |
                |  121142 |
                |  121187 |
                |  121316 |
                |  121359 |
                |  121374 |
                |  121424 |
                |  121444 |
                |  121447 |
                |  121449 |
                |  121475 |
                |  121476 |
                |  121540 |
                |  121641 |
                |  121650 |
                |  121726 |
                |  121829 |
                |  121870 |
                |  121917 |
                |  121989 |
                |  121992 |
                |  121994 |
                |  122020 |
                |  122095 |
                |  122155 |
                |  122192 |
                |  122202 |
                |  122283 |
                |  122325 |
                |  122342 |
                |  122390 |
                |  122398 |
                |  122429 |
                |  122496 |
                |  122516 |
                |  122534 |
                |  122537 |
                |  122538 |
                |  122565 |
                |  122575 |
                |  122577 |
                |  122621 |
                |  122651 |
                |  122669 |
                |  122857 |
                |  122864 |
                |  122907 |
                |  122993 |
                |  123055 |
                |  123097 |
                |  123123 |
                |  123126 |
                |  123127 |
                |  123153 |
                |  123154 |
                |  123219 |
                |  123241 |
                |  123328 |
                |  123416 |
                |  123457 |
                |  123477 |
                |  123542 |
                |  123544 |
                |  123545 |
                |  123582 |
                |  123583 |
                |  123620 |
                |  123674 |
                |  123678 |
                |  123710 |
                |  123751 |
                |  123940 |
                |  123986 |
                |  123994 |
                |  124006 |
                |  124035 |
                |  124054 |
                |  124077 |
                |  124126 |
                |  124210 |
                |  124220 |
                |  124222 |
                |  124239 |
                |  124240 |
                |  124244 |
                |  124273 |
                |  124316 |
                |  124440 |
                |  124532 |
                |  124588 |
                |  124632 |
                |  124639 |
                |  124720 |
                |  124772 |
                |  124800 |
                |  124804 |
                |  124805 |
                |  124846 |
                |  124847 |
                |  124874 |
                |  124885 |
                |  124913 |
                |  124916 |
                |  124940 |
                |  124980 |
                |  124986 |
                |  125019 |
                |  125071 |
                |  125106 |
                |  125205 |
                |  125244 |
                |  125298 |
                |  125299 |
                |  125356 |
                |  125358 |
                |  125359 |
                |  125361 |
                |  125384 |
                |  125396 |
                |  125427 |
                |  125449 |
                |  125533 |
                |  125573 |
                |  125622 |
                |  125684 |
                |  125738 |
                |  125779 |
                |  125799 |
                |  125920 |
                |  125923 |
                |  125924 |
                |  125951 |
                |  125952 |
                |  126051 |
                |  126071 |
                |  126098 |
                |  126139 |
                |  126177 |
                |  126220 |
                |  126312 |
                |  126352 |
                |  126397 |
                |  126404 |
                |  126411 |
                |  126450 |
                |  126487 |
                |  126492 |
                |  126504 |
                |  126533 |
                |  126556 |
                |  126600 |
                |  126730 |
                |  126758 |
                |  126847 |
                |  126896 |
                |  126943 |
                |  126974 |
                |  126986 |
                |  127025 |
                |  127038 |
                |  127048 |
                |  127051 |
                |  127077 |
                |  127154 |
                |  127246 |
                |  127292 |
                |  127359 |
                |  127396 |
                |  127441 |
                |  127588 |
                |  127591 |
                |  127592 |
                |  127618 |
                |  127681 |
                |  127700 |
                |  127777 |
                |  127821 |
                |  127834 |
                |  127857 |
                |  127864 |
                |  127912 |
                |  127941 |
                |  127975 |
                |  127979 |
                |  128013 |
                |  128063 |
                |  128129 |
                |  128135 |
                |  128182 |
                |  128223 |
                |  128240 |
                |  128303 |
                |  128311 |
                |  128353 |
                |  128366 |
                |  128400 |
                |  128443 |
                |  128537 |
                |  128588 |
                |  128629 |
                |  128658 |
                |  128698 |
                |  128700 |
                |  128705 |
                |  128735 |
                |  128810 |
                |  128849 |
                |  128889 |
                |  129006 |
                |  129089 |
                |  129120 |
                |  129134 |
                |  129222 |
                |  129238 |
                |  129241 |
                |  129243 |
                |  129276 |
                |  129295 |
                |  129463 |
                |  129497 |
                |  129509 |
                |  129650 |
                |  129670 |
                |  129675 |
                |  129709 |
                |  129724 |
                |  129748 |
                |  129762 |
                |  129766 |
                |  129768 |
                |  129800 |
                |  129803 |
                |  129823 |
                |  129826 |
                |  129881 |
                |  129888 |
                |  129898 |
                |  129903 |
                |  130050 |
                |  130094 |
                |  130175 |
                |  130216 |
                |  130288 |
                |  130352 |
                |  130355 |
                |  130357 |
                |  130388 |
                |  130472 |
                |  130533 |
                |  130545 |
                |  130582 |
                |  130876 |
                |  130879 |
                |  130882 |
                |  130883 |
                |  130910 |
                |  130911 |
                |  130962 |
                |  131104 |
                |  131197 |
                |  131252 |
                |  131282 |
                |  131325 |
                |  131396 |
                |  131411 |
                |  131412 |
                |  131414 |
                |  131416 |
                |  131459 |
                |  131520 |
                |  131545 |
                |  131601 |
                |  131727 |
                |  131776 |
                |  131897 |
                |  131917 |
                |  131964 |
                |  131982 |
                |  131987 |
                |  132019 |
                |  132020 |
                |  132030 |
                |  132059 |
                |  132072 |
                |  132122 |
                |  132157 |
                |  132439 |
                |  132464 |
                |  132514 |
                |  132518 |
                |  132520 |
                |  132521 |
                |  132550 |
                |  132553 |
                |  132606 |
                |  132641 |
                |  132793 |
                |  132846 |
                |  132921 |
                |  132935 |
                |  132966 |
                |  133006 |
                |  133021 |
                |  133057 |
                |  133072 |
                |  133073 |
                |  133077 |
                |  133113 |
                |  133179 |
                |  133202 |
                |  133237 |
                |  133279 |
                |  133330 |
                |  133371 |
                |  133514 |
                |  133533 |
                |  133559 |
                |  133627 |
                |  133628 |
                |  133634 |
                |  133667 |
                |  133671 |
                |  133751 |
                |  133795 |
                |  133842 |
                |  133936 |
                |  134034 |
                |  134097 |
                |  134152 |
                |  134153 |
                |  134155 |
                |  134195 |
                |  134243 |
                |  134269 |
                |  134286 |
                |  134345 |
                |  134419 |
                |  134432 |
                |  134535 |
                |  134651 |
                |  134704 |
                |  134708 |
                |  134709 |
                |  134737 |
                |  134741 |
                |  134807 |
                |  134828 |
                |  134851 |
                |  134964 |
                |  134982 |
                |  135147 |
                |  135198 |
                |  135251 |
                |  135259 |
                |  135262 |
                |  135264 |
                |  135292 |
                |  135445 |
                |  135473 |
                |  135644 |
                |  135740 |
                |  135784 |
                |  135794 |
                |  135799 |
                |  135823 |
                |  135909 |
                |  135970 |
                |  136017 |
                |  136102 |
                |  136163 |
                |  136192 |
                |  136237 |
                |  136238 |
                |  136242 |
                |  136251 |
                |  136257 |
                |  136348 |
                |  136351 |
                |  136352 |
                |  136364 |
                |  136379 |
                |  136466 |
                |  136491 |
                |  136607 |
                |  136608 |
                |  136651 |
                |  136698 |
                |  136727 |
                |  136744 |
                |  136785 |
                |  136834 |
                |  136857 |
                |  136898 |
                |  136916 |
                |  136919 |
                |  136921 |
                |  136955 |
                |  136956 |
                |  136984 |
                |  137007 |
                |  137041 |
                |  137042 |
                |  137050 |
                |  137096 |
                |  137136 |
                |  137184 |
                |  137219 |
                |  137229 |
                |  137373 |
                |  137408 |
                |  137477 |
                |  137480 |
                |  137482 |
                |  137506 |
                |  137578 |
                |  137631 |
                |  137678 |
                |  137761 |
                |  137828 |
                |  137938 |
                |  137951 |
                |  137999 |
                |  138014 |
                |  138017 |
                |  138052 |
                |  138138 |
                |  138245 |
                |  138284 |
                |  138371 |
                |  138383 |
                |  138527 |
                |  138544 |
                |  138546 |
                |  138563 |
                |  138564 |
                |  138612 |
                |  138613 |
                |  138706 |
                |  138733 |
                |  138750 |
                |  138755 |
                |  138791 |
                |  138830 |
                |  138873 |
                |  139024 |
                |  139096 |
                |  139114 |
                |  139129 |
                |  139158 |
                |  139195 |
                |  139298 |
                |  139325 |
                |  139402 |
                |  139455 |
                |  139523 |
                |  139562 |
                |  139572 |
                |  139645 |
                |  139660 |
                |  139661 |
                |  139662 |
                |  139665 |
                |  139691 |
                |  139692 |
                |  139755 |
                |  139783 |
                |  139896 |
                |  139939 |
                |  139982 |
                |  140021 |
                |  140160 |
                |  140217 |
                |  140220 |
                |  140222 |
                |  140248 |
                |  140249 |
                |  140272 |
                |  140296 |
                |  140358 |
                |  140390 |
                |  140433 |
                |  140478 |
                |  140537 |
                |  140642 |
                |  140670 |
                |  140716 |
                |  140763 |
                |  140778 |
                |  140779 |
                |  140780 |
                |  140784 |
                |  140810 |
                |  140855 |
                |  141034 |
                |  141061 |
                |  141077 |
                |  141094 |
                |  141158 |
                |  141166 |
                |  141246 |
                |  141286 |
                |  141305 |
                |  141306 |
                |  141308 |
                |  141310 |
                |  141341 |
                |  141354 |
                |  141423 |
                |  141481 |
                |  141493 |
                |  141533 |
                |  141540 |
                |  141592 |
                |  141611 |
                |  141674 |
                |  141785 |
                |  141864 |
                |  141877 |
                |  141880 |
                |  141881 |
                |  141909 |
                |  141910 |
                |  141955 |
                |  141992 |
                |  142066 |
                |  142087 |
                |  142153 |
                |  142163 |
                |  142220 |
                |  142251 |
                |  142279 |
                |  142386 |
                |  142429 |
                |  142430 |
                |  142434 |
                |  142467 |
                |  142468 |
                |  142597 |
                |  142646 |
                |  142652 |
                |  142728 |
                |  142741 |
                |  142742 |
                |  142785 |
                |  142827 |
                |  142931 |
                |  142932 |
                |  142938 |
                |  142953 |
                |  142958 |
                |  143000 |
                |  143001 |
                |  143006 |
                |  143079 |
                |  143157 |
                |  143196 |
                |  143280 |
                |  143374 |
                |  143467 |
                |  143529 |
                |  143533 |
                |  143562 |
                |  143611 |
                |  143659 |
                |  143820 |
                |  143861 |
                |  143921 |
                |  144003 |
                |  144048 |
                |  144067 |
                |  144069 |
                |  144070 |
                |  144071 |
                |  144096 |
                |  144135 |
                |  144139 |
                |  144171 |
                |  144195 |
                |  144290 |
                |  144338 |
                |  144513 |
                |  144547 |
                |  144583 |
                |  144600 |
                |  144603 |
                |  144604 |
                |  144629 |
                |  144630 |
                |  144697 |
                |  144736 |
                |  144790 |
                |  144874 |
                |  144955 |
                |  144997 |
                |  145149 |
                |  145164 |
                |  145167 |
                |  145169 |
                |  145197 |
                |  145198 |
                |  145210 |
                |  145249 |
                |  145335 |
                |  145376 |
                |  145447 |
                |  145487 |
                |  145532 |
                |  345632 |
                |  349894 |
                |  351961 |
                |  351971 |
                |  363466 |
                |  365705 |
                |  365707 |
                |  365718 |
                |  365719 |
                |  365720 |
                |  365755 |
                |  365756 |
                |  365761 |
                |  365762 |
                |  365765 |
                |  365766 |
                |  365767 |
                |  365768 |
                |  365771 |
                |  365772 |
                |  365773 |
                |  365774 |
                |  365775 |
                |  365777 |
                |  365778 |
                |  365779 |
                |  365780 |
                |  365781 |
                |  365788 |
                |  365789 |
                |  365790 |
                |  365791 |
                |  365792 |
                |  365794 |
                |  365804 |
                |  365805 |
                |  365810 |
                |  365811 |
                |  365812 |
                |  365813 |
                |  365815 |
                |  365816 |
                |  365817 |
                |  365818 |
                |  365819 |
                |  365820 |
                |  365824 |
                |  365825 |
                |  365826 |
                |  365827 |
                |  365832 |
                |  365833 |
                |  365834 |
                |  365835 |
                |  365836 |
                |  365838 |
                |  365839 |
                |  365840 |
                |  365841 |
                |  365842 |
                |  365843 |
                |  365848 |
                |  365853 |
                |  365854 |
                |  365855 |
                |  365863 |
                |  365864 |
                |  365865 |
                |  365866 |
                |  365867 |
                |  365868 |
                |  365869 |
                |  365870 |
                |  365871 |
                |  365872 |
                |  365873 |
                |  365874 |
                |  365875 |
                |  365876 |
                |  365877 |
                |  365878 |
                |  365879 |
                |  365880 |
                |  365881 |
                |  365891 |
                |  365892 |
                |  365893 |
                |  365894 |
                |  365895 |
                |  365897 |
                |  365898 |
                |  365899 |
                |  365900 |
                |  365901 |
                |  365902 |
                |  365903 |
                |  365904 |
                |  365905 |
                |  365906 |
                |  365907 |
                |  365908 |
                |  365909 |
                |  365910 |
                |  365911 |
                |  365912 |
                |  365913 |
                |  365914 |
                |  365915 |
                |  365916 |
                |  365917 |
                |  365921 |
                |  365922 |
                |  365924 |
                |  365930 |
                |  365931 |
                |  365932 |
                |  365933 |
                |  365934 |
                |  365935 |
                |  365936 |
                |  365941 |
                |  365942 |
                |  365945 |
                |  365946 |
                |  365947 |
                |  365948 |
                |  365950 |
                |  365951 |
                |  365954 |
                |  365955 |
                |  365956 |
                |  365958 |
                |  365959 |
                |  365960 |
                |  365961 |
                |  365966 |
                |  365967 |
                |  365968 |
                |  365969 |
                |  365970 |
                |  365971 |
                |  365972 |
                |  365973 |
                |  365974 |
                |  365975 |
                |  365976 |
                |  365977 |
                |  365978 |
                |  365979 |
                |  365980 |
                |  365981 |
                |  365982 |
                |  365987 |
                |  365988 |
                |  365989 |
                |  365990 |
                |  365995 |
                |  365996 |
                |  366001 |
                |  366002 |
                |  366003 |
                |  366004 |
                |  366005 |
                |  366006 |
                |  366011 |
                |  366012 |
                |  366013 |
                |  366014 |
                |  366015 |
                |  366016 |
                |  366017 |
                |  366018 |
                |  366019 |
                |  366020 |
                |  366021 |
                |  366032 |
                |  366040 |
                |  366048 |
                |  366050 |
                |  366539 |
                |  366540 |
                |  366543 |
                |  366544 |
                |  366549 |
                |  366550 |
                |  366555 |
                |  366556 |
                |  366559 |
                |  366560 |
                |  366563 |
                |  366564 |
                |  366566 |
                |  366567 |
                |  366568 |
                |  366569 |
                |  366570 |
                |  366574 |
                |  366575 |
                |  366578 |
                |  366579 |
                |  366580 |
                |  366581 |
                |  366582 |
                |  366583 |
                |  366584 |
                |  366585 |
                |  366587 |
                |  366588 |
                |  366589 |
                |  366590 |
                |  366591 |
                |  366592 |
                |  366595 |
                |  366596 |
                |  366598 |
                |  366599 |
                |  366600 |
                |  366601 |
                |  366602 |
                |  366603 |
                |  366604 |
                |  366605 |
                |  366606 |
                |  366607 |
                |  366608 |
                |  366610 |
                |  366624 |
                |  366627 |
                |  366648 |
                |  366649 |
                |  366650 |
                |  366651 |
                |  366658 |
                |  366659 |
                |  366679 |
                |  366680 |
                |  367352 |
                |  448456 |
                |  448524 |
                |  468837 |
                |  481669 |
                |  481916 |
                |  497332 |
                |  497481 |
                |  497482 |
                |  497487 |
                |  497488 |
                |  497891 |
                |  497983 |
                |  498767 |
                |  498768 |
                |  499139 |
                |  499140 |
                |  553086 |
                |  614595 |
                |  614596 |
                |  614597 |
                |  614598 |
                |  614599 |
                |  614600 |
                |  614601 |
                |  614602 |
                |  614606 |
                |  614608 |
                |  614609 |
                |  614610 |
                |  614613 |
                |  614614 |
                |  614617 |
                |  614618 |
                |  614700 |
                |  614702 |
                |  614704 |
                |  614706 |
                |  614708 |
                |  614710 |
                |  614711 |
                |  614712 |
                |  614713 |
                |  614714 |
                |  614716 |
                |  614718 |
                |  614719 |
                |  614720 |
                |  614721 |
                |  614722 |
                |  614749 |
                |  614750 |
                |  614751 |
                |  614752 |
                |  614753 |
                |  614754 |
                |  614755 |
                |  614756 |
                |  614757 |
                |  614758 |
                |  614759 |
                |  614760 |
                |  614761 |
                |  614762 |
                |  614763 |
                |  614764 |
                |  614765 |
                |  614766 |
                |  614849 |
                |  614854 |
                |  614857 |
                |  614860 |
                |  614865 |
                |  614868 |
                |  614871 |
                |  616216 |
                |  616490 |
                |  616546 |
                |  616654 |
                |  616805 |
                |  616981 |
                |  616985 |
                |  616992 |
                |  617015 |
                |  617030 |
                |  666544 |
                |  666547 |
                |  666842 |
                |  666844 |
                |  915385 |
                |  946994 |
                |  947011 |
                |  947077 |
                |  967387 |
                |  967388 |
                |  967910 |
                |  967911 |
                |  967912 |
                |  967913 |
                |  967914 |
                |  981578 |
                |  981579 |
                |  981580 |
                |  981583 |
                |  981585 |
                |  981587 |
                |  981591 |
                |  981592 |
                |  981593 |
                |  981596 |
                |  981597 |
                |  981598 |
                |  981600 |
                |  981601 |
                |  981602 |
                |  981603 |
                |  981604 |
                |  981605 |
                |  981606 |
                |  981609 |
                |  981610 |
                |  981611 |
                |  981612 |
                |  981613 |
                |  981614 |
                |  981615 |
                |  991620 |
                | 1049057 |
                | 1049058 |
                | 1049059 |
                | 1049074 |
                | 1049134 |
                | 1049138 |
                | 1049141 |
                | 1049142 |
                | 1065811 |
                | 1107474 |
                | 1108770 |
                | 1175483 |
                | 1224461 |
                | 1224462 |
                | 1224463 |
                | 1224464 |
                | 1224465 |
                | 1224466 |
                | 1224467 |
                | 1224468 |
                | 1224469 |
                | 1224561 |
                | 1224562 |
                | 1275522 |
                | 1275523 |
                | 1275524 |
                | 1275525 |
                | 1275526 |
                | 1275527 |
                | 1275528 |
                | 1275529 |
                | 1275530 |
                | 1275531 |
                | 1275532 |
                | 1275533 |
                | 1275534 |
                | 1275535 |
                | 1275536 |
                | 1275537 |
                | 1275538 |
                | 1275539 |
                | 1275540 |
                | 1275541 |
                | 1275542 |
                | 1288043 |
                | 1302794 |
                | 1302795 |
                | 1302796 |
                | 1302797 |
                | 1302798 |
                | 1302799 |
                | 1302800 |
                | 1302801 |
                | 1302802 |
                | 1302803 |
                | 1302804 |
                | 1302805 |
                | 1302806 |
                | 1302807 |
                | 1302808 |
                | 1302815 |
                | 1302816 |
                | 1302817 |
                | 1302881 |
                | 1302882 |
                | 1302883 |
                | 1302884 |
                | 1302885 |
                | 1302886 |
                | 1302887 |
                | 1302888 |
                | 1302889 |
                | 1302890 |
                | 1302891 |
                | 1302892 |
                | 1302893 |
                | 1302894 |
                | 1302895 |
                | 1302899 |
                | 1302900 |
                | 1302901 |
                | 1302972 |
                | 1303080 |
                | 1303120 |
                | 1303121 |
                | 1303122 |
                | 1303123 |
                | 1303124 |
                | 1303125 |
                | 1303126 |
                | 1303127 |
                | 1303128 |
                | 1303129 |
                | 1303130 |
                | 1303131 |
                | 1303132 |
                | 1303133 |
                | 1303134 |
                | 1303137 |
                | 1303138 |
                | 1303139 |
                | 1303183 |
                | 1303184 |
                | 1303185 |
                | 1303186 |
                | 1303187 |
                | 1303188 |
                | 1303189 |
                | 1303190 |
                | 1303191 |
                | 1303192 |
                | 1303193 |
                | 1303194 |
                | 1303195 |
                | 1303196 |
                | 1303197 |
                | 1303204 |
                | 1303205 |
                | 1303206 |
                | 1303257 |
                | 1303258 |
                | 1303259 |
                | 1303260 |
                | 1303261 |
                | 1303262 |
                | 1303263 |
                | 1303264 |
                | 1303265 |
                | 1303266 |
                | 1303267 |
                | 1303268 |
                | 1303269 |
                | 1303270 |
                | 1303271 |
                | 1303274 |
                | 1303275 |
                | 1303276 |
                | 1303303 |
                | 1303304 |
                | 1303305 |
                | 1303306 |
                | 1303307 |
                | 1303308 |
                | 1303309 |
                | 1303310 |
                | 1303311 |
                | 1303312 |
                | 1303313 |
                | 1303314 |
                | 1303315 |
                | 1303316 |
                | 1303317 |
                | 1303320 |
                | 1303321 |
                | 1303322 |
                | 1303376 |
                | 1303377 |
                | 1303378 |
                | 1303379 |
                | 1303380 |
                | 1303381 |
                | 1303382 |
                | 1303383 |
                | 1303384 |
                | 1303385 |
                | 1303386 |
                | 1303387 |
                | 1303388 |
                | 1303389 |
                | 1303390 |
                | 1303392 |
                | 1303393 |
                | 1303394 |
                | 1303444 |
                | 1303445 |
                | 1303446 |
                | 1303447 |
                | 1303448 |
                | 1303449 |
                | 1303450 |
                | 1303451 |
                | 1303452 |
                | 1303453 |
                | 1303454 |
                | 1303455 |
                | 1303456 |
                | 1303457 |
                | 1303458 |
                | 1303462 |
                | 1303463 |
                | 1303464 |
                | 1303544 |
                | 1303545 |
                | 1303546 |
                | 1303547 |
                | 1303548 |
                | 1303549 |
                | 1303550 |
                | 1303551 |
                | 1303552 |
                | 1303553 |
                | 1303554 |
                | 1303555 |
                | 1303556 |
                | 1303557 |
                | 1303558 |
                | 1303568 |
                | 1303569 |
                | 1303570 |
                | 1303675 |
                | 1303686 |
                | 1303710 |
                | 1303711 |
                | 1303712 |
                | 1303713 |
                | 1303714 |
                | 1303715 |
                | 1303716 |
                | 1303717 |
                | 1303718 |
                | 1303719 |
                | 1303720 |
                | 1303721 |
                | 1303722 |
                | 1303723 |
                | 1303724 |
                | 1303725 |
                | 1303726 |
                | 1303727 |
                | 1303728 |
                | 1303729 |
                | 1303730 |
                | 1303922 |
                | 1303923 |
                | 1303924 |
                | 1303925 |
                | 1303926 |
                | 1303927 |
                | 1303928 |
                | 1303929 |
                | 1303930 |
                | 1303931 |
                | 1303932 |
                | 1303933 |
                | 1303934 |
                | 1303935 |
                | 1303936 |
                | 1303937 |
                | 1303938 |
                | 1303939 |
                | 1304054 |
                | 1304055 |
                | 1304056 |
                | 1304057 |
                | 1304058 |
                | 1304059 |
                | 1304060 |
                | 1304061 |
                | 1304062 |
                | 1304063 |
                | 1304064 |
                | 1304065 |
                | 1304066 |
                | 1304067 |
                | 1304068 |
                | 1304069 |
                | 1304070 |
                | 1304071 |
                | 1304091 |
                | 1304092 |
                | 1304093 |
                | 1304094 |
                | 1304095 |
                | 1304096 |
                | 1304097 |
                | 1304098 |
                | 1304099 |
                | 1304100 |
                | 1304101 |
                | 1304102 |
                | 1304103 |
                | 1304104 |
                | 1304105 |
                | 1304106 |
                | 1304107 |
                | 1304108 |
                | 1304181 |
                | 1304182 |
                | 1304183 |
                | 1304184 |
                | 1304185 |
                | 1304186 |
                | 1304187 |
                | 1304188 |
                | 1304189 |
                | 1304190 |
                | 1304191 |
                | 1304192 |
                | 1304193 |
                | 1304194 |
                | 1304195 |
                | 1304196 |
                | 1304197 |
                | 1304198 |
                | 1304301 |
                | 1304302 |
                | 1304303 |
                | 1304304 |
                | 1304305 |
                | 1304318 |
                | 1304319 |
                | 1304400 |
                | 1304401 |
                | 1304402 |
                | 1304403 |
                | 1304404 |
                | 1304593 |
                | 1304594 |
                | 1304595 |
                | 1304763 |
                | 1304764 |
                | 1304765 |
                | 1304766 |
                | 1304767 |
                | 1304768 |
                | 1304769 |
                | 1304770 |
                | 1304771 |
                | 1304772 |
                | 1304773 |
                | 1304774 |
                | 1304775 |
                | 1304776 |
                | 1304777 |
                | 1304778 |
                | 1304779 |
                | 1304780 |
                | 1304786 |
                | 1304787 |
                | 1304788 |
                | 1304832 |
                | 1304841 |
                | 1304883 |
                | 1304884 |
                | 1304937 |
                | 1304938 |
                | 1305046 |
                | 1305047 |
                | 1305657 |
                | 1305658 |
                | 1305659 |
                | 1305660 |
                | 1305661 |
                | 1305662 |
                | 1305663 |
                | 1305664 |
                | 1305673 |
                | 1305674 |
                | 1305675 |
                | 1305676 |
                | 1305677 |
                | 1305678 |
                | 1305679 |
                | 1305680 |
                | 1305860 |
                | 1305861 |
                | 1305870 |
                | 1305871 |
                | 1317222 |
                | 1317223 |
                | 1320262 |
                | 1320263 |
                | 1407990 |
                | 1407991 |
                | 1436551 |
                | 1436556 |
                | 1436557 |
                | 1436558 |
                | 1436559 |
                | 1436560 |
                | 1436561 |
                | 1436562 |
                | 1436563 |
                | 1436564 |
                | 1436565 |
                | 1436566 |
                | 1436567 |
                | 1436568 |
                | 1436569 |
                | 1436570 |
                | 1436571 |
                | 1436572 |
                | 1446715 |
                | 1499597 |
                | 1499604 |
                | 1499605 |
                | 1499606 |
                | 1499607 |
                | 1499608 |
                | 1499609 |
                | 1499610 |
                | 1499611 |
                | 1499612 |
                | 1499613 |
                | 1499614 |
                | 1499615 |
                | 1499616 |
                | 1499617 |
                | 1499618 |
                | 1499619 |
                | 1499620 |
                | 1508400 |
                | 1510683 |
                | 1522612 |
                | 1522616 |
                | 1539056 |
                | 1580296 |
                | 1611888 |
                | 1611889 |
                | 1632009 |
                | 1634200 |
                | 1634201 |
                | 1651389 |
                | 1651400 |
                | 1651401 |
                | 1651402 |
                | 1651403 |
                | 1651404 |
                | 1651405 |
                | 1651406 |
                | 1651407 |
                | 1651408 |
                | 1651409 |
                | 1651410 |
                | 1651411 |
                | 1651412 |
                | 1651413 |
                | 1651414 |
                | 1651415 |
                | 1651416 |
                | 1670753 |
                | 1711916 |
                | 1711917 |
                | 1711924 |
                | 1711925 |
                | 1711926 |
                | 1711927 |
                | 1711928 |
                | 1711930 |
                | 1711931 |
                | 1719744 |
                | 1719745 |
                | 1719746 |
                | 1719747 |
                | 1719748 |
                | 1719749 |
                | 1726069 |
                | 1726070 |
                | 1739623 |
                | 1739626 |
                | 1740763 |
                | 1740764 |
                | 1788371 |
                | 1793281 |
                | 1793282 |
                | 1819642 |
                | 1819680 |
                | 1819700 |
                | 1819738 |
                | 1819952 |
                | 1819989 |
                | 1820022 |
                | 1820036 |
                | 1820051 |
                | 1820073 |
                | 1820552 |
                | 1820691 |
                | 1830904 |
                | 1830905 |
                | 1834027 |
                | 1837771 |
                | 1837772 |
                | 1838955 |
                | 1838956 |
                • vso
                  Zabbix developer
                  • Aug 2016
                  • 190
                  #38
                  You could do a backup and try query below, but no guarantees:
                  delete from problem where not exists (select null from events where events.eventid=problem.eventid);
                  • lukisec
                    • Apr 2018
                    • 22
                    #39
                    Hi!
                    SOLVED! That works!
                    Thank you very much for your help!
                    BR
                    • lukisec
                      • Apr 2018
                      • 22
                      #40
                      Hi, again, can someone can help mi with:
                      2289:20180727:144058.831 [Z3005] query failed: [1062] Duplicate entry '199718' for key 'PRIMARY' [insert into event_recovery (eventid,r_eventid,correlationid, c_eventid,userid) values (199470,227423,null,null,null),(197966,227423,null ,null ,null),(199718,227423,null,null,null),(196898,2274 23,null,null,null),(197801,227 423,null,null,null),(197088,227423,null,null,null) ,(209889,227423,null,null,null ),(210468,227423,null,null,null),(198748,227423,nu ll,null,null),(196920,227423,n ull,null,null),(197146,227423,null,null,null),(202 113,227423,null,null,null),(19 7660,227423,null,null,null),(202180,227423,null,nu ll,null),(211480,227423,null,n ull,null),(198944,227423,null,null,null),(197391,2 27423,null,null,null),(210437, 227423,null,null,null),(199932,227423,null,null,nu ll),(202066,227423,null,null,n ull),(227422,227423,null,null,null),(197868,227423 ,null,null,null),(199749,22742 3,null,null,null),(197030,227423,null,null,null),( 199360,227423,null,null,null), (210915,227423,null,null,null),(196965,227423,null ,null,null),(200014,227423,nul l,null,null),(199196,227423,null,null,null),(19984 4,227423,null,null,null),(2114 09,227423,null,null,null),(198971,227423,null,null ,null),(202220,227423,null,nul l,null),(197431,227423,null,null,null),(198634,227 423,null,null,null),(198833,22 7423,null,null,null),(199976,227423,null,null,null ),(197207,227423,null,null,nul l),(199910,227423,null,null,null),(211745,227423,n ull,null,null),(199416,227423, null,null,null),(211281,227423,null,null,null),(20 2045,227423,null,null,null),(2 27006,227423,null,null,null),(199956,227423,null,n ull,null),(198791,227423,null, null,null),(210057,227423,null,null,null),(211701, 227423,null,null,null),(196860 ,227423,null,null,null),(227358,227423,null,null,n ull),(197634,227423,null,null, null),(199562,227423,null,null,null),(201986,22742 3,null,null,null),(210576,2274 23,null,null,null),(199668,227423,null,null,null), (197707,227423,null,null,null) ,(199150,227423,null,null,null),(198866,227423,nul l,null,null),(202287,227423,nu ll,null,null),(200054,227423,null,null,null),(1992 49,227423,null,null,null),(210 677,227423,null,null,null),(198061,227423,null,nul l,null),(201954,227423,null,nu ll,null),(197172,227423,null,null,null),(199489,22 7423,null,null,null),(211514,2 27423,null,null,null),(211432,227423,null,null,nul l),(211884,227423,null,null,nu ll),(199060,227423,null,null,null),(199875,227423, null,null,null),(211122,227423 ,null,null,null),(198695,227423,null,null,null),(1 96819,227423,null,null,null),( 198928,227423,null,null,null),(200498,227423,null, null,null),(210735,227423,null ,null,null),(198181,227423,null,null,null),(210806 ,227423,null,null,null),(21034 7,227423,null,null,null),(199625,227423,null,null, null),(210403,227423,null,null
                      • dferrari
                        • Dec 2016
                        • 9
                        #41
                        Perfect for me !!
