Escalator process gets stuck what leads to a huge disk I/O load
  • guest12345
    • Apr 2018
    installation details:
    zabbix server 3.4 + mysql(mariadb) with partitioning (on the same server CentOS7)
    zabbix proxy 3.4 + mysql(mariadb)
    mysql Ver 15.1 Distrib 10.1.32-MariaDB
    zabbix_server (Zabbix) 3.4.8
    Issue:
    After disbling one single trigger in the template an escalator process gets busy 100% and DISK I/O load severely increases
    As result no notifications being sent out, overall server performance degrades
    Described symptoms stay even after reloading the VM, zabbix-server, mariadb services
    Inscreasing a number of the escalator processes on the config file does not change the situation
    The trigger is for a standard item - system.uptime (agent check)
    The template has been applied for some months already to about ~100 windows servers)
    For testing purposes some similar triggers were disabled from the template with no problem
    The issue showed up for the fisrt time on 3.2 version. Upgarding zabbix to 3.4 and mariadb to the latest release did not change a thing
    Zabbix bug? corrupted data?
    any thoughts and suggestions would be much appreciated
    some debug(5) logs
    8231:20180411:175451.559 End of check_escalation():cancel error:'trigger "{HOST.NAME} uptime > 30 days" disabled.'
    8231:20180411:175707.760 In check_escalation() escalationid:594427 status:sleep
    8231:20180411:175707.761 End of check_escalation():cancel error:'trigger "{HOST.NAME} uptime > 30 days" disabled.'
    8232:20180411:180300.425 In check_escalation() escalationid:366904 status:sleep
    8232:20180411:180300.429 End of check_escalation():cancel error:'trigger "{HOST.NAME} uptime > 30 days" disabled.'
    8230:20180411:180307.547 In check_escalation() escalationid:550077 status:sleep
    8230:20180411:180307.551 End of check_escalation()rocess error:''
    8230:20180411:180307.555 In check_escalation() escalationid:581580 status:sleep
    8230:20180411:180307.559 End of check_escalation():cancel error:'trigger "{HOST.NAME} uptime > 30 days" disabled.'
    8229:20180411:180311.591 In check_escalation() escalationid:613754 status:active
    8229:20180411:180311.594 End of check_escalation()rocess error:''
    8229:20180411:180313.277 In check_escalation() escalationid:613767 status:active
    8229:20180411:180313.280 End of check_escalation()rocess error:''
    8229:20180411:180314.397 In check_escalation() escalationid:613777 status:active
    8229:20180411:180314.401 End of check_escalation()rocess error:''
    8229:20180411:180315.622 In check_escalation() escalationid:534119 status:sleep
    8229:20180411:180315.625 End of check_escalation():cancel error:'trigger "{HOST.NAME} uptime > 30 days" disabled.'
    8233:20180411:180320.184 In check_escalation() escalationid:393636 status:sleep
    8233:20180411:180320.188 End of check_escalation():cancel error:'trigger "{HOST.NAME} uptime > 30 days" disabled.'
  • vso
    Zabbix developer
    • Aug 2016
    • 190
    Is issue solved ? Can it be related to https://support.zabbix.com/browse/ZBXNEXT-4271 ?
