proc.cpu.util bug?
  • tmroberts
    • Jan 2017
    • 73
    proc.cpu.util bug?
    We are trying to set up some monitoring on specific user processes on some linux boxes by using the proc.cpu.util item key. But every time we enter ANY parameters it reverts to unsupported item stating that one of the parameters is invalid. We have tried the other proc parameters (proc.mem and proc.num) for specific users and it works just fine but not the proc.cpu.util. An example of what have tried just as a proof of concept is proc.cpu.util[,root] which returns the error of an invalid first parameter. We are running version 3.4.7. The agent we were testing on is version 3.4.8 i believe. Are we just doing something wrong or have we uncovered a bug?
  • kloczek
    • Jun 2006
    • 1771
    Please show exact key and OS name.
    • tmroberts
      • Jan 2017
      • 73
      The exact key that we have been trying is: proc.cpu.util[,root]
      This results in: Unsupported item key.
      This is on CentOS
      Ideally this would be used for specific processes (i.e. our wiki software) runs under a specific user other than root.
      • kloczek
        • Jun 2006
        • 1771
        Just done quick test and it works for me. View from last data -> values:
        2018-04-19 19:19:04 4.8
        2018-04-19 19:18:34 6.6
        2018-04-19 19:18:04 6.8
        2018-04-19 19:17:34 6.5
        2018-04-19 19:17:04 7.9
        2018-04-19 19:16:34 10.8
        2018-04-19 19:16:04 13.3
        2018-04-19 19:15:34 3
        Definition of the Item:
        • Name
          test proc.cpu.util[,root]
        • Type
          Zabbix agent (active)
        • Key
        • Type of information
          Numeric (float)
        • tmroberts
          • Jan 2017
          • 73
          I can't seem to find anything wrong with how i have it created:
          What am I doing wrong?
          • tmroberts
            • Jan 2017
            • 73
            and by the way.... thank you for responding....
            • kloczek
              • Jun 2006
              • 1771
              Go to item definition -> "Processing" tab and double check do you have any processing rules (it should be the empty list here).
              • kloczek
                • Jun 2006
                • 1771
                (No .. preprocessing has nothing to do with this error message)
                Just checked source code:
                [tkloczko@domek src]$ grep -r "Unsupported item key" *
                libs/zbxsysinfo/sysinfo.c:        SET_MSG_RESULT(result, zbx_strdup(NULL, "Unsupported item key."));
                zabbix_server/poller/checks_telnet.c:        SET_MSG_RESULT(result, zbx_strdup(NULL, "Unsupported item key for this item type."));
                zabbix_server/poller/checks_ssh.c:        SET_MSG_RESULT(result, zbx_strdup(NULL, "Unsupported item key for this item type."));
                zabbix_server/poller/checks_internal.c:        SET_MSG_RESULT(result, zbx_strdup(NULL, "Unsupported item key for this item type."));
                zabbix_server/poller/checks_db.c:            SET_MSG_RESULT(result, zbx_strdup(NULL, "Unsupported item key for this item type."));
                [tkloczko@domek src]$ grep -r proc.cpu.util
                libs/zbxsysinfo/linux/linux.c:    {"proc.cpu.util",    CF_HAVEPARAMS,    PROC_CPU_UTIL,        "inetd"},
                libs/zbxsysinfo/linux/proc.c:    /* proc.cpu.util[<procname>,<username>,(user|system),<cmdline>,(avg1|avg5|avg15)] */
                libs/zbxsysinfo/solaris/solaris.c:    {"proc.cpu.util",    CF_HAVEPARAMS,    PROC_CPU_UTIL,        "inetd"},
                libs/zbxsysinfo/solaris/proc.c:    /* proc.cpu.util[<procname>,<username>,(user|system),<cmdline>,(avg1|avg5|avg15),(current|all)] */
                And I don't see anything conditionally switched in libs/zbxsysinfo/sysinfo.c or libs/zbxsysinfo/linux/linux.c which could affect this key :-/
                Looking at the src code looks like this error message is displayed only when the key is not handled by the agent. Please try the test on your binary:
                [tkloczko@domek src]$ strings /usr/sbin/zabbix_agentd |grep proc.cpu.util
                proc.cpu.util
                • tmroberts
                  tmroberts commented
                  When we ran that test it didn't return anything.... my first question would be this... when we installed the agent on this host, we only pulled down the rpm file for the agent not the whole release rpm. Would that have anything to do with this?
              • vso
                Zabbix developer
                • Aug 2016
                • 190
                Please increase log level in agent configuration file, create new pro.cpu.util key and start agent.
                • tmroberts
                  • Jan 2017
                  • 73
                  I finally got a little more info from the end user on this host.... After I had them look for that proc.cpu.util sting as instructed and returning nothing, I had them double check the version of their agent and it turns out that the upgrade they ran on their host to bring the agent up to 3.4.8 didn't actually take so they were still running 2.4.x agent. My apologies on this, and thanks for the input.
                  • kloczek
                    • Jun 2006
                    • 1771
                    This is why my OS templates have linked "Service Zabbix Agent" template in which is the item "version" in which is sampled agent.version[] agent key.
                    With this is possible to check running version of the agent without login on the host just only looking on monitoring data. Additional trigger in this template will notice any changes in agents version strings. This item as well is mapped in item definition in "Populates host inventory field" to "Software application A".
                    With this mapping is possible to go in zabbix web interface to Inventory -> Overview and after after changing "Grouping by" to "Software application A" is possible to see aggregated data about on how many hosts is used exact version of the agent.
                    Try to add something like this and shortly after this with minimal effort you will have precise informations on which other hosts you need to upgrade zabbix agent.
                    • salai
                      • Nov 2020
                      • 27
                      I am getting the same error "Unsupported item Key". Is this item not supported for windows server?
                        • 4996
                        no ...
