compare 3 values
  • ukasz
    • Jan 2014
    compare 3 values
    want to compare 3 last values with the current value if all are eq current values run the trriger
    {x:vfs.file.md5sum[/tmp/zabbix_ipmitool.current].diff(#1)}=0&
    {z:vfs.file.md5sum[/tmp/zabbix_ipmitool.current].diff(#2)}=0&
    {x:vfs.file.md5sum[/tmp/zabbix_ipmitool.current].diff(#3)}=0
    what is wrong
  • BDiE8VNy
    • Apr 2010
    • 680
    The diff() trigger function always checks if last and previous values differ.
    Passed parameters will be ignored (See Supported trigger functions).
    Line breaks in trigger expressions are not supported as well.
    • ukasz
      • Jan 2014
      Do you have any idea how to compare N last values with the current one?
      • BDiE8VNy
        • Apr 2010
        • 680
        Maybe one of these (not tested!):
        {<server>:vfs.file.md5sum[file].last(#1)}#{<server>:vfs.file.md5sum[file].last(#2)}|{<server>:vfs.file.md5sum[file].last(#2)}#{<server>:vfs.file.md5sum[file].last(#3)}
        {<server>:vfs.file.md5sum[file].diff(0)}=1|{<server>:vfs.file.md5sum[file].last(#2)}#{<server>:vfs.file.md5sum[file].last(#3)}
        {<server>:vfs.file.cksum[file].sum(#3)}/3#{<server>:vfs.file.cksum[file].last(0)}
        {<server>:vfs.file.cksum[file].last(0)}*3#{<server>:vfs.file.cksum[file].sum(#3)}
        Edit:
        Since comparison to strings is not supported only the cksum() ones may work
        • ukasz
          • Jan 2014
          ({x:vfs.file.cksum[/tmp/zabbix_ipmitool.current].sum(#3)}/{x:vfs.file.cksum[/tmp/zabbix_ipmitool.current].last(#1)})=3
          works for me
          Thx
