zebbix_server defaults
  • DavidD
    • Nov 2013
    Quick and simple question but one I can't find a quick answer for.
    Within the zabbix_server.conf there are default, but is the system hard coded with the defaults.
    So for example:
    Below we have HousekeepingFrequency=1 commented out, but we also have DisableHousekeeping=1 commented out. Does this mean
    a) Housekeeping runs and uses a hard coded default frequency of 1
    b) Housekeeping does not run at all as it has no defined frequency
    # How often ZABBIX will perform housekeeping procedure
    # (in hours)
    # Default value is 1 hour
    # Housekeeping is removing unnecessary information from
    # tables history, alert, and alarms
    # This parameter must be between 1 and 24
    #HousekeepingFrequency=1
    # How often ZABBIX will try to send unsent alerts
    # (in seconds)
    # Default value is 30 seconds
    SenderFrequency=30
    # Uncomment this line to disable housekeeping procedure
    #DisableHousekeeping=1
