zabbix_agentd reponds, zabbix_get returns ZBX_NOTSUPPORTED
  • DSpencer
    • Dec 2013
    Zabbix Server version 1.8.8 on CentOS 6
    Zabbix Agentd 1.8.3 on CentOS 6
    I am working on cleaning up our zabbix monitoring. I am checkingitems on templates and there are a number host that report the items as "Not Supported".
    Most I have figured out most, but vm.memory.size[shared] had got me puzzled.
    Running the zabbix_agentd on the host vm.memory.size[shared] returns [u|0] which is correct for this host.
    Running the zabbix_get on the zabbix server vm.memory.size[shared] returns ZBX_NOTSUPPORTED.
    I cannot figure out why zabbix server is unable to check vm.memory.size[shared]. All other modes work fine except for shared. I ran into similar problems with vfs.file.cksum[/foo/bar] and found it was a permission issue on the file being checked, but i cannot find the file or documenation about any specific file that vm.memory.size item checks. I did look into the /proc/sys/vm and systrl but did not find any answers.
    Any help or suggestions would be greatly appreciated!
    ~ds
  • dirckcopeland
    • Oct 2013
    • 50
    Puzzled about vm.memory.size[shared]
    DSpencer,
    I was scratching my head about this also and not sure if yours is the same issue but after researching it and finding the latest docs in the zabbix site I see that the vm.memory.size support for the parameter "shared" only works with the linux kernel 2.4. I'm running 2.6.
    • arifzulfikar
      • Mar 2014
      Hi DSpencer,
      Please try to restart the zabbix agentd in your monitored server.
      Actually I have same problem with you, when I trying to zabbix_get from my server the value is always 0.
