Hello, Cold here,
I want to implement a dependency between Router and Host. So that if the Router is down, none of the connected Hosts would be displaying an issue.
The Setup would be:
Router (down) --> Dont Show Host/VM Triggers
Router (Up) --> Show Host/VM Triggers
I know it is possible to manually add this for every Host and make the Host Ping Trigger dependant of the Router Ping Trigger.
But thats a huge load of work for about 1k Hosts where 3 Hosts are connected to one Router.
Is there a way around the fact that i cannot make Templates dependant of each other? Also if I were to manually edit the Hosts, after an export all dependencies would be lost.
But maybe my initial thoughts to accomplish this is wrong I'm also thankfull for any new ideas.
The Setup would be:
