I'm currently dealing with trigger prototypes. By defaults there's one that triggers a problem when the disk space usage falls under 20%. Because that's not suitable for me I've cloned the trigger prototype and changed the value to <10 (10%). Then I've activated manual acknowledge and disabled the origin.
When I check the applied trigger prototypes per host it looks correct. The obvisious next step was to acknowledge the old problem manually.
But after a while I've checked the dashboard again and the same old problem appeared - disk usage less than 20%
What I am doing wrong?
