Aggregate checks VMware esxi hosts
  • Turboaaa2018
    • May 2018
    I am trying to create an aggregate check for all vmware hosts to monitor total CPU utilization. The hosts are discovered using the "Virt VMware" Template on the vSphere management server. I then created a new item under my vsphere host with type "Zabbix Aggregate" with the following key
    grpsum["VSI","vmware.hv.cpu.usage[{$URL},{HOST.HOST}",last]
    The group I want to pull from is VSI, but the full name appears to be But the group name is "VSI" when I look at the hosts in the group.
    The error I am receiving is below, though with the {$URL},{HOST.HOST} variables filled out for the vsphere host, which does not translate to the esxi hosts.
    "No items for key "vmware.hv.cpu.usage" in group(s) "VSI"."
    What would be the best method for aggregating the CPU usage for all hosts so I can create alerts?
  • Turboaaa2018
    • May 2018
    ---bump---
    • sfl
      • Jun 2016
      • 26
      same here with Zabbix 4.0.7.
      grpsum["GROUP1","vmware.hv.hw.cpu.num[{$URL},{HOST.HOST}]",sum,last]
      and receive following message :
      No items for key "vmware.hv.hw.cpu.num[https://1.1.1.1/sdk,VCENTER]" in group(s) "GROUP1"
      • Hamardaban
        • May 2019
        • 2713
        The stupid question: Is GROUP1 a HOST group in your expression?
        • sfl
          • Jun 2016
          • 26
          yes of course unfortunately
          I can precise that items come from LLD and host prototype.
