Zabbix DM Sync problem
  • rosangela
    • Nov 2010
    I'm running Zabbix with DM Setup with 4 Child-Nodes in sync with a Master-Node in my Company.
    After a few months running, some fields in both Master and Child Node gone "blank". I.E. fields like "hostname", associated templates or even login names gone blank... does anyone know why this is happening or how to solve the problem ?
    I'm using Zabbix 2.0.9 DM Setup, PostgreSQL 9.2.
    Thanks in advance.
  • johansen
    • Oct 2009
    • 38
    we have nearly the same setup but we were told to stop use DM for the moment:
    the currently used DM setup will be removed from the code and rewritten from scratch (but there is no time defined).
    We also have a lot of problems with syncing data (uint) from node to master and currently under review to use master-proxy setup.
    EDIT: another interesting post: https://www.zabbix.com/forum/showthread.php?t=38033
