After an upgrade of the zabbix server to 2.2.1, I'm still having trouble getting network LLD to work correctly on FreeBSD hosts. Example from one host is below:
My regex:
^(em|igb|loo|bce|eth|wan|lan|bridge)\d?$
(I renamed the regex 'interfaces' for now, to make sure I wasn't missing a typo)
What I see come across the wire:
"data":[
"{#IFNAME}":"usbus0"},
"{#IFNAME}":"em0"},
"{#IFNAME}":"em1"},
"{#IFNAME}":"usbus1"},
"{#IFNAME}":"lo0"}]}
Relevant log entry:
37824:20140110:235115.227 In substitute_simple_macros() data:'30'
37824:20140110:235115.228 DBlld_process_discovery_rule() f_macro:'{#IFNAME}' f_regexp:'@interfaces'
37824:20140110:235115.228 In DBlld_update_items()
37824:20140110:235115.228 query [txnlev:0] [select i.itemid,i.name,i.key_,i.type,i.value_type,i.data
_type,i.delay,i.delay_flex,i.history,i.trends,i.st atus,i.trapper_hosts,i.units,i.multiplier,i.delta, i
.formula,i.logtimefmt,i.valuemapid,i.params,i.ipmi _sensor,i.snmp_community,i.snmp_oid,i.port,i.snmpv 3
_securityname,i.snmpv3_securitylevel,i.snmpv3_auth protocol,i.snmpv3_authpassphrase,i.snmpv3_privprot o
col,i.snmpv3_privpassphrase,i.authtype,i.username, i.password,i.publickey,i.privatekey,i.description, i
.interfaceid,i.snmpv3_contextname from items i,item_discovery id where i.itemid=id.itemid and id.pare
nt_itemid=24375]
37824:20140110:235115.228 In DBlld_items_get()
37824:20140110:235115.228 query [txnlev:0] [select id.itemid,id.key_,id.lastcheck,id.ts_delete,i.nam
e,i.key_,i.type,i.value_type,i.data_type,i.delay,i .delay_flex,i.history,i.trends,i.trapper_hosts,i.u n
its,i.multiplier,i.delta,i.formula,i.logtimefmt,i. valuemapid,i.params,i.ipmi_sensor,i.snmp_community ,
i.snmp_oid,i.port,i.snmpv3_securityname,i.snmpv3_s ecuritylevel,i.snmpv3_authprotocol,i.snmpv3_authpa s
sphrase,i.snmpv3_privprotocol,i.snmpv3_privpassphr ase,i.authtype,i.username,i.password,i.publickey,i .
privatekey,i.description,i.interfaceid,i.snmpv3_co ntextname from item_discovery id join items i on id
.itemid=i.itemid where id.parent_itemid=24377]
37824:20140110:235115.228 End of DBlld_items_get()
37824:20140110:235115.228 In lld_check_record() jp_row:'{
"{#IFNAME}":"usbus0"}'
37824:20140110:235115.228 End of lld_check_record():FAIL
"{#IFNAME}":"em0"}'
"{#IFNAME}":"em1"}'
"{#IFNAME}":"usbus1"}'
"{#IFNAME}":"lo0"}'
37824:20140110:235115.229 End of lld_check_record():FAIL
37824:20140110:235115.229 In DBlld_items_validate()
37824:20140110:235115.229 End of DBlld_items_validate()
It appears to be using the correct regex, the regex looks correct to me and tests allright. What else might be causing the failure?
My regex:
"data":[
"{#IFNAME}":"em0"},
"{#IFNAME}":"em1"},
Relevant log entry:
nt_itemid=24375]
"{#IFNAME}":"em0"}'
"{#IFNAME}":"em1"}'
"{#IFNAME}":"lo0"}'
