I was running Zabbix 2.0.9 with current stats:
Zabbix server and the frontend are running on a Vmware virtual machine and the Percona MySQL database is running on a seperate 4-core 2Ghz server with 4Gb of RAM. The database files are located on Flash disks in a fibre connected SAN..
When using v2.0.9 this al worked correctly. MySQL running between 50 and 80% cpu usage and performing about 250 IOPS on the database diskpool with peaks of max 550 IOPS.
After the upgrade to 2.2.1, the MySQL process now consumes between 250 to 400% CPU usage (hence 100% on all cores) and we now have 4500 - 5500 IOPS in the database diskpool..
And even with that zabbix servers starts complaining about transaction locks timing out and the value cache being fully used (meanwhile adjusted to 1GB size, but still fully used). All active agents complain about timeouts connecting to the server and even the PHP frontend is only able to connect to the zabbix server process once every few minutes..
bottom line.. zabbix is currently completely unusable..
Did something go wrong during the upgrade? I can't imagine that it is normal that the database activity is increased 5 to 6 times just by upgrading .. ?
Number of hosts (monitored/not monitored/templates) 963 854 / 48 / 61 Number of items (monitored/disabled/not supported) 47135 42624 / 2024 / 2487 Number of triggers (enabled/disabled) [problem/ok] 30999 25519 / 5480 [623 / 24896] Required server performance, new values per second 641.24 -
