Cannot delete proxy - SQL statement execution has failed
  • Starko
    • Aug 2012
    • 93
    We are using Zabbix 3.4.8 on Debian Stretch with about 29 Proxys I guess. We are slowly migration from passive Proxys with IPsec VPNs to Active Proxys with TLS-PSK. This Zabbix Installation is online since Zabbix 2.0.
    While migrating the Proxys from Passive to Active I hit one of the oldest Proxys. This one has been in use since ever. I first stumbled on this error, when I tried to switch from passive to active:
    Interface is linked to item "Maximum number of opened files" on "".
    So I searched for a while but eventually gave up and created the Proxy a second time with Active TLS-PSK. I switched the hosts and everything works just fine. But as I tried to delete the old instance, I now faced a new problem which must be related to the first problem I guess:
    Error in query [DELETE FROM interface WHERE hostid='10085'] [Cannot delete or update a parent row: a foreign key constraint fails (`zabbix`.`items`, CONSTRAINT `c_items_4` FOREIGN KEY (`interfaceid`) REFERENCES `interface` (`interfaceid`))]
    SQL statement execution has failed "DELETE FROM interface WHERE hostid='10085'"
    Can anybody help me with this, or is this interesting enough to be considered for a bug report?
  • Starko
    • Aug 2012
    • 93
    Hello everybody! Sorry for the double post, but I just wanted to say, that by now I have the second "old" proxy I can't delete. My Zabbix Server is version 3.4.12 today.
    Cannot delete proxy
    Details[LIST][*]Error in query [DELETE FROM interface WHERE hostid='10745'] [Cannot delete or update a parent row: a foreign key constraint fails (`zabbix`.`items`, CONSTRAINT `c_items_4` FOREIGN KEY (`interfaceid`) REFERENCES `interface` (`interfaceid`))][*]SQL statement execution has failed "DELETE FROM interface WHERE hostid='10745'"[/LIST]
    Can anybody help me?
    • zux
      • Sep 2018
      • 97
      the proxy is probably linked to some hosts, can you try this?
      select hostid, proxy_hostid, host, status from hosts where hostid=10085;
      and also, identify the hostid of the proxies you can't delete and then do this:
      select hostid, proxy_hostid, host, status from hosts where proxy_hostid=<proxy_hostid>;
      you can easily identify the hostid of proxy, by looking at the link, when you click on that proxy
      • Starko
        • Aug 2012
        • 93
        Found the solution via ZBX-15082 and the help of a friend.
        The following statement shows you the orphaned items:
        SELECT itemid,hostid,key_ FROM items WHERE interfaceid IN (SELECT interfaceid FROM interface WHERE hostid=10085)
        Which showed me this:
        | itemid | hostid | key_                          |
        |  24866 |  10085 | kernel.maxfiles               |
        |  24867 |  10085 | kernel.maxproc                |
        |  24868 |  10085 | net.if.discovery              |
        |  24869 |  10085 | net.if.in[{#IFNAME}]          |
        |  24870 |  10085 | net.if.out[{#IFNAME}]         |
        |  24871 |  10085 | proc.num[,,run]               |
        |  24872 |  10085 | proc.num[]                    |
        |  24873 |  10085 | system.boottime               |
        |  24874 |  10085 | system.cpu.intr               |
        |  24875 |  10085 | system.cpu.load[percpu,avg15] |
        |  24876 |  10085 | system.cpu.load[percpu,avg1]  |
        |  24877 |  10085 | system.cpu.load[percpu,avg5]  |
        |  24878 |  10085 | system.cpu.switches           |
        |  24879 |  10085 | system.cpu.util[,idle]        |
        |  24880 |  10085 | system.cpu.util[,interrupt]   |
        |  24881 |  10085 | system.cpu.util[,iowait]      |
        |  24882 |  10085 | system.cpu.util[,nice]        |
        |  24883 |  10085 | system.cpu.util[,softirq]     |
        |  24884 |  10085 | system.cpu.util[,steal]       |
        |  24885 |  10085 | system.cpu.util[,system]      |
        |  24886 |  10085 | system.cpu.util[,user]        |
        |  24887 |  10085 | system.hostname               |
        |  24888 |  10085 | system.localtime              |
        |  24889 |  10085 | system.swap.size[,free]       |
        |  24890 |  10085 | system.swap.size[,pfree]      |
        |  24891 |  10085 | system.swap.size[,total]      |
        |  24892 |  10085 | system.uname                  |
        |  24893 |  10085 | system.uptime                 |
        |  24894 |  10085 | system.users.num              |
        |  24895 |  10085 | vfs.file.cksum[/etc/passwd]   |
        |  24896 |  10085 | vfs.fs.discovery              |
        |  24897 |  10085 | vfs.fs.inode[{#FSNAME},pfree] |
        |  24898 |  10085 | vfs.fs.size[{#FSNAME},free]   |
        |  24899 |  10085 | vfs.fs.size[{#FSNAME},pfree]  |
        |  24900 |  10085 | vfs.fs.size[{#FSNAME},total]  |
        |  24901 |  10085 | vfs.fs.size[{#FSNAME},used]   |
        |  24902 |  10085 | vm.memory.size[available]     |
        |  24903 |  10085 | vm.memory.size[total]         |
        |  48304 |  10085 | icmppingloss[]                |
        |  48305 |  10085 | icmppingsec[]                 |
        |  48306 |  10085 | icmpping[]                    |
        |  48753 |  10085 | net.tcp.service[tcp,,1494]    |
        42 rows in set (0.00 sec)
        So I could delete it like this:
        DELETE FROM `zabbix`.`items` WHERE `itemid` IN (24866,24867,24868,24869,24870,24871,24872,24873,24874,24875,24876,24877,24878,24879,24880,24881,24882,24883,24884,24885,24886,24887,24888,24889,24890,24891,24892,24893,24894,24895,24896,24897,24898,24899,24900,24901,24902,24903,48304,48305,48306,48753);
