Host being monitored by Proxy not working but monitored by Server is working
  • marahman3001
    • Apr 2018
    I have a zabbix server and with separate server hosting its database
    and a proxy server with local database
    All mariadb databases
    Agent Config:
    Server=PROXY_IP
    ServerActive=PROXY_IP
    StartAgents=3
    DebugLevel=3
    LogFile=C:\Zabbix\zabbix_agentd.log
    LogFileSize=5
    Timeout=3
    Hostname=LDNPINF
    Proxy Config:
    Server=SERVER_IP
    LogFile=/var/log/zabbix/zabbix_proxy.log
    LogFileSize=0
    PidFile=/var/run/zabbix/zabbix_proxy.pid
    DBHost=127.0.0.1
    DBName=zabbix_proxy_emea
    DBUser=zabbix
    DBPassword=********
    SNMPTrapperFile=/var/log/snmptrap/snmptrap.log
    Timeout=4
    ExternalScripts=/usr/lib/zabbix/externalscripts
    LogSlowQueries=3000
    Server Config:
    LogFile=/var/log/zabbix/zabbix_server.log
    LogFileSize=0
    PidFile=/var/run/zabbix/zabbix_server.pid
    DBHost=DATABASE_SERVER_IP
    DBName=zabbix
    DBUser=zabbix
    DBPassword=********
    DBPort=3306
    Timeout=4
    AlertScriptsPath=/usr/lib/zabbix/alertscripts
    LogSlowQueries=3000
    Added proxy server under Proxies and it is last seen OK
    if the host is set under "monitored by proxy" with the Proxy Server, the host's availability is GREY
    telnet from server to host
    Connected to IP
    Escape character is '^]'.
    Connection closed by foreign host.
    telnet from proxy to host
    Connected to IP
    zabbix_proxy.log
    received configuration data from server at "ZABBIX_SERVER_IP", datalen 12939
    zabbix_server.log
    sending configuration data to proxy "PROXY_SERVER" at "PROXY_IP", datalen 12939
    27305:20180515:130242.891 Zabbix agent item "net.if.in[WAN Miniport (IPv6)]" on host "LDNPINF" failed: first network error, wait for 15 seconds
    27306:20180515:130257.202 Zabbix agent item "net.if.in[Microsoft Kernel Debug Network Adapter]" on host "LDNPINF" failed: another network error, wait for 15 seconds
    27306:20180515:130312.236 Zabbix agent item "net.if.out[WAN Miniport (Network Monitor)]" on host "LDNPINF" failed: another network error, wait for 15 seconds
    27306:20180515:130327.266 temporarily disabling Zabbix agent checks on host "LDNPINF": host unavailable
    Please help. The host when monitored by Proxy is not working. The availability is GREY even though there are items and templates attached.
  • marahman3001
    • Apr 2018
    it all worked after some time. thanks
    • LenR
      • Sep 2009
      • 1011
      Probably the refresh interval of the proxy config.
