Hi!
I'm trying to monitor several Mikrotik routers with zabbix 2.2 I want to use LLD of SNMP OIDs and monitor these values:
these values are represented with OIDs:
I created a Discovery rule with SNMP OID: mtxrWlRtabAddr. The value of #SNMPINDEX is treated as string so it has these 3 values:
.'..Bb..'.4
.'..B{O.'.13
.'..B{P.'.1693
I created item prototypes but these "string" #SNMPINDEX values are not working even not with snmpwalk.
For example this command retrieve no value:
But the same command with OID as number retrieve the right value:
Is there any way to force zabbix to use number reprezentation of SNMPINDEX instead of string?
I've tried to edit the Discovery rule SNMP OID to the number representation of mtxrWlRtabAddr - .1.3.6.1.4.1.14988.1.1.1.2.1.1 but the value of SNMPINDEX was still a string.
snmpwalk -m ALL -v 2c -c public 10.1.1.25 mtxr 2>%1 | grep Rtab
MIKROTIK-MIB::mtxrWlRtabAddr.'..Bb..'.4 = STRING: 0:c:42:62:ed:b8
MIKROTIK-MIB::mtxrWlRtabAddr.'..B{O.'.13 = STRING: 0:c:42:7b:4f:b7
MIKROTIK-MIB::mtxrWlRtabAddr.'..B{P.'.1693 = STRING: 0:c:42:7b:50:15
MIKROTIK-MIB::mtxrWlRtabStrength.'..Bb..'.4 = INTEGER: -57
MIKROTIK-MIB::mtxrWlRtabStrength.'..B{O.'.13 = INTEGER: -57
MIKROTIK-MIB::mtxrWlRtabStrength.'..B{P.'.1693 = INTEGER: -79
MIKROTIK-MIB::mtxrWlRtabTxBytes.'..Bb..'.4 = Counter32: 1403192725
MIKROTIK-MIB::mtxrWlRtabTxBytes.'..B{O.'.13 = Counter32: 471748537
MIKROTIK-MIB::mtxrWlRtabTxBytes.'..B{P.'.1693 = Counter32: 3501943253
MIKROTIK-MIB::mtxrWlRtabRxBytes.'..Bb..'.4 = Counter32: 1407096665
MIKROTIK-MIB::mtxrWlRtabRxBytes.'..B{O.'.13 = Counter32: 57091893
MIKROTIK-MIB::mtxrWlRtabRxBytes.'..B{P.'.1693 = Counter32: 524033999
MIKROTIK-MIB::mtxrWlRtabTxPackets.'..Bb..'.4 = Counter32: 317406075
MIKROTIK-MIB::mtxrWlRtabTxPackets.'..B{O.'.13 = Counter32: 2467100
MIKROTIK-MIB::mtxrWlRtabTxPackets.'..B{P.'.1693 = Counter32: 17857918
MIKROTIK-MIB::mtxrWlRtabRxPackets.'..Bb..'.4 = Counter32: 227006377
MIKROTIK-MIB::mtxrWlRtabRxPackets.'..B{O.'.13 = Counter32: 323986
MIKROTIK-MIB::mtxrWlRtabRxPackets.'..B{P.'.1693 = Counter32: 3519667
MIKROTIK-MIB::mtxrWlRtabTxRate.'..Bb..'.4 = Gauge32: 240000000
MIKROTIK-MIB::mtxrWlRtabTxRate.'..B{O.'.13 = Gauge32: 150000000
MIKROTIK-MIB::mtxrWlRtabTxRate.'..B{P.'.1693 = Gauge32: 60000000
MIKROTIK-MIB::mtxrWlRtabRxRate.'..Bb..'.4 = Gauge32: 240000000
MIKROTIK-MIB::mtxrWlRtabRxRate.'..B{O.'.13 = Gauge32: 150000000
MIKROTIK-MIB::mtxrWlRtabRxRate.'..B{P.'.1693 = Gauge32: 54000000
MIKROTIK-MIB::mtxrWlRtabRouterOSVersion.'..Bb..'.4 = STRING:
MIKROTIK-MIB::mtxrWlRtabRouterOSVersion.'..B{O.'.13 = STRING:
MIKROTIK-MIB::mtxrWlRtabRouterOSVersion.'..B{P.'.1693 = STRING:
MIKROTIK-MIB::mtxrWlRtabUptime.'..Bb..'.4 = Timeticks: (42359500) 4 days, 21:39:55.00
MIKROTIK-MIB::mtxrWlRtabUptime.'..B{O.'.13 = Timeticks: (11136300) 1 day, 6:56:03.00
MIKROTIK-MIB::mtxrWlRtabUptime.'..B{P.'.1693 = Timeticks: (42388100) 4 days, 21:44:41.00
MIKROTIK-MIB::mtxrWlRtabSignalToNoise.'..Bb..'.4 = INTEGER: 51
MIKROTIK-MIB::mtxrWlRtabSignalToNoise.'..B{O.'.13 = INTEGER: 50
MIKROTIK-MIB::mtxrWlRtabSignalToNoise.'..B{P.'.1693 = INTEGER: 33
MIKROTIK-MIB::mtxrWlRtabTxStrengthCh0.'..Bb..'.4 = INTEGER: -61
MIKROTIK-MIB::mtxrWlRtabTxStrengthCh0.'..B{O.'.13 = INTEGER: -63
MIKROTIK-MIB::mtxrWlRtabTxStrengthCh0.'..B{P.'.1693 = INTEGER: -77
MIKROTIK-MIB::mtxrWlRtabRxStrengthCh0.'..Bb..'.4 = INTEGER: -61
MIKROTIK-MIB::mtxrWlRtabRxStrengthCh0.'..B{O.'.13 = INTEGER: -57
MIKROTIK-MIB::mtxrWlRtabRxStrengthCh0.'..B{P.'.1693 = INTEGER: -79
MIKROTIK-MIB::mtxrWlRtabTxStrengthCh1.'..Bb..'.4 = INTEGER: -61
MIKROTIK-MIB::mtxrWlRtabTxStrengthCh1.'..B{O.'.13 = INTEGER: 0
MIKROTIK-MIB::mtxrWlRtabTxStrengthCh1.'..B{P.'.1693 = INTEGER: 0
MIKROTIK-MIB::mtxrWlRtabRxStrengthCh1.'..Bb..'.4 = INTEGER: -60
MIKROTIK-MIB::mtxrWlRtabRxStrengthCh1.'..B{O.'.13 = INTEGER: 0
MIKROTIK-MIB::mtxrWlRtabRxStrengthCh1.'..B{P.'.1693 = INTEGER: 0
MIKROTIK-MIB::mtxrWlRtabTxStrengthCh2.'..Bb..'.4 = INTEGER: -96
MIKROTIK-MIB::mtxrWlRtabTxStrengthCh2.'..B{O.'.13 = INTEGER: 0
MIKROTIK-MIB::mtxrWlRtabTxStrengthCh2.'..B{P.'.1693 = INTEGER: 0
MIKROTIK-MIB::mtxrWlRtabRxStrengthCh2.'..Bb..'.4 = INTEGER: -96
MIKROTIK-MIB::mtxrWlRtabRxStrengthCh2.'..B{O.'.13 = INTEGER: 0
MIKROTIK-MIB::mtxrWlRtabRxStrengthCh2.'..B{P.'.1693 = INTEGER: 0
MIKROTIK-MIB::mtxrWlRtabEntryCount.0 = Gauge32: 3
snmpwalk -m ALL -v 2c -c public 10.1.1.25 -On mtxr 2>%1 .1.3.6.1.4.1.14988.1.1.1.2.1.1.0.12.66.98.237.184.4 = STRING: 0:c:42:62:ed:b8 .1.3.6.1.4.1.14988.1.1.1.2.1.1.0.12.66.123.79.183.13 = STRING: 0:c:42:7b:4f:b7 .1.3.6.1.4.1.14988.1.1.1.2.1.1.0.12.66.123.80.21.1693 = STRING: 0:c:42:7b:50:15 .1.3.6.1.4.1.14988.1.1.1.2.1.3.0.12.66.98.237.184.4 = INTEGER: -57 .1.3.6.1.4.1.14988.1.1.1.2.1.3.0.12.66.123.79.183.13 = INTEGER: -57 .1.3.6.1.4.1.14988.1.1.1.2.1.3.0.12.66.123.80.21.1693 = INTEGER: -79 .1.3.6.1.4.1.14988.1.1.1.2.1.4.0.12.66.98.237.184.4 = Counter32: 1639744120 .1.3.6.1.4.1.14988.1.1.1.2.1.4.0.12.66.123.79.183.13 = Counter32: 474496865 .1.3.6.1.4.1.14988.1.1.1.2.1.4.0.12.66.123.80.21.1693 = Counter32: 3504711740 .1.3.6.1.4.1.14988.1.1.1.2.1.5.0.12.66.98.237.184.4 = Counter32: 1475879196 .1.3.6.1.4.1.14988.1.1.1.2.1.5.0.12.66.123.79.183.13 = Counter32: 57343723 .1.3.6.1.4.1.14988.1.1.1.2.1.5.0.12.66.123.80.21.1693 = Counter32: 524287844 .1.3.6.1.4.1.14988.1.1.1.2.1.6.0.12.66.98.237.184.4 = Counter32: 317824849 .1.3.6.1.4.1.14988.1.1.1.2.1.6.0.12.66.123.79.183.13 = Counter32: 2486545 .1.3.6.1.4.1.14988.1.1.1.2.1.6.0.12.66.123.80.21.1693 = Counter32: 17877555 .1.3.6.1.4.1.14988.1.1.1.2.1.7.0.12.66.98.237.184.4 = Counter32: 227247181 .1.3.6.1.4.1.14988.1.1.1.2.1.7.0.12.66.123.79.183.13 = Counter32: 325772 .1.3.6.1.4.1.14988.1.1.1.2.1.7.0.12.66.123.80.21.1693 = Counter32: 3521466 .1.3.6.1.4.1.14988.1.1.1.2.1.8.0.12.66.98.237.184.4 = Gauge32: 240000000 .1.3.6.1.4.1.14988.1.1.1.2.1.8.0.12.66.123.79.183.13 = Gauge32: 150000000 .1.3.6.1.4.1.14988.1.1.1.2.1.8.0.12.66.123.80.21.1693 = Gauge32: 60000000 .1.3.6.1.4.1.14988.1.1.1.2.1.9.0.12.66.98.237.184.4 = Gauge32: 240000000 .1.3.6.1.4.1.14988.1.1.1.2.1.9.0.12.66.123.79.183.13 = Gauge32: 135000000 .1.3.6.1.4.1.14988.1.1.1.2.1.9.0.12.66.123.80.21.1693 = Gauge32: 60000000 .1.3.6.1.4.1.14988.1.1.1.2.1.10.0.12.66.98.237.184.4 = STRING: .1.3.6.1.4.1.14988.1.1.1.2.1.10.0.12.66.123.79.183.13 = STRING: .1.3.6.1.4.1.14988.1.1.1.2.1.10.0.12.66.123.80.21.1693 = STRING: .1.3.6.1.4.1.14988.1.1.1.2.1.11.0.12.66.98.237.184.4 = Timeticks: (42458000) 4 days, 21:56:20.00 .1.3.6.1.4.1.14988.1.1.1.2.1.11.0.12.66.123.79.183.13 = Timeticks: (11234900) 1 day, 7:12:29.00 .1.3.6.1.4.1.14988.1.1.1.2.1.11.0.12.66.123.80.21.1693 = Timeticks: (42486700) 4 days, 22:01:07.00 .1.3.6.1.4.1.14988.1.1.1.2.1.12.0.12.66.98.237.184.4 = INTEGER: 51 .1.3.6.1.4.1.14988.1.1.1.2.1.12.0.12.66.123.79.183.13 = INTEGER: 49 .1.3.6.1.4.1.14988.1.1.1.2.1.12.0.12.66.123.80.21.1693 = INTEGER: 32 .1.3.6.1.4.1.14988.1.1.1.2.1.13.0.12.66.98.237.184.4 = INTEGER: -61 .1.3.6.1.4.1.14988.1.1.1.2.1.13.0.12.66.123.79.183.13 = INTEGER: -63 .1.3.6.1.4.1.14988.1.1.1.2.1.13.0.12.66.123.80.21.1693 = INTEGER: -77 .1.3.6.1.4.1.14988.1.1.1.2.1.14.0.12.66.98.237.184.4 = INTEGER: -62 .1.3.6.1.4.1.14988.1.1.1.2.1.14.0.12.66.123.79.183.13 = INTEGER: -57 .1.3.6.1.4.1.14988.1.1.1.2.1.14.0.12.66.123.80.21.1693 = INTEGER: -79 .1.3.6.1.4.1.14988.1.1.1.2.1.15.0.12.66.98.237.184.4 = INTEGER: -61 .1.3.6.1.4.1.14988.1.1.1.2.1.15.0.12.66.123.79.183.13 = INTEGER: 0 .1.3.6.1.4.1.14988.1.1.1.2.1.15.0.12.66.123.80.21.1693 = INTEGER: 0 .1.3.6.1.4.1.14988.1.1.1.2.1.16.0.12.66.98.237.184.4 = INTEGER: -61 .1.3.6.1.4.1.14988.1.1.1.2.1.16.0.12.66.123.79.183.13 = INTEGER: 0 .1.3.6.1.4.1.14988.1.1.1.2.1.16.0.12.66.123.80.21.1693 = INTEGER: 0 .1.3.6.1.4.1.14988.1.1.1.2.1.17.0.12.66.98.237.184.4 = INTEGER: -96 .1.3.6.1.4.1.14988.1.1.1.2.1.17.0.12.66.123.79.183.13 = INTEGER: 0 .1.3.6.1.4.1.14988.1.1.1.2.1.17.0.12.66.123.80.21.1693 = INTEGER: 0 .1.3.6.1.4.1.14988.1.1.1.2.1.18.0.12.66.98.237.184.4 = INTEGER: -96 .1.3.6.1.4.1.14988.1.1.1.2.1.18.0.12.66.123.79.183.13 = INTEGER: 0 .1.3.6.1.4.1.14988.1.1.1.2.1.18.0.12.66.123.80.21.1693 = INTEGER: 0
.'..Bb..'.4
.'..B{O.'.13
.'..B{P.'.1693
snmpwalk -m ALL -v 2c -c public 10.1.1.25 mtxrWlRtabAddr.'..Bb..'.4 2>%1
snmpwalk -m ALL -v 2c -c public 10.1.1.25 .1.3.6.1.4.1.14988.1.1.1.2.1.1.0.12.66.98.237.184.4 2>%1 MIKROTIK-MIB::mtxrWlRtabAddr.'..Bb..'.4 = STRING: 0:c:42:62:ed:b8
