Hello all
I'm using Zabbix Server 2.2.7 running on Debian 8.
There are some templates that use low level discovery (mounted filesystem), there are some triggers in the LLD. I want to disable some of these triggers
What I do is go to mounted filesystem triggers and disable them. Seems to be OK. However hosts using the template seem not to notice changes - when I go to host triggers (that list all of the triggers host use), the mounted filesystem triggers are still enabled.
Is it a bug? For example: https://support.zabbix.com/browse/ZBX-11558
Or maybe I am doing something wrong?
Tried waiting for changes to propagate, but even after few days pass nothing change.
Many thanks for any suggestions!
