Zabbix 3.2 - Log monitoring too many alerts for same pattern
  • pushpendra.singh
    • Aug 2017
    I am monitoring the log files from zabbix, however, Problem i have is , it is sending too many emails for similar log pattern.
    for example ,
    if ERROR found in a line of logfile then send an email due to which i am getting huge alerts . Is there any way through which i can check if line containing "ERROR" keyword is having different pattern ?
    I am getting three alerts for below three lines but i want one alert. But when their pattern is not same in that case i should be getting three alerts .
    Pattern is same: i should be getting only one email.
    [ERROR] 2018-05-08 03:14:38.957 [stream_4] CSVDataProvider - java.time.format.DateTimeParseException: Text '13/01/2015 00:00:00.000' could not be parsed: Invalid value for MonthOfYear (valid values 1 - 12): 13
    [ERROR] 2018-05-08 03:14:39.957 [stream_4] CSVDataProvider - java.time.format.DateTimeParseException: Text '13/01/2015 00:00:00.000' could not be parsed: Invalid value for MonthOfYear (valid values 1 - 12): 13
    ​​​​​​​[ERROR] 2018-05-08 03:14:40.957 [stream_4] CSVDataProvider - java.time.format.DateTimeParseException: Text '13/01/2015 00:00:00.000' could not be parsed: Invalid value for MonthOfYear (valid values 1 - 12): 13
    for below ​​​​​​​Pattern is not same ==> for which i am ok to get three alerts
    ​​​​​​​[ERROR] 2018-05-08 03:14:39.957 [stream_4] MARKETDataProvider - java.time.format.DateTimeParseException: Text '13/01/2015 00:00:00.000' could not be parsed: Invalid value for MonthOfYear (valid values 1 - 12): 13
    ​​​​​​​[ERROR] 2018-05-08 03:14:40.957 [stream_4] REFRENCEDataProvider - java.time.format.DateTimeParseException: Text '13/01/2015 00:00:00.000' could not be parsed: Invalid value for MonthOfYear (valid values 1 - 12): 13
    Please help me to fix this
