Hi All,
I would like to know, is there any way where i can schedule zabbix housekeeper process at night or some time when the loads on the server is slow. As of now, i see that consistently some or the other delete query is running on zabbix, and its taking lot of time, hence (looks like ) zabbix UI takes as much as 50-60+ seconds to respond to clicks.
Zabbix dashboard status is like this,
I have made below entries in zabbix server conf w.r.to houseKeeper settings
I may not be correct in terms of configurations, please point to right place if you think above configs are wrong. I am kind a stuck at resolving this wait on the zabbix UI and load on the server issue, hence i am exposing most of the details of zabbix server. ( Pardon me if you think i am mixing up issues - i am not sure what is causing load, thought houseKeeper is causing it).
1). Zabbix Server ( 2.0.6) and DB ( mysql 5.1.69-log Source distribution ) , httpd ( 2.2.15 ) is running on the same machine with CentOS 6.4. Its H/W configs are, 8 Core, 36G RAM, 500GB HDD ( SAAS, RAID 5 configured)
2). Zabbix Conf Details
- Cache, TrendCache, HistorySize cache are high, because long back zabbix crashed due these settings, and at this size i got zabbix working.
- Timeout is 30, as i have some servers/ n/w devices (snmp) are sending data lately due to n/w latency.
- Trapper, Pinger, Pollers are exactly 45 - okay this might be put in random number - need your suggestion on this.
- When zabbix starts it runs 184 zabbix_server process, and it varies later to 169-181.
- When taken dump, zabbix DB size is close to 27GB.
MySql Config. Yes i have enabled replication ( below is zabbixserver/master config).
And below is the mysqltuner output.
It would be great if you guys can suggest where i am doing wrong.
Any suggestion w.r.to housekeeper scheduling and tuning zabbix server/mysql or to make sure server responds to clicks or any other suggestions are greatly helpful.
Number of hosts (monitored/not monitored/templates) :489, 425 / 19 / 45 Number of items (monitored/disabled/not supported) :15830, 15063 / 340 / 427 Number of triggers (enabled/disabled)[problem/unknown/ok] : 1292, 1087 / 205 [10 / 0 / 1077] Number of users (online) : 34 , 6 Required server performance, new values per second : 98.53
HousekeepingFrequency=12 MaxHousekeeperDelete=5500 DisableHousekeeping=0
LogFile=/var/log/zabbix/zabbix_server.log LogFileSize=50 DebugLevel=4 PidFile=/var/run/zabbix/zabbix_server.pid DBName=zabbix DBUser=zabbix DBPassword= StartPollers=45 StartTrappers=45 StartPingers=45 StartDiscoverers=3 StartSNMPTrapper=1 ListenIP=0.0.0.0 HousekeepingFrequency=12 MaxHousekeeperDelete=5500 SenderFrequency=300 CacheSize=1G CacheUpdateFrequency=300 StartDBSyncers=15 HistoryCacheSize=128M TrendCacheSize=1G HistoryTextCacheSize=128M Timeout=30 TrapperTimeout=120 UnreachablePeriod=120 AlertScriptsPath=/etc/zabbix/alert.d/ FpingLocation=/usr/local/sbin/fping LogSlowQueries=1
[mysqld] datadir=/var/lib/mysql socket=/var/lib/mysql/mysql.sock slow_query_log_file=/var/log/mysql/slow-query.log long_query_time = 30 log-queries-not-using-indexes=YES innodb_lock_wait_timeout=500 innodb_locks_unsafe_for_binlog=1 innodb_buffer_pool_size=20G innodb_file_per_table max_allowed_packet = 8M innodb_additional_mem_pool_size = 30M innodb_thread_concurrency = 8 key_buffer_size = 60M max_connections=290 table_cache=4096 query_cache_size = 96M tmp_table_size = 32M thread_cache_size = 64 sort_buffer_size = 12M query_cache_limit=64M thread_cache_size=512 wait_timeout=60 read_buffer_size=2M read_rnd_buffer_size=8M join_buffer_size=8M log-bin=/var/log/mysql/mysql-bin.log binlog-do-db=zabbix server-id=1 sync_binlog=1 [mysqld_safe] log-error=/var/log/mysql/mysqld.log pid-file=/var/run/mysqld/mysqld.pid
[--] Skipped version check for MySQLTuner script
[OK] Currently running supported MySQL version 5.1.69-log
[OK] Operating on 64-bit architecture
-------- Storage Engine Statistics -------------------------------------------
[--] Status: -Archive -BDB -Federated +InnoDB -ISAM -NDBCluster
[--] Data in InnoDB tables: 27G (Tables: 103)
[!!] Total fragmented tables: 103
-------- Performance Metrics -------------------------------------------------
[--] Up for: 15d 3h 34m 39s (315M q [241.388 qps], 1M conn, TX: 192B, RX: 49B)
[--] Reads / Writes: 43% / 57%
[--] Total buffers: 20.2G global + 30.2M per thread (290 max threads)
[OK] Maximum possible memory usage: 28.8G (81% of installed RAM)
[OK] Slow queries: 0% (110K/315M)
[OK] Highest usage of available connections: 81% (235/290)
[OK] Key buffer size / total MyISAM indexes: 60.0M/91.0K
[OK] Key buffer hit rate: 100.0% (18M cached / 5 reads)
[OK] Query cache efficiency: 25.4% (35M cached / 138M selects)
[!!] Query cache prunes per day: 25406
[OK] Sorts requiring temporary tables: 0% (141 temp sorts / 10M sorts)
[OK] Temporary tables created on disk: 2% (1M on disk / 40M total)
[OK] Thread cache hit rate: 99% (235 created / 1M connections)
[OK] Table cache hit rate: 98% (505 open / 512 opened)
[OK] Open file limit used: 0% (43/8K)
[OK] Table locks acquired immediately: 100% (360M immediate / 360M locks)
[!!] InnoDB data size / buffer pool: 27.4G/20.0G
-------- Recommendations -----------------------------------------------------
General recommendations:
Run OPTIMIZE TABLE to defragment tables for better performance
Enable the slow query log to troubleshoot bad queries
Variables to adjust:
long_query_time (<= 10)
query_cache_size (> 96M)
innodb_buffer_pool_size (>= 27G)
